[PATCH rtems-source-builder 1/2] rtems-gdb-11.2.cfg: Add patch for hosts with readline 8.2
Joel Sherrill
joel at rtems.org
Thu Feb 16 22:56:48 UTC 2023
Get the fix from gdb git repo to fix build issue which showed
up on Cygwin but was cross platform.
Closes #4858.
rtems/config/tools/rtems-gdb-11.2.cfg | 3 +++
1 file changed, 3 insertions(+)
diff --git a/rtems/config/tools/rtems-gdb-11.2.cfg b/rtems/config/tools/rtems-gdb-11.2.cfg
index 31385e7..59dd402 100644
--- a/rtems/config/tools/rtems-gdb-11.2.cfg
+++ b/rtems/config/tools/rtems-gdb-11.2.cfg
@@ -9,4 +9,7 @@
%define gdb_src_ext xz
%hash sha512 gdb-%{gdb_version}.tar.xz 07e9026423438049b11f4f784d57401ece4e940570f613bd6958b3714fe7fbc2c048470bcce3e7d7d9f93331cdf3881d30dcc964cb113a071143a02b28e5b127
+%patch add gdb --rsb-file=gdb-readline8.2.patch https://sourceware.org/git/?p=binutils-gdb.git;a=commitdiff_plain;h=1add37b567a7dee39d99f37b37802034c3fce9c4
+%hash sha512 gdb-readline8.2.patch E/nGalfBBfn0rl/pi1SGIuKD11x0qREZBp3ajaFbl/nGMZUIm31M/1z0FsG76K7IjvE5pPsl2JqESt+LBN9lZA==
%include %{_configdir}/gdb-common-1.cfg
2.24.4
