[PATCH 0/3] build: Use enabled by for defaults
Sebastian Huber
Thu Jan 12 12:16:25 UTC 2023
On 12.01.23 13:03, Sebastian Huber wrote:
> Merge the "default" and "default-by-variant" attributes. Use an
> "enabled-by" expression to select the default value based on the enabled
> set. This makes it possible to select default values depending on other
> options. For example you could choose memory settings based on whether
> RTEMS_SMP is enabled or disabled.
> Sebastian Huber (3):
> build: Format build items
> build: Replace variant patterns with a list
Patch 3 exceeded the mailing list limit. You can review it here:
https://github.com/sebhub/rtems/tree/build-defaults
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
