[PATCH 2/2] RISC-V: Test rv32i and rv32imafdc on QEMU
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Mon Jan 9 18:28:09 UTC 2023
Is this patchset fine to merge?
On Fri, 23 Dec 2022 at 09:25, <heshamelmatary at gmail.com> wrote:
> From: Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
> Updates #4775
>  tester/rtems/testing/bsps/rv32i.ini      | 37 ++++++++++++++++++++++++
>  tester/rtems/testing/bsps/rv32imafdc.ini | 37 ++++++++++++++++++++++++
>  2 files changed, 74 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/rv32i.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32imafdc.ini
> diff --git a/tester/rtems/testing/bsps/rv32i.ini b/tester/rtems/testing/bsps/rv32i.ini
> new file mode 100644
> index 0000000..1817216
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/rv32i.ini
> @@ -0,0 +1,37 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2020 Hesham Almatary
> +# Copyright 2018 embedded brains GmbH
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +[rv32i]
> +bsp           = rv32i
> +arch          = riscv32
> +tester        = %{_rtscripts}/qemu.cfg
> +bsp_qemu_image_type = -bios
> +bsp_qemu_opts = -no-reboot -nographic %{qemu_opts_no_net} -machine virt -m 128M
> diff --git a/tester/rtems/testing/bsps/rv32imafdc.ini b/tester/rtems/testing/bsps/rv32imafdc.ini
> index 0000000..2f91a9a
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/rv32imafdc.ini
> @@ -0,0 +1,37 @@
> +[rv32imafdc]
> +bsp           = rv32imafdc
> +arch          = riscv32
> 2.25.1
