[PATCH 13/18] jffs2: fix memory leak in jffs2_scan_medium
Wed Jan 11 11:58:47 UTC 2023
If an error is returned in jffs2_scan_eraseblock() and some memory
has been added to the jffs2_summary *s, we can observe the following
kmemleak report:
unreferenced object 0xffff88812b889c40 (size 64):
  comm "mount", pid 692, jiffies 4294838325 (age 34.288s)
  hex dump (first 32 bytes):
    40 48 b5 14 81 88 ff ff 01 e0 31 00 00 00 50 00  @H........1...P.
    00 00 01 00 00 00 01 00 00 00 02 00 00 00 09 08  ................
  backtrace:
    [<ffffffffae93a3a3>] __kmalloc+0x613/0x910
    [<ffffffffaf423b9c>] jffs2_sum_add_dirent_mem+0x5c/0xa0
    [<ffffffffb0f3afa8>] jffs2_scan_medium.cold+0x36e5/0x4794
    [<ffffffffb0f3dbe1>] jffs2_do_mount_fs.cold+0xa7/0x2267
    [<ffffffffaf40acf3>] jffs2_do_fill_super+0x383/0xc30
    [<ffffffffaf40c00a>] jffs2_fill_super+0x2ea/0x4c0
    [<ffffffffb0315d64>] mtd_get_sb+0x254/0x400
    [<ffffffffb0315f5f>] mtd_get_sb_by_nr+0x4f/0xd0
    [<ffffffffb0316478>] get_tree_mtd+0x498/0x840
    [<ffffffffaf40bd15>] jffs2_get_tree+0x25/0x30
    [<ffffffffae9f358d>] vfs_get_tree+0x8d/0x2e0
    [<ffffffffaea7a98f>] path_mount+0x50f/0x1e50
    [<ffffffffaea7c3d7>] do_mount+0x107/0x130
    [<ffffffffaea7c5c5>] __se_sys_mount+0x1c5/0x2f0
    [<ffffffffaea7c917>] __x64_sys_mount+0xc7/0x160
    [<ffffffffb10142f5>] do_syscall_64+0x45/0x70
unreferenced object 0xffff888114b54840 (size 32):
    c0 75 b5 14 81 88 ff ff 02 e0 02 00 00 00 02 00  .u..............
    00 00 84 00 00 00 44 00 00 00 6b 6b 6b 6b 6b a5  ......D...kkkkk.
  backtrace:
    [<ffffffffae93be24>] kmem_cache_alloc_trace+0x584/0x880
    [<ffffffffaf423b04>] jffs2_sum_add_inode_mem+0x54/0x90
    [<ffffffffb0f3bd44>] jffs2_scan_medium.cold+0x4481/0x4794
unreferenced object 0xffff888114b57280 (size 32):
  comm "mount", pid 692, jiffies 4294838393 (age 34.357s)
    10 d5 6c 11 81 88 ff ff 08 e0 05 00 00 00 01 00  ..l.............
    00 00 38 02 00 00 28 00 00 00 6b 6b 6b 6b 6b a5  ..8...(...kkkkk.
  backtrace:
    [<ffffffffaf423c34>] jffs2_sum_add_xattr_mem+0x54/0x90
    [<ffffffffb0f3a24f>] jffs2_scan_medium.cold+0x298c/0x4794
unreferenced object 0xffff8881116cd510 (size 16):
  comm "mount", pid 692, jiffies 4294838395 (age 34.355s)
  hex dump (first 16 bytes):
    00 00 00 00 00 00 00 00 09 e0 60 02 00 00 6b a5  ..........`...k.
  backtrace:
    [<ffffffffaf423cc4>] jffs2_sum_add_xref_mem+0x54/0x90
    [<ffffffffb0f3b2e3>] jffs2_scan_medium.cold+0x3a20/0x4794
Therefore, we should call jffs2_sum_reset_collected(s) on exit to
release the memory added in s. In addition, a new tag "out_buf" is
added to prevent the NULL pointer reference caused by s being NULL.
(thanks to Zhang Yi for this analysis)
Fixes: e631ddba5887 ("[JFFS2] Add erase block summary support (mount time improvement)")
Cc: stable at vger.kernel.org
Co-developed-with: Zhihao Cheng <chengzhihao1 at huawei.com>
Signed-off-by: Baokun Li <libaokun1 at huawei.com>
Signed-off-by: Richard Weinberger <richard at nod.at>
 cpukit/libfs/src/jffs2/src/scan.c | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/scan.c b/cpukit/libfs/src/jffs2/src/scan.c
index fc33faffbe..10663feb1f 100644
--- a/cpukit/libfs/src/jffs2/src/scan.c
+++ b/cpukit/libfs/src/jffs2/src/scan.c
@@ -139,7 +139,7 @@ int jffs2_scan_medium(struct jffs2_sb_info *c)
 		if (!s) {
 			JFFS2_WARNING("Can't allocate memory for summary\n");
 			ret = -ENOMEM;
-			goto out;
+			goto out_buf;
@@ -278,13 +278,15 @@ int jffs2_scan_medium(struct jffs2_sb_info *c)
 	ret = 0;
  out:
+	jffs2_sum_reset_collected(s);
+	kfree(s);
+ out_buf:
 	if (buf_size)
 		kfree(flashbuf);
 #ifndef __ECOS
 	else
 		mtd_unpoint(c->mtd, 0, c->mtd->size);
 #endif
-	kfree(s);
 	return ret;
2.35.3
