updating to gdb 12.1 was Re: RFC Add --disable-werror to gdb, etc
Chris Johns
chrisj at rtems.org
Thu Feb 16 00:54:55 UTC 2023
On 16/2/2023 11:43 am, Joel Sherrill wrote:
> The same issue is in gdb 12.1 and is still present in the gdb master.
> I have fixed this locally and will create a patch.
> Any thoughts on me updating to gdb 12.1 at the same time?
I am ok with a GDB update. It is a host support tool and so the bar is lower
than the compiler which is generating target code.
