[PATCH 16/18] jffs2: Use kzalloc instead of kmalloc/memset
Sebastian Huber
Wed Jan 11 11:58:50 UTC 2023
Use kzalloc rather than duplicating its implementation, which
makes code simple and easy to understand.
Signed-off-by: Haowen Bai <baihaowen at meizu.com>
[rw: Fixed printk string]
Signed-off-by: Richard Weinberger <richard at nod.at>
cpukit/libfs/src/jffs2/src/erase.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/erase.c b/cpukit/libfs/src/jffs2/src/erase.c
index e8ab569462..6966ed9b0a 100644
--- a/cpukit/libfs/src/jffs2/src/erase.c
+++ b/cpukit/libfs/src/jffs2/src/erase.c
@@ -45,9 +45,9 @@ static void jffs2_erase_block(struct jffs2_sb_info *c,
jffs2_dbg(1, "%s(): erase block %#08x (range %#08x-%#08x)\n",
__func__,
jeb->offset, jeb->offset, jeb->offset + c->sector_size);
- instr = kmalloc(sizeof(struct erase_info), GFP_KERNEL);
+ instr = kzalloc(sizeof(struct erase_info), GFP_KERNEL);
if (!instr) {
- pr_warn("kmalloc for struct erase_info in jffs2_erase_block failed. Refiling block for later\n");
+ pr_warn("kzalloc for struct erase_info in jffs2_erase_block failed. Refiling block for later\n");
mutex_lock(&c->erase_free_sem);
spin_lock(&c->erase_completion_lock);
list_move(&jeb->list, &c->erase_pending_list);
@@ -59,8 +59,6 @@ static void jffs2_erase_block(struct jffs2_sb_info *c,
return;
- memset(instr, 0, sizeof(*instr));
instr->addr = jeb->offset;
instr->len = c->sector_size;
2.35.3
