[PATCH] rtems: Document scheduler configuration API
Gedare Bloom
gedare at rtems.org
Fri Feb 10 14:56:27 UTC 2023
ok, thanks
On Fri, Feb 10, 2023 at 7:20 AM Sebastian Huber
> Move the scheduler configuration macros out of the #ifdef
> CONFIGURE_SCHEDULER_* scope so that Doxygen can see them and generate
> the corresponding documentation entries.
> cpukit/include/rtems/scheduler.h | 569 ++++++++++++++++++++++---------
> 1 file changed, 407 insertions(+), 162 deletions(-)
> diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
> index 2adb42adc2..daf949fb48 100644
> --- a/cpukit/include/rtems/scheduler.h
> +++ b/cpukit/include/rtems/scheduler.h
> @@ -54,6 +54,8 @@
> extern const Scheduler_Control RTEMS_SCHEDULER_INVALID_INDEX;
> + * @ingroup RTEMSApplConfigGeneralSchedulerConfiguration
> * @brief This define indicates that default attributes shall be used for a
> * processor to scheduler assignment.
> @@ -64,11 +66,13 @@
> SCHEDULER_ASSIGN_DEFAULT
> * @brief This define indicates that the processor is optionally assigned to
> * the scheduler.
> - * If the processor is not present during system initialization, then no
> - * fatal error will occur.
> + * If the processor is not present during system initialization, then the
> + * system initialization continues and the processor is marked as not online.
> * This define may be used as an attribute parameter value in the
> * RTEMS_SCHEDULER_ASSIGN() macro.
> @@ -77,12 +81,14 @@
> SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL
> * @brief This define indicates that the processor to scheduler assignment is
> * mandatory.
> - * fatal error with source ::RTEMS_FATAL_SOURCE_SMP and code
> - * ::SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT will occur.
> + * system terminates with the fatal source of ::RTEMS_FATAL_SOURCE_SMP and
> + * fatal code of ::SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT.
> @@ -91,6 +97,8 @@
> SCHEDULER_ASSIGN_PROCESSOR_MANDATORY
> * @brief Defines a processor to scheduler assignment.
> * This macro may be used to define entries of the scheduler assignment
> @@ -108,6 +116,8 @@
> * @brief Defines that no scheduler is assigned to the processor.
> * This processor cannot be used by the application.
> @@ -126,23 +136,48 @@
> * information.
> -#ifdef CONFIGURE_SCHEDULER_CBS
> - #include <rtems/score/schedulercbs.h>
> + * @brief Defines a CBS Scheduler context name based on the instantiation
> + * name.
> + * @param name is the scheduler instantiation name.
> +#define SCHEDULER_CBS_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( CBS_ ## name )
> - #define SCHEDULER_CBS_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( CBS_ ## name )
> + * @brief Defines a CBS Scheduler instantiation.
> +#define RTEMS_SCHEDULER_CBS( name ) \
> + static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_CBS( name ) \
> - static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
> + * @brief Defines a CBS Scheduler entry for the scheduler table.
> + * Use this macro to define an entry for the
> + * @ref CONFIGURE_SCHEDULER_TABLE_ENTRIES application configuration option.
> + * @param name is the scheduler object name.
> +#define RTEMS_SCHEDULER_TABLE_CBS( name, obj_name ) \
> + &SCHEDULER_CBS_CONTEXT_NAME( name ).Base, \
> + SCHEDULER_CBS_ENTRY_POINTS, \
> + SCHEDULER_CBS_MAXIMUM_PRIORITY, \
> + ( obj_name ) \
> + SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( true ) \
> - #define RTEMS_SCHEDULER_TABLE_CBS( name, obj_name ) \
> - &SCHEDULER_CBS_CONTEXT_NAME( name ).Base, \
> - SCHEDULER_CBS_ENTRY_POINTS, \
> - SCHEDULER_CBS_MAXIMUM_PRIORITY, \
> - ( obj_name ) \
> - SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( true ) \
> +#ifdef CONFIGURE_SCHEDULER_CBS
> + #include <rtems/score/schedulercbs.h>
> /* Provided for backward compatibility */
> @@ -153,23 +188,48 @@
> #endif
> -#ifdef CONFIGURE_SCHEDULER_EDF
> - #include <rtems/score/scheduleredf.h>
> + * @brief Defines an EDF Scheduler context name based on the instantiation
> + * name.
> +#define SCHEDULER_EDF_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( EDF_ ## name )
> - #define SCHEDULER_EDF_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( EDF_ ## name )
> + * @brief Defines an EDF Scheduler instantiation.
> +#define RTEMS_SCHEDULER_EDF( name ) \
> + static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_EDF( name ) \
> - static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
> + * @brief Defines an EDF Scheduler entry for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_EDF( name, obj_name ) \
> + &SCHEDULER_EDF_CONTEXT_NAME( name ).Base, \
> + SCHEDULER_EDF_ENTRY_POINTS, \
> + SCHEDULER_EDF_MAXIMUM_PRIORITY, \
> + ( obj_name ) \
> - #define RTEMS_SCHEDULER_TABLE_EDF( name, obj_name ) \
> - &SCHEDULER_EDF_CONTEXT_NAME( name ).Base, \
> - SCHEDULER_EDF_ENTRY_POINTS, \
> - SCHEDULER_EDF_MAXIMUM_PRIORITY, \
> - ( obj_name ) \
> +#ifdef CONFIGURE_SCHEDULER_EDF
> + #include <rtems/score/scheduleredf.h>
> @@ -180,34 +240,59 @@
> #endif
> + * @brief Defines an EDF SMP Scheduler context name based on the instantiation
> + * name.
> +#define SCHEDULER_EDF_SMP_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
> + * @brief Defines an EDF SMP Scheduler instantiation.
> +#define RTEMS_SCHEDULER_EDF_SMP( name ) \
> + static struct { \
> + Scheduler_EDF_SMP_Context Base; \
> + Scheduler_EDF_SMP_Ready_queue Ready[ CONFIGURE_MAXIMUM_PROCESSORS + 1 ]; \
> + } SCHEDULER_EDF_SMP_CONTEXT_NAME( name )
> + * @brief Defines an EDF SMP Scheduler entry for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name ) \
> + &SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> + SCHEDULER_EDF_SMP_ENTRY_POINTS, \
> + ( obj_name ) \
> + SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
> #ifdef CONFIGURE_SCHEDULER_EDF_SMP
> #ifndef RTEMS_SMP
> #error "CONFIGURE_SCHEDULER_EDF_SMP cannot be used if RTEMS_SMP is disabled"
> #endif
> - #include <rtems/score/scheduleredfsmp.h>
> #ifndef CONFIGURE_MAXIMUM_PROCESSORS
> - #error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the EDF SMP scheduler"
> + #error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the EDF SMP Scheduler"
> #endif
> - #define SCHEDULER_EDF_SMP_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
> - #define RTEMS_SCHEDULER_EDF_SMP( name ) \
> - static struct { \
> - Scheduler_EDF_SMP_Context Base; \
> - Scheduler_EDF_SMP_Ready_queue Ready[ CONFIGURE_MAXIMUM_PROCESSORS + 1 ]; \
> - } SCHEDULER_EDF_SMP_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name ) \
> - &SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> - SCHEDULER_EDF_SMP_ENTRY_POINTS, \
> - ( obj_name ) \
> - SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
> + #include <rtems/score/scheduleredfsmp.h>
> @@ -218,28 +303,56 @@
> #endif
> -#ifdef CONFIGURE_SCHEDULER_PRIORITY
> - #include <rtems/score/schedulerpriority.h>
> + * @brief Defines a Deterministic Priority Scheduler context name based on the
> + * instantiation name.
> +#define SCHEDULER_PRIORITY_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( priority_ ## name )
> - #define SCHEDULER_PRIORITY_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( priority_ ## name )
> + * @brief Defines a Deterministic Priority Scheduler instantiation.
> + * @param prio_count is the count of supported priority levels.
> +#define RTEMS_SCHEDULER_PRIORITY( name, prio_count ) \
> + static struct { \
> + Scheduler_priority_Context Base; \
> + Chain_Control Ready[ ( prio_count ) ]; \
> + } SCHEDULER_PRIORITY_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_PRIORITY( name, prio_count ) \
> - static struct { \
> - Scheduler_priority_Context Base; \
> - Chain_Control Ready[ ( prio_count ) ]; \
> - } SCHEDULER_PRIORITY_CONTEXT_NAME( name )
> + * @brief Defines a Deterministic Priority Scheduler entry for the scheduler
> + * table.
> +#define RTEMS_SCHEDULER_TABLE_PRIORITY( name, obj_name ) \
> + &SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Base.Base, \
> + SCHEDULER_PRIORITY_ENTRY_POINTS, \
> + RTEMS_ARRAY_SIZE( \
> + SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Ready \
> + ) - 1, \
> + ( obj_name ) \
> - #define RTEMS_SCHEDULER_TABLE_PRIORITY( name, obj_name ) \
> - &SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Base.Base, \
> - SCHEDULER_PRIORITY_ENTRY_POINTS, \
> - RTEMS_ARRAY_SIZE( \
> - SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Ready \
> - ) - 1, \
> - ( obj_name ) \
> +#ifdef CONFIGURE_SCHEDULER_PRIORITY
> + #include <rtems/score/schedulerpriority.h>
> @@ -250,6 +363,55 @@
> #endif
> + * @brief Defines a Arbitrary Processor Affinity Priority SMP Scheduler context
> + * name based on the instantiation name.
> +#define SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( priority_affinity_SMP_ ## name )
> + * instantiation.
> +#define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( name, prio_count ) \
> + static struct { \
> + Scheduler_priority_SMP_Context Base; \
> + } SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name )
> + * @brief Defines a Arbitrary Processor Affinity Priority SMP Scheduler entry
> + * for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( name, obj_name ) \
> + &SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> + SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
> + SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Ready \
> + ) - 1, \
> + ( obj_name ) \
> #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
> #ifndef RTEMS_SMP
> #error "CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP cannot be used if RTEMS_SMP is disabled"
> @@ -257,26 +419,6 @@
> #include <rtems/score/schedulerpriorityaffinitysmp.h>
> - #define SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( priority_affinity_SMP_ ## name )
> - #define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( name, prio_count ) \
> - static struct { \
> - Scheduler_priority_SMP_Context Base; \
> - } SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( name, obj_name ) \
> - &SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> - SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
> - SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Ready \
> - ) - 1, \
> - ( obj_name ) \
> #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( name, prio_count ) \
> @@ -286,6 +428,54 @@
> #endif
> + * @brief Defines a Deterministic Priority SMP Scheduler context name based on
> + * the instantiation name.
> +#define SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( priority_SMP_ ## name )
> + * @brief Defines a Deterministic Priority SMP Scheduler instantiation.
> +#define RTEMS_SCHEDULER_PRIORITY_SMP( name, prio_count ) \
> + static struct { \
> + } SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name )
> + * @brief Defines a Deterministic Priority SMP Scheduler entry for the
> + * scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( name, obj_name ) \
> + &SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> + SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
> + SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Ready \
> + ) - 1, \
> + ( obj_name ) \
> #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
> #ifndef RTEMS_SMP
> #error "CONFIGURE_SCHEDULER_PRIORITY_SMP cannot be used if RTEMS_SMP is disabled"
> @@ -293,26 +483,6 @@
> #include <rtems/score/schedulerprioritysmp.h>
> - #define SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( priority_SMP_ ## name )
> - #define RTEMS_SCHEDULER_PRIORITY_SMP( name, prio_count ) \
> - static struct { \
> - } SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( name, obj_name ) \
> - &SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
> - SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
> - SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Ready \
> - ) - 1, \
> - ( obj_name ) \
> #define RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( name, prio_count ) \
> @@ -322,34 +492,59 @@
> #endif
> + * @brief Defines a Strong APA Scheduler context name based on the
> +#define SCHEDULER_STRONG_APA_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
> + * @brief Defines a Strong APA Scheduler instantiation.
> +#define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
> + static struct { \
> + Scheduler_strong_APA_Context Base; \
> + Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
> + } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
> + * @brief Defines a Strong APA Scheduler entry for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
> + &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
> + SCHEDULER_STRONG_APA_ENTRY_POINTS, \
> + SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
> + ( obj_name ) \
> #ifdef CONFIGURE_SCHEDULER_STRONG_APA
> #ifndef RTEMS_SMP
> #error "CONFIGURE_SCHEDULER_STRONG_APA cannot be used if RTEMS_SMP is disabled"
> #endif
> - #include <rtems/score/schedulerstrongapa.h>
> - #error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the Strong APA scheduler"
> + #error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the Strong APA Scheduler"
> #endif
> - #define SCHEDULER_STRONG_APA_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
> - #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
> - static struct { \
> - Scheduler_strong_APA_Context Base; \
> - Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
> - } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
> - &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
> - SCHEDULER_STRONG_APA_ENTRY_POINTS, \
> - SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
> - ( obj_name ) \
> + #include <rtems/score/schedulerstrongapa.h>
> @@ -360,24 +555,49 @@
> #endif
> -#ifdef CONFIGURE_SCHEDULER_SIMPLE
> - #include <rtems/score/schedulersimple.h>
> + * @brief Defines a Simple Scheduler context name based on the instantiation
> + * name.
> +#define SCHEDULER_SIMPLE_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( simple_ ## name )
> - #define SCHEDULER_SIMPLE_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( simple_ ## name )
> + * @brief Defines a Simple Scheduler instantiation.
> +#define RTEMS_SCHEDULER_SIMPLE( name ) \
> + static Scheduler_simple_Context \
> + SCHEDULER_SIMPLE_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_SIMPLE( name ) \
> - static Scheduler_simple_Context \
> - SCHEDULER_SIMPLE_CONTEXT_NAME( name )
> + * @brief Defines a Simple Scheduler entry for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_SIMPLE( name, obj_name ) \
> + &SCHEDULER_SIMPLE_CONTEXT_NAME( name ).Base, \
> + SCHEDULER_SIMPLE_ENTRY_POINTS, \
> + SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
> + ( obj_name ) \
> - #define RTEMS_SCHEDULER_TABLE_SIMPLE( name, obj_name ) \
> - &SCHEDULER_SIMPLE_CONTEXT_NAME( name ).Base, \
> - SCHEDULER_SIMPLE_ENTRY_POINTS, \
> - SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
> - ( obj_name ) \
> +#ifdef CONFIGURE_SCHEDULER_SIMPLE
> + #include <rtems/score/schedulersimple.h>
> @@ -388,6 +608,47 @@
> #endif
> + * @brief Defines a Simple SMP Scheduler context name based on the
> +#define SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ) \
> + SCHEDULER_CONTEXT_NAME( simple_SMP_ ## name )
> + * @brief Defines a Simple SMP Scheduler instantiation.
> +#define RTEMS_SCHEDULER_SIMPLE_SMP( name ) \
> + static Scheduler_simple_SMP_Context \
> + SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name )
> + * @brief Defines a Simple SMP Scheduler entry for the scheduler table.
> +#define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( name, obj_name ) \
> + &SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ).Base.Base, \
> + SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
> + SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
> + ( obj_name ) \
> #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
> #ifndef RTEMS_SMP
> #error "CONFIGURE_SCHEDULER_SIMPLE_SMP cannot be used if RTEMS_SMP is disabled"
> @@ -395,22 +656,6 @@
> #include <rtems/score/schedulersimplesmp.h>
> - #define SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ) \
> - SCHEDULER_CONTEXT_NAME( simple_SMP_ ## name )
> - #define RTEMS_SCHEDULER_SIMPLE_SMP( name ) \
> - static Scheduler_simple_SMP_Context \
> - SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name )
> - #define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( name, obj_name ) \
> - &SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ).Base.Base, \
> - SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
> - SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
> - ( obj_name ) \
> #define RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( name ) \
> 2.35.3
> devel mailing list
> devel at rtems.org
