GSoC project suggestion for the BSP Raspberry pi 4B aarch64
Noor Aman
nooraman5718 at gmail.com
Sun Feb 19 13:44:18 UTC 2023
I booted freeBSD on the Raspberry pi, I was able to confirm that it used
genet driver together with miibus for the NIC. This is further confirmed
with the FreeBSD manual page.
https://man.freebsd.org/cgi/man.cgi?query=genet
One more thing to follow is that i noticed that FreeBSD is using PSCI, so
I'm assuming that it is being used for SMP. I'll file a ticket as soon as
I'm able to grab more information.
Here are the full dmesg log of Raspberry pi 4B booting FreeBSD 13.2
WARNING: Cannot find freebsd,dts-version property, cannot check DTB
> compliance
> Copyright (c) 1992-2021 The FreeBSD Project.
> Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
> The Regents of the University of California. All rights reserved.
> FreeBSD is a registered trademark of The FreeBSD Foundation.
> FreeBSD 13.2-BETA2 releng/13.2-n254478-065f7854521d GENERIC arm64
> FreeBSD clang version 14.0.5 (https://github.com/llvm/llvm-project.git
> llvmorg-14.0.5-0-gc12386ae247c)
> VT(efifb): resolution 592x448
> module firmware already present!
> real memory = 4148158464 (3955 MB)
> avail memory = 4022452224 (3836 MB)
> Starting CPU 1 (1)
> Starting CPU 2 (2)
> Starting CPU 3 (3)
> FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
> random: unblocking device.
> random: entropy device external interface
> MAP 39f2b000 mode 2 pages 1
> MAP 39f2f000 mode 2 pages 1
> MAP 39f31000 mode 2 pages 2
> MAP 39f34000 mode 2 pages 4
> MAP 3b350000 mode 2 pages 16
> MAP fe100000 mode 0 pages 1
> kbd0 at kbdmux0
> ofwbus0: <Open Firmware Device Tree>
> simplebus0: <Flattened device tree simple bus> on ofwbus0
> ofw_clkbus0: <OFW clocks bus> on ofwbus0
> clk_fixed0: <Fixed clock> on ofw_clkbus0
> clk_fixed1: <Fixed clock> on ofw_clkbus0
> clk_fixed2: <Fixed clock> on ofwbus0
> clk_fixed3: <Fixed clock> on ofwbus0
> simplebus1: <Flattened device tree simple bus> on ofwbus0
> simplebus2: <Flattened device tree simple bus> on ofwbus0
> regfix0: <Fixed Regulator> on ofwbus0
> regfix1: <Fixed Regulator> on ofwbus0
> regfix2: <Fixed Regulator> on ofwbus0
> simplebus3: <Flattened device tree simple bus> on ofwbus0
> simple_mfd0: <Simple MFD (Multi-Functions Device)> mem
> 0x7d5d2000-0x7d5d2eff on simplebus0
> bcm2835_firmware0: <BCM2835 Firmware> on simplebus0
> ofw_clkbus1: <OFW clocks bus> on bcm2835_firmware0
> psci0: <ARM Power State Co-ordination Interface Driver> on ofwbus0
> gic0: <ARM Generic Interrupt Controller> mem
> 0x40041000-0x40041fff,0x40042000-0x40043fff,0x40044000-0x40045fff,0x40046000-0x40047fff
> irq 30 on simplebus0
> gic0: pn 0x2, arch 0x2, rev 0x1, implementer 0x43b irqs 256
> gpio0: <BCM2708/2835 GPIO controller> mem 0x7e200000-0x7e2000b3 irq 14,15
> on simplebus0
> gpiobus0: <OFW GPIO bus> on gpio0
> gpio1: <Raspberry Pi Firmware GPIO controller> on bcm2835_firmware0
> gpiobus1: <GPIO bus> on gpio1
> regfix0: Cannot set GPIO pin: 6
> REGNODE_INIT failed: 6
> regfix0: Cannot register regulator.
> mbox0: <BCM2835 VideoCore Mailbox> mem 0x7e00b880-0x7e00b8bf irq 13 on
> simplebus0
> gpioregulator0: <GPIO controlled regulator> on ofwbus0
> generic_timer0: <ARMv8 Generic Timer> irq 4,5,6,7 on ofwbus0
> Timecounter "ARM MPCore Timecounter" frequency 54000000 Hz quality 1000
> Event timer "ARM MPCore Eventtimer" frequency 54000000 Hz quality 1000
> usb_nop_xceiv0: <USB NOP PHY> on ofwbus0
> bcm2835_clkman0: <BCM283x Clock Manager> mem 0x7e101000-0x7e102fff on
> simplebus0
> gpioc0: <GPIO controller> on gpio0
> uart0: <PrimeCell UART (PL011)> mem 0x7e201000-0x7e2011ff irq 16 on
> simplebus0
> uart0: console (115200,n,8,1)
> spi0: <BCM2708/2835 SPI controller> mem 0x7e204000-0x7e2041ff irq 18 on
> simplebus0
> spibus0: <OFW SPI bus> on spi0
> spibus0: <unknown card> at cs 0 mode 0
> spibus0: <unknown card> at cs 1 mode 0
> iichb0: <BCM2708/2835 BSC controller> mem 0x7e804000-0x7e804fff irq 26 on
> simplebus0
> bcm_dma0: <BCM2835 DMA Controller> mem 0x7e007000-0x7e007aff irq
> 31,32,33,34,35,36,37,38,39,40,41 on simplebus0
> bcmwd0: <BCM2708/2835 Watchdog> mem
> 0x7e100000-0x7e100113,0x7e00a000-0x7e00a023,0x7ec11000-0x7ec1101f on
> simplebus0
> bcmrng0: <Broadcom BCM2835/BCM2838 RNG> mem 0x7e104000-0x7e104027 on
> simplebus0
> gpioc1: <GPIO controller> on gpio1
> sdhci_bcm0: <Broadcom 2708 SDHCI controller> mem 0x7e300000-0x7e3000ff irq
> 73 on simplebus0
> mmc0: <MMC/SD bus> on sdhci_bcm0
> fb0: <BCM2835 VT framebuffer driver> on simplebus0
> fb0: keeping existing fb bpp of 32
> fbd0 on fb0
> WARNING: Device "fb" is Giant locked and may be deleted before FreeBSD
> 14.0.
> VT: Replacing driver "efifb" with new "fb".
> fb0: 592x448(592x448 at 0,0) 32bpp
> fb0: fbswap: 1, pitch 2368, base 0x3eaf5000, screen_size 1060864
> sdhci_bcm1: <Broadcom 2708 SDHCI controller> mem 0x7e340000-0x7e3400ff irq
> 79 on simplebus1
> mmc1: <MMC/SD bus> on sdhci_bcm1
> pmu0: <Performance Monitoring Unit> irq 0,1,2,3 on ofwbus0
> cpulist0: <Open Firmware CPU Group> on ofwbus0
> cpu0: <Open Firmware CPU> on cpulist0
> bcm2835_cpufreq0: <CPU Frequency Control> on cpu0
> cpu1: <Open Firmware CPU> on cpulist0
> cpu2: <Open Firmware CPU> on cpulist0
> cpu3: <Open Firmware CPU> on cpulist0
> pcib0: <BCM2838-compatible PCI-express controller> mem
> 0x7d500000-0x7d50930f irq 80,81 on simplebus2
> pcib0: hardware identifies as revision 0x304.
> pci1: <PCI bus> on pcib0
> pcib1: <PCI-PCI bridge> irq 91 at device 0.0 on pci1
> pci2: <PCI bus> on pcib1
> bcm_xhci0: <VL805 USB 3.0 controller (on the Raspberry Pi 4b)> irq 92 at
> device 0.0 on pci2
> bcm_xhci0: 32 bytes context size, 64-bit DMA
> usbus0 on bcm_xhci0
> pci0: <PCI bus> on pcib0
> pci0: failed to allocate bus number
> device_attach: pci0 attach returned 6
> genet0: <RPi4 Gigabit Ethernet> mem 0x7d580000-0x7d58ffff irq 82,83 on
> simplebus2
> genet0: GENET version 5.0 phy 0x0000
> miibus0: <MII bus> on genet0
> brgphy0: <BCM54213PE 1000BASE-T media interface> PHY 1 on miibus0
> brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT,
> 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto
> genet0: Ethernet address: e4:5f:01:62:6c:5b
> gpioled0: <GPIO LEDs> on ofwbus0
> armv8crypto0: CPU lacks AES instructions
> Timecounters tick every 1.000 msec
> [nl_generic] genl_register_family: Registered family nlctrl id 16
> [nl_generic] genl_register_cmds: Adding cmd GETFAMILY(3) to family nlctrl
> usbus0: 5.0Gbps Super Speed USB v3.0
> iicbus0: <OFW I2C bus> on iichb0
> iic0: <I2C generic I/O> on iicbus0
> ugen0.1: <(0x1106) XHCI root HUB> at usbus0
> uhub0 on usbus0
> uhub0: <(0x1106) XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
> sdhci_bcm0-slot0: Got command interrupt 0x00030000, but there is no active
> command.
> sdhci_bcm0-slot0: ============== REGISTER DUMP ==============
> sdhci_bcm0-slot0: Sys addr: 0x00000000 | Version: 0x00009902
> sdhci_bcm0-slot0: Blk size: 0x00000000 | Blk cnt: 0x00000000
> sdhci_bcm0-slot0: Argument: 0x000001aa | Trn mode: 0x00000000
> sdhci_bcm0-slot0: Present: 0x000f0000 | Host ctl: 0x00000001
> sdhci_bcm0-slot0: Power: 0x0000000f | Blk gap: 0x00000000
> sdhci_bcm0-slot0: Wake-up: 0x00000000 | Clock: 0x00003947
> sdhci_bcm0-slot0: Timeout: 0x00000000 | Int stat: 0x00000000
> sdhci_bcm0-slot0: Int enab: 0x01ff00bb | Sig enab: 0x01ff00bb
> sdhci_bcm0-slot0: AC12 err: 0x00000000 | Host ctl2:0x00000000
> sdhci_bcm0-slot0: Caps: 0x00000000 | Caps2: 0x00000000
> sdhci_bcm0-slot0: Max curr: 0x00000001 | ADMA err: 0x00000000
> sdhci_bcm0-slot0: ADMA addr:0x00000000 | Slot int: 0x00000000
> sdhci_bcm0-slot0: ===========================================
> command.
> command.
> command.
> command.
> sdhci_bcm0-slot0: Argument: 0x00000000 | Trn mode: 0x00000000
> command.
> command.
> command.
> uhub0: 5 ports with 4 removable, self powered
> mmc0: No compatible cards found on bus
> mmcsd0: 32GB <SDHC SS32G 8.0 SN 618C22B0 MFG 01/2022 by 3 SD> at mmc1
> 50.0MHz/4bit/65535-block
> bcm2835_cpufreq0: ARM 600MHz, Core 200MHz, SDRAM 400MHz, Turbo OFF
> CPU 0: ARM Cortex-A72 r0p3 affinity: 0
> Cache Type = <64 byte D-cacheline,64 byte
> I-cacheline,PIPT ICache,64 byte ERG,64 byte CWG>
> Trying to mount root from ufs:/dev/ufs/rootfs [rw]...
> Instruction Set Attributes 0 = <CRC32>
> Instruction Set Attributes 1 = <>
> Instruction Set Attributes 2 = <>
> Processor Features 0 = <AdvSIMD,FP,EL3 32,EL2 32,EL1 32,EL0 32>
> Processor Features 1 = <>
> Memory Model Features 0 = <TGran4,TGran64,SNSMem,BigEnd,16bit
> ASID,16TB PA>
> Memory Model Features 1 = <8bit VMID>
> Memory Model Features 2 = <32bit CCIDX,48bit VA>
> Debug Features 0 = <DoubleLock,2 CTX BKPTs,4 Watchpoints,6
> Breakpoints,PMUv3,Debugv8>
> Debug Features 1 = <>
> Auxiliary Features 0 = <>
> Auxiliary Features 1 = <>
> AArch32 Instruction Set Attributes 5 = <CRC32,SEVL>
> AArch32 Media and VFP Features 0 = <FPRound,FPSqrt,FPDivide,DP VFPv3+v4,SP
> VFPv3+v4,AdvSIMD>
> AArch32 Media and VFP Features 1 = <SIMDFMAC,FPHP DP Conv,SIMDHP SP
> Conv,SIMDSP,SIMDInt,SIMDLS,FPDNaN,FPFtZ>
> CPU 1: ARM Cortex-A72 r0p3 affinity: 1
> CPU 2: ARM Cortex-A72 r0p3 affinity: 2
> CPU 3: ARM Cortex-A72 r0p3 affinity: 3
> Release APs...done
> WARNING: / was not properly dismounted
> Warning: no time-of-day clock registered, system time will not be set
> accurately
> Dual Console: Serial Primary, Video Secondary
> ugen0.2: <vendor 0x2109 USB2.0 Hub> at usbus0
> uhub1 on uhub0
> uhub1: <vendor 0x2109 USB2.0 Hub, class 9/0, rev 2.10/4.21, addr 1> on
> usbus0
> uhub1: 4 ports with 4 removable, self powered
> lo0: link state changed to UP
> genet0: link state changed to DOWN
> genet0: link state changed to UP
On Sun, 19 Feb 2023 at 02:24, Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Feb 18, 2023 at 11:09 AM Noor Aman <nooraman5718 at gmail.com> wrote:
>> Hey everyone,
>> Last year I helped with the porting of RTEMS-aarch64 for Raspberry Pi 4B
>> with Kinsey, Alan and Hesham. I'm looking forward to continuing my project
>> further. As of now, I have 2 projects in my mind.
> Every GSoC project should have a ticket. I found this one for the lower
> model Pis but not one for the Pi4
> https://devel.rtems.org/ticket/2899
> Can you file a ticket like that for the Pi4 with these ideas?
>> 1. Bringing in multicore support for the BSP.
>> This can be achieved by one of the 2 methods which I know as of now.
>> - By using PSCI via TF-A (Currently implemented in Zync MPSoC).
>> - By adding support directly to the start.S file.
>> 2. Add Ethernet support for the BSP
>> - This can be done by importing the Genet driver which is used by freeBSD
>> for the board. ( https://man.freebsd.org/cgi/man.cgi?query=genet )
>> - This is all I know as of now about this idea.
>> To be honest, I'm not that very familiar with either RTEMS-libbsd or
>> TF-A. I did try to use libbsd with RPi4B. Some of the exe ran fine, like
>> crypto01 and openssl, but I dont have the exact idea about the rest of the
>> testsuites. I'm open to any further ideas. Your suggestions are most
>> welcome.
> Did you manage to get anything using device drivers from libbsd working on
> the Pi4?
> I don't see it listed in include/bsp/nexus-devices.h: which is where the
> devices used
> would be listed. FWIW I also don't see any arm/Pi configurations either. I
> could be
> missing something though.
> A first step would be to identify which NIC driver is used for the Pi4 on
> FreeBSD. This
> should help:
> https://wiki.freebsd.org/arm/Raspberry%20Pi
> Booting FreeBSD on the Pi4 would give you a boot log which should show a
> lot
> of the details about what needs to be configured.
> --joel
>> Thank you. Regards
>> Mohd Noor Aman
>> Tinkering with Hardware
>> devel mailing list
>> devel at rtems.org
Mohd Noor Aman
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230219/8909b7cf/attachment-0001.htm>
