[PATCH] bsp/leon3: Move SMP data to start.S
Joel Sherrill
joel at rtems.org
Fri Feb 10 14:22:16 UTC 2023
Looks ok.
On Fri, Feb 10, 2023 at 3:57 AM Sebastian Huber <
> The LEON3_Boot_Cpu global object is only used by start.S. Move the
> definition
> of this object to start.S and use a local symbol .Lbootcpuindex for it.
> Use a compare-and-swap instruction to assign the boot CPU. This allows a
> concurrent initialization.
> Close #4845.
> bsps/sparc/leon3/start/bspstart.c | 5 -----
> bsps/sparc/shared/start/start.S | 35 +++++++++++++++++++++----------
> 2 files changed, 24 insertions(+), 16 deletions(-)
> diff --git a/bsps/sparc/leon3/start/bspstart.c
> b/bsps/sparc/leon3/start/bspstart.c
> index d93d73aca8..61f888247f 100644
> --- a/bsps/sparc/leon3/start/bspstart.c
> +++ b/bsps/sparc/leon3/start/bspstart.c
> @@ -59,11 +59,6 @@ int CPU_SPARC_HAS_SNOOPING;
> /* Index of CPU, in an AMP system CPU-index may be non-zero */
> uint32_t LEON3_Cpu_Index = 0;
> -#if defined(RTEMS_SMP)
> -/* Index of the boot CPU. Set by the first CPU at boot to its CPU ID. */
> -int LEON3_Boot_Cpu = -1;
> -#endif
> * set_snooping
> diff --git a/bsps/sparc/shared/start/start.S
> b/bsps/sparc/shared/start/start.S
> index a67c6bc163..01f1353758 100644
> --- a/bsps/sparc/shared/start/start.S
> +++ b/bsps/sparc/shared/start/start.S
> @@ -493,17 +493,13 @@ SYM(hard_reset):
> mov %sp, %fp ! set frame pointer
> #if defined(START_LEON3_ENABLE_SMP)
> - /* If LEON3_Boot_Cpu < 0 then assign us as boot CPU and continue.
> - set SYM(LEON3_Boot_Cpu), %l0
> - ld [%l0], %l1
> - tst %l1
> - bneg .Lbootcpu
> - nop
> - call SYM(bsp_start_on_secondary_processor) ! does not return
> - mov %g6, %o0
> -.Lbootcpu:
> - st %l7, [%l0]
> + /* If .Lbootcpuindex < 0 then assign us as boot CPU and continue.
> + set SYM(.Lbootcpuindex), %l0
> + mov -1, %l1
> + casa [ %l0 ] (10), %l1, %l7
> + cmp %l1, %l7
> + bne .Lbootsecondarycpu
> + nop
> #endif
> /* clear the bss */
> @@ -527,4 +523,21 @@ SYM(hard_reset):
> call SYM(boot_card) ! does not return
> mov %g0, %o0 ! command line
> +#if defined(START_LEON3_ENABLE_SMP)
> +.Lbootsecondarycpu:
> + call SYM(bsp_start_on_secondary_processor) ! does not return
> + mov %g6, %o0
> + * This is the index of the boot CPU. Set by the first CPU at
> boot to
> + * its CPU index.
> + .section .data, "aw"
> + .align 4
> + .type .Lbootcpuindex, #object
> + .size .Lbootcpuindex, 4
> +.Lbootcpuindex:
> + .long -1
> +#endif
> /* end of file */
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230210/22a75e8a/attachment.htm>
