[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao Begari
padmarao.begari at microchip.com
Mon Feb 27 15:51:30 UTC 2023
The interrupt complete should clear with the interrupt
number before disabling the interrupt in the PLIC to
get the next interrupt.
bsps/riscv/riscv/irq/irq.c | 4 ++++
1 file changed, 4 insertions(+)
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index e8d297052b..8e72bd8da5 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -585,6 +585,8 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
#ifdef RTEMS_SMP
if (enable != NULL) {
+ cpu = _Per_CPU_Get_by_index(_CPU_SMP_Get_current_processor());
+ cpu->cpu_per_cpu.plic_hart_regs->claim_complete = interrupt_index
enable[group] &= ~bit;
} else {
uint32_t cpu_max;
@@ -595,6 +597,7 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
for (cpu_index = 0; cpu_index < cpu_max; ++cpu_index) {
cpu = _Per_CPU_Get_by_index(cpu_index);
enable = cpu->cpu_per_cpu.plic_m_ie;
@@ -603,6 +606,7 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
#else
cpu = _Per_CPU_Get_by_index(0);
cpu->cpu_per_cpu.plic_m_ie[group] &= ~bit;
#endif
2.25.1
