[PATCH] bsps/microblaze: Add AXI GPIO driver
Alex White alex.white at oarcorp.com
Tue Feb 14 21:18:31 UTC 2023
 .../microblaze_fpga/gpio/microblaze-gpio.c    | 261 ++++++++++++++
 .../include/bsp/microblaze-gpio.h             | 321 ++++++++++++++++++
 .../bsps/microblaze/microblaze_fpga/grp.yml   |  18 +
 .../bsps/microblaze/microblaze_fpga/obj.yml   |   2 +
 .../microblaze_fpga/optgpio1baseaddress.yml   |  20 ++
 .../microblaze_fpga/optgpio1dualchannel.yml   |  17 +
 .../microblaze_fpga/optgpio1interrupt.yml     |  17 +
 .../microblaze_fpga/optgpio1irq.yml           |  19 ++
 .../microblaze_fpga/optgpio2baseaddress.yml   |  20 ++
 .../microblaze_fpga/optgpio2dualchannel.yml   |  17 +
 .../microblaze_fpga/optgpio2enable.yml        |  18 +
 .../microblaze_fpga/optgpio2interrupt.yml     |  17 +
 .../microblaze_fpga/optgpio2irq.yml           |  19 ++
 13 files changed, 766 insertions(+)
 create mode 100644 bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
 create mode 100644 bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
diff --git a/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c b/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
new file mode 100644
index 0000000000..9025840e32
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
@@ -0,0 +1,261 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroblaze
+ * @brief MicroBlaze AXI GPIO implementation
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#include <assert.h>
+#include <bsp/fatal.h>
+#include <bsp/microblaze-gpio.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+Microblaze_GPIO_context gpio1_context = {
+  .regs = (Microblaze_GPIO_registers *) BSP_MICROBLAZE_FPGA_GPIO1_BASE,
+#ifdef BSP_MICROBLAZE_FPGA_GPIO1_DUAL_CHANNEL
+  .is_dual = true,
+#else
+  .is_dual = false,
+#endif
+  .irq = BSP_MICROBLAZE_FPGA_GPIO1_IRQ,
+#ifdef BSP_MICROBLAZE_FPGA_GPIO1_INTERRUPT
+  .has_interrupts = true
+#else
+  .has_interrupts = false
+#endif
+#if BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
+Microblaze_GPIO_context gpio2_context = {
+  .regs = (Microblaze_GPIO_registers *) BSP_MICROBLAZE_FPGA_GPIO2_BASE,
+#ifdef BSP_MICROBLAZE_FPGA_GPIO2_DUAL_CHANNEL
+  .is_dual = true,
+#else
+  .is_dual = false,
+#endif
+  .irq = BSP_MICROBLAZE_FPGA_GPIO2_IRQ,
+#ifdef BSP_MICROBLAZE_FPGA_GPIO2_INTERRUPT
+#else
+#endif
+#endif
+void microblaze_gpio_set_data_direction(
+  Microblaze_GPIO_context *ctx,
+  uint32_t                 channel,
+  uint32_t                 mask
+  assert( channel == 1 || (ctx->is_dual && channel == 2) );
+  if ( channel == 1 ) {
+    ctx->regs->gpio_tri = mask;
+  } else if ( ctx->is_dual && channel == 2 ) {
+    ctx->regs->gpio2_tri = mask;
+uint32_t microblaze_gpio_get_data_direction(
+  uint32_t                 channel
+    return ctx->regs->gpio_tri;
+    return ctx->regs->gpio2_tri;
+  return 0;
+uint32_t microblaze_gpio_discrete_read(
+  uint32_t                 channel
+    return ctx->regs->gpio_data;
+  return 0;
+void microblaze_gpio_discrete_write(
+  uint32_t                 channel,
+  uint32_t                 mask
+    ctx->regs->gpio_data = mask;
+void microblaze_gpio_discrete_set(
+  uint32_t                 channel,
+  uint32_t                 mask
+    ctx->regs->gpio_data |= mask;
+    ctx->regs->gpio2_tri |= mask;
+void microblaze_gpio_discrete_clear(
+  uint32_t                 channel,
+  uint32_t                 mask
+    ctx->regs->gpio_data &= ~mask;
+    ctx->regs->gpio2_tri &= ~mask;
+rtems_vector_number microblaze_gpio_get_irq( Microblaze_GPIO_context *ctx )
+  return ctx->irq;
+void microblaze_gpio_interrupt_global_enable( Microblaze_GPIO_context *ctx )
+  assert( ctx->has_interrupts );
+  if ( ctx->has_interrupts ) {
+    ctx->regs->gier = GLOBAL_INTERRUPT_REGISTER_ENABLE;
+void microblaze_gpio_interrupt_global_disable( Microblaze_GPIO_context *ctx )
+    ctx->regs->gier = 0x0;
+void microblaze_gpio_interrupt_enable(
+  uint32_t                 channel
+      ctx->regs->ip_ier |= CHANNEL_1_INTERRUPT_REGISTER;
+      ctx->regs->ip_ier |= CHANNEL_2_INTERRUPT_REGISTER;
+void microblaze_gpio_interrupt_disable(
+  uint32_t                 channel
+    ctx->regs->ip_ier &= ~CHANNEL_1_INTERRUPT_REGISTER;
+    ctx->regs->ip_ier &= ~CHANNEL_2_INTERRUPT_REGISTER;
+void microblaze_gpio_interrupt_clear(
+  uint32_t                 channel
+    ctx->regs->ip_isr &= CHANNEL_1_INTERRUPT_REGISTER;
+    ctx->regs->ip_isr &= CHANNEL_2_INTERRUPT_REGISTER;
+uint32_t microblaze_gpio_interrupt_get_enabled( Microblaze_GPIO_context *ctx )
+    return ctx->regs->ip_ier;
+  return 0;
+uint32_t microblaze_gpio_interrupt_get_status( Microblaze_GPIO_context *ctx )
+    return ctx->regs->ip_isr;
+  return 0;
+#ifdef __cplusplus
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h b/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
index 0000000000..5fe9c44cf8
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
@@ -0,0 +1,321 @@
+ * @file
+ * @brief MicroBlaze AXI GPIO definitions
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_FPGA_MICROBLAZE_GPIO_H
+#define LIBBSP_MICROBLAZE_FPGA_MICROBLAZE_GPIO_H
+#include <bspopts.h>
+#include <bsp/utility.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+typedef struct {
+  /* Channel 1 data values */
+   * Used to read general purpose input ports and write to general purpose
+   * output ports from channel 1.
+  volatile uint32_t gpio_data;
+   * The 3-state control register for channel 1 is used for the dynamic
+   * configuration of ports as input or output. When a bit is set to 1, the
+   * corresponding I/O port is an input port. When a bit is set to 0, it is an
+   * output port.
+  volatile uint32_t gpio_tri;
+  /* Channel 2 data values */
+   * output ports from channel 2.
+  volatile uint32_t gpio2_data;
+   * The 3-state control register for channel 2 is used for the dynamic
+   * output port.
+  volatile uint32_t gpio2_tri;
+  char _unused[272];
+  /* Only the 31st bit is used to enable interrupts globally */
+#define GLOBAL_INTERRUPT_REGISTER_ENABLE BSP_BIT32(31)
+   * Global Interrupt Enable Register
+   * Determines whether interrupts are enabled or disabled.
+   * 0 - Disabled
+   * 1 - Enabled
+  volatile uint32_t gier;
+  char _unused2[12];
+  /* Used with ip_isr and ip_ier member variables */
+#define CHANNEL_1_INTERRUPT_REGISTER BSP_BIT32(0)
+#define CHANNEL_2_INTERRUPT_REGISTER BSP_BIT32(1)
+   * IP Status Registers
+   * Contains the status bit for each channel.
+   * 0 - Disabled
+   * 1 - Enabled
+  volatile uint32_t ip_isr;
+  char _unused3[4];
+   * IP Interrupt Enable Register
+   * Provides the ability to independtly control whether interrupts for each
+   * channel are enabled or disabled.
+   * 0 - No Channel input interrupt
+   * 1 - Channel input interrupt
+  volatile uint32_t ip_ier;
+} Microblaze_GPIO_registers;
+typedef struct {
+  Microblaze_GPIO_registers *regs;
+  bool                       is_dual;
+  uint32_t                   irq;
+  bool                       has_interrupts;
+} Microblaze_GPIO_context;
+extern Microblaze_GPIO_context gpio1_context;
+#ifdef BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
+extern Microblaze_GPIO_context gpio2_context;
+#endif
+#define gpio1 ((Microblaze_GPIO_context * const) &gpio1_context)
+#define gpio2 ((Microblaze_GPIO_context * const) &gpio2_context)
+#endif
+ * @brief Set pin configuration for the specified GPIO channel.
+ * Changes the pin configuration for a channel. Bits set to 0 are output, and
+ * bits set to 1 are input.
+ * @param[in] ctx the GPIO context
+ * @param[in] channel the GPIO channel
+ * @param[in] mask the mask to be applied to @ channel
+ * @retval None
+  uint32_t                 channel,
+  uint32_t                 mask
+ * @brief Get pin configuration for specified GPIO channel.
+ * Gets the current pin configuration for a specified GPIO channel. Bits set to
+ * 0 are output, and bits set to 1 are input.
+ * @retval bitmask specifiying which pins on a channel are input or output
+  uint32_t                 channel
+ * @brief Reads data for specified GPIO channel.
+ * @retval Current values in discretes register.
+  uint32_t                 channel
+ * @brief Writes to data register for specified GPIO channel.
+ * @retval None
+  uint32_t                 channel,
+  uint32_t                 mask
+ * @brief Set bits to 1 on specified GPIO channel.
+ * @retval None
+  uint32_t                 channel,
+  uint32_t                 mask
+ * @brief Set bits to 0 on specified GPIO channel.
+ * @retval None
+  uint32_t                 channel,
+  uint32_t                 mask
+ * @brief Returns the vector number of the interrupt handler.
+ * @retval the vector number
+rtems_vector_number microblaze_gpio_get_irq( Microblaze_GPIO_context *ctx );
+ * @brief Turns on interrupts globally.
+ * @retval None
+void microblaze_gpio_interrupt_global_enable( Microblaze_GPIO_context *ctx );
+ * @brief Turns off interrupts globally.
+ * @retval None
+void microblaze_gpio_interrupt_global_disable( Microblaze_GPIO_context *ctx );
+ * @brief Enables interrupts on specified channel
+ * @param[in] channel the channel to enable interrupts on
+ * @retval None
+  uint32_t                 channel
+ * @brief Disables interrupts on specified channel
+ * @param[in] channel the channel to turn interrupts on for
+ * @retval None
+  uint32_t                 channel
+ * @brief Clear status of interrupt signals on a specific channel
+ * @param[in] channel the channel to clear the interrupt pending status from
+ * @retval None
+  uint32_t                 channel
+ * @brief Return a bitmask of the interrupts that are enabled
+ * @retval the bitmask of enabled interrupts
+uint32_t microblaze_gpio_interrupt_get_enabled( Microblaze_GPIO_context *ctx );
+ * @brief Return a bitmask of the status of the interrupt signals
+ * @retval bitmask containing statuses of interrupt signals
+uint32_t microblaze_gpio_interrupt_get_status( Microblaze_GPIO_context *ctx );
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_FPGA_MICROBLAZE_GPIO_H */
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index f3088a68a3..4d1ac0f426 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -28,6 +28,24 @@ links:
   uid: optdcachesize
 - role: build-dependency
   uid: optdtbheaderpath
+- role: build-dependency
+  uid: optgpio2enable
+  uid: optgpio1baseaddress
+  uid: optgpio2baseaddress
+  uid: optgpio1dualchannel
+  uid: optgpio2dualchannel
+  uid: optgpio1irq
+  uid: optgpio2irq
+  uid: optgpio1interrupt
+  uid: optgpio2interrupt
   uid: opticachebaseaddress
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 2bbe50d3d9..487a99aae9 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -15,6 +15,7 @@ install:
   source:
   - bsps/microblaze/microblaze_fpga/include/bsp/irq.h
   - bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
+  - bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
   - bsps/microblaze/include/bsp/microblaze-fdt-support.h
   - bsps/microblaze/include/common/xil_types.h
   - bsps/microblaze/include/dev/serial/uartlite.h
@@ -25,6 +26,7 @@ source:
 - bsps/microblaze/microblaze_fpga/console/console-io.c
 - bsps/microblaze/microblaze_fpga/console/debug-io.c
 - bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
+- bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
 - bsps/microblaze/microblaze_fpga/irq/irq.c
 - bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
 - bsps/microblaze/microblaze_fpga/start/_exception_handler.S
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
index 0000000000..f525b0468b
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+default:
+- enabled-by: true
+  value: 0x40000000
+default-by-variant: []
+description: |
+  base address of GPIO 1
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO1_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
index 0000000000..c8810e2a9a
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
@@ -0,0 +1,17 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  GPIO 1 is dual channel
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO1_DUAL_CHANNEL
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
index 0000000000..59df9b1bce
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
@@ -0,0 +1,17 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  GPIO 1 has interrupt
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO1_INTERRUPT
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
index 0000000000..69e3c5d2d5
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
@@ -0,0 +1,19 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 8
+description: |
+  the IRQ number of GPIO 1
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO1_IRQ
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
index 0000000000..2da5cd722e
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
@@ -0,0 +1,20 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x40010000
+description: |
+  base address of GPIO 2
+enabled-by: BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO2_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
index 0000000000..c6d4819d8c
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
@@ -0,0 +1,17 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: false
+description: |
+  GPIO 2 is dual channel
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO2_DUAL_CHANNEL
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
index 0000000000..65e9be167e
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
@@ -0,0 +1,18 @@
+actions:
+- env-enable: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: false
+description: |
+  GPIO 2 is enabled
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
index 0000000000..de579426d2
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
@@ -0,0 +1,17 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  GPIO 2 has interrupt
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO2_INTERRUPT
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
index 0000000000..18b64f3680
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
@@ -0,0 +1,19 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 9
+description: |
+  the IRQ number of GPIO 2
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_GPIO2_IRQ
+type: build
2.34.1
