[PATCH v1 0/1] Update rtems-llvm to version 11.1.0
Jan Sommer
jan.sommer at dlr.de
Fri Feb 10 09:16:26 UTC 2023
Hello,
I couldn't get the rtems-llvm buildset to work.
As it was building llvm8 which is not that modern, I just tried to build
a more recent version with the scripts.
It works with llvm11. Are there any objections to updating?
And should we keep the rtems-llvm-8.cfg or should I remove this with
this patch?
Have a nice weekend,
Jan
Jan Sommer (1):
rtems-tools: Update rtems-llvm to version 11.1.0
rtems/config/6/rtems-llvm.bset | 2 +-
rtems/config/tools/rtems-llvm-11.1.0.cfg | 21 +++++++++++++++++++++
source-builder/config/llvm-common-1.cfg | 6 +++---
3 files changed, 25 insertions(+), 4 deletions(-)
create mode 100644 rtems/config/tools/rtems-llvm-11.1.0.cfg
2.25.1
