[PATCH 09/18] jffs2: avoid Wempty-body warnings
Wed Jan 11 11:58:43 UTC 2023
Building with W=1 shows a few warnings for empty macros:
fs/jffs2/scan.c: In function 'jffs2_scan_xattr_node':
fs/jffs2/scan.c:378:66: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
  378 |                 jffs2_sum_add_xattr_mem(s, rx, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_xref_node':
fs/jffs2/scan.c:434:65: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
  434 |                 jffs2_sum_add_xref_mem(s, rr, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_eraseblock':
fs/jffs2/scan.c:893:88: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
  893 |                                 jffs2_sum_add_padding_mem(s, je32_to_cpu(node->totlen));
Change all these macros to 'do { } while (0)' statements to avoid the
warnings and make the code a little more robust.
Signed-off-by: Arnd Bergmann <arnd at arndb.de>
Signed-off-by: Richard Weinberger <richard at nod.at>
 cpukit/libfs/src/jffs2/src/summary.h | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/summary.h b/cpukit/libfs/src/jffs2/src/summary.h
index e4131cb1f1..36d9a12807 100644
--- a/cpukit/libfs/src/jffs2/src/summary.h
+++ b/cpukit/libfs/src/jffs2/src/summary.h
@@ -194,18 +194,18 @@ int jffs2_sum_scan_sumnode(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb
 #define jffs2_sum_active() (0)
 #define jffs2_sum_init(a) (0)
-#define jffs2_sum_exit(a)
+#define jffs2_sum_exit(a) do { } while (0)
 #define jffs2_sum_disable_collecting(a)
 #define jffs2_sum_is_disabled(a) (0)
-#define jffs2_sum_reset_collected(a)
+#define jffs2_sum_reset_collected(a) do { } while (0)
 #define jffs2_sum_add_kvec(a,b,c,d) (0)
-#define jffs2_sum_move_collected(a,b)
+#define jffs2_sum_move_collected(a,b) do { } while (0)
 #define jffs2_sum_write_sumnode(a) (0)
-#define jffs2_sum_add_padding_mem(a,b)
-#define jffs2_sum_add_inode_mem(a,b,c)
-#define jffs2_sum_add_dirent_mem(a,b,c)
-#define jffs2_sum_add_xattr_mem(a,b,c)
-#define jffs2_sum_add_xref_mem(a,b,c)
+#define jffs2_sum_add_padding_mem(a,b) do { } while (0)
+#define jffs2_sum_add_inode_mem(a,b,c) do { } while (0)
+#define jffs2_sum_add_dirent_mem(a,b,c) do { } while (0)
+#define jffs2_sum_add_xattr_mem(a,b,c) do { } while (0)
+#define jffs2_sum_add_xref_mem(a,b,c) do { } while (0)
 #define jffs2_sum_scan_sumnode(a,b,c,d,e) (0)
 #endif /* CONFIG_JFFS2_SUMMARY */
2.35.3
