[PATCH rtems-release] rtems-notes-6.md: Add removal of libmisc/serdbg
Chris Johns
chrisj at rtems.org
Thu Feb 9 22:42:13 UTC 2023
OK. I will apply if you do not because I want to move that file :)
On 10/2/2023 2:11 am, Joel Sherrill wrote:
> Updates #2828.
> rtems-notes-6.md | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/rtems-notes-6.md b/rtems-notes-6.md
> index 70b66a3..7197def 100644
> --- a/rtems-notes-6.md
> +++ b/rtems-notes-6.md
> @@ -262,7 +262,8 @@ The following improvements were made to the RTEMS Shell:
> ## General
> -* TBD
> +* The obsolete libmisc/serdbg was removed. Use libdebugger instead. This functionality
> + was not built as part of the 5 release series in anticipation of its removal.
> ## Architectures
