[PATCH 02/18] jffs2: Fix if/else empty body warnings
Wed Jan 11 11:58:36 UTC 2023
When debug (print) macros are not enabled, change them to use the
no_printk() macro instead of <nothing>. This fixes gcc warnings when
-Wextra is used:
../cpukit/libfs/src/jffs2/src/nodelist.c:255:37: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:278:38: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:558:52: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1247:58: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1281:65: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
Builds without warnings on all 3 levels of CONFIG_JFFS2_FS_DEBUG.
Signed-off-by: Randy Dunlap <rdunlap at infradead.org>
Cc: David Woodhouse <dwmw2 at infradead.org>
Cc: Richard Weinberger <richard at nod.at>
Cc: linux-mtd at lists.infradead.org
Signed-off-by: Richard Weinberger <richard at nod.at>
 cpukit/libfs/src/jffs2/src/debug.h | 23 ++++++++++++-----------
 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/debug.h b/cpukit/libfs/src/jffs2/src/debug.h
index 6c905b3854..6b4afd4e75 100644
--- a/cpukit/libfs/src/jffs2/src/debug.h
+++ b/cpukit/libfs/src/jffs2/src/debug.h
@@ -13,6 +13,7 @@
 #ifndef _JFFS2_DEBUG_H_
 #define _JFFS2_DEBUG_H_
+#include <linux/printk.h>
 #include <linux/sched.h>
 #ifndef CONFIG_JFFS2_FS_DEBUG
@@ -117,73 +118,73 @@ do {						\
 #ifdef JFFS2_DBG_READINODE_MESSAGES
 #define dbg_readinode(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_readinode(fmt, ...)
+#define dbg_readinode(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 #ifdef JFFS2_DBG_READINODE2_MESSAGES
 #define dbg_readinode2(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_readinode2(fmt, ...)
+#define dbg_readinode2(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Fragtree build debugging messages */
 #ifdef JFFS2_DBG_FRAGTREE_MESSAGES
 #define dbg_fragtree(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_fragtree(fmt, ...)
+#define dbg_fragtree(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 #ifdef JFFS2_DBG_FRAGTREE2_MESSAGES
 #define dbg_fragtree2(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_fragtree2(fmt, ...)
+#define dbg_fragtree2(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Directory entry list manilulation debugging messages */
 #ifdef JFFS2_DBG_DENTLIST_MESSAGES
 #define dbg_dentlist(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_dentlist(fmt, ...)
+#define dbg_dentlist(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Print the messages about manipulating node_refs */
 #ifdef JFFS2_DBG_NODEREF_MESSAGES
 #define dbg_noderef(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_noderef(fmt, ...)
+#define dbg_noderef(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Manipulations with the list of inodes (JFFS2 inocache) */
 #ifdef JFFS2_DBG_INOCACHE_MESSAGES
 #define dbg_inocache(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_inocache(fmt, ...)
+#define dbg_inocache(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Summary debugging messages */
 #ifdef JFFS2_DBG_SUMMARY_MESSAGES
 #define dbg_summary(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_summary(fmt, ...)
+#define dbg_summary(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* File system build messages */
 #ifdef JFFS2_DBG_FSBUILD_MESSAGES
 #define dbg_fsbuild(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_fsbuild(fmt, ...)
+#define dbg_fsbuild(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Watch the object allocations */
 #ifdef JFFS2_DBG_MEMALLOC_MESSAGES
 #define dbg_memalloc(fmt, ...)	JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_memalloc(fmt, ...)
+#define dbg_memalloc(fmt, ...)	no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* Watch the XATTR subsystem */
 #ifdef JFFS2_DBG_XATTR_MESSAGES
 #define dbg_xattr(fmt, ...)  JFFS2_DEBUG(fmt, ##__VA_ARGS__)
 #else
-#define dbg_xattr(fmt, ...)
+#define dbg_xattr(fmt, ...)  no_printk(fmt, ##__VA_ARGS__)
 #endif
 /* "Sanity" checks */
2.35.3
