bsps/riscv: interrupt not occurred
Padmarao.Begari at microchip.com
Thu Feb 9 06:36:53 UTC 2023
Hi,
While testing the Candence GEM driver of RTEMS-FreeBSD with the RTEMS
on the PolarFire SoC Icicle Kit found one issue.
Issue:The Interrupt is disabled before clearing the interrupt complete
in the PLIC because of this the same interrupt is not occurred next
time.
Resolved: Clear the Interrupt complete in the PLIC before disable the
interrupt.
Updated the bsp_interrupt_vector_disable() function like below then the
cgem driver is working fine with the RTEMS.
@Sebastian Huber - Can I send the patch for this?
rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number
vector)
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
if (RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector)) {
uint32_t interrupt_index;
volatile uint32_t *enable;
uint32_t group;
uint32_t bit;
rtems_interrupt_lock_context lock_context;
volatile RISCV_PLIC_hart_regs *plic_hart_regs;
interrupt_index = RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(vector);
enable = riscv_plic_irq_to_cpu[interrupt_index - 1];
group = interrupt_index / 32;
bit = UINT32_C(1) << (interrupt_index % 32);
rtems_interrupt_lock_acquire(&riscv_plic_lock, &lock_context);
#ifdef RTEMS_SMP
uint32_t cpu_max;
uint32_t cpu_index;
cpu_max = _SMP_Get_processor_maximum();
for (cpu_index = 0; cpu_index < cpu_max; ++cpu_index) {
Per_CPU_Control *cpu;
cpu = _Per_CPU_Get_by_index(cpu_index);
enable = cpu->cpu_per_cpu.plic_m_ie;
plic_hart_regs = cpu->cpu_per_cpu.plic_hart_regs;
plic_hart_regs->claim_complete = interrupt_index;
if (enable != NULL) {
enable[group] &= ~bit;
#else
cpu = _Per_CPU_Get_by_index(0);
#endif
rtems_interrupt_lock_release(&riscv_plic_lock, &lock_context);
return RTEMS_SUCCESSFUL;
if (vector == RISCV_INTERRUPT_VECTOR_TIMER) {
clear_csr(mie, MIP_MTIP);
_Assert(vector == RISCV_INTERRUPT_VECTOR_SOFTWARE);
clear_csr(mie, MIP_MSIP);
Regards
Padmarao
