[PATCH v1 3/4] cpukit/libdl: Add AArch64 TLS reloc support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Jan 12 22:54:55 UTC 2023
This adds basic TLS relocation support for AArch64 to libdl. This lets
loadable modules use TLS symbols hosted in the main binary. This does
not allow loadable modules to host their own TLS symbols.
cpukit/libdl/rtl-mdreloc-aarch64.c | 38 ++++++++++++++++++++++++++++++
1 file changed, 38 insertions(+)
diff --git a/cpukit/libdl/rtl-mdreloc-aarch64.c b/cpukit/libdl/rtl-mdreloc-aarch64.c
index 4c51d97a78..e44238e636 100644
--- a/cpukit/libdl/rtl-mdreloc-aarch64.c
+++ b/cpukit/libdl/rtl-mdreloc-aarch64.c
@@ -79,6 +79,7 @@ __RCSID("$NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $");
#include "rtl-error.h"
#include <rtems/rtl/rtl-trace.h>
#include "rtl-unwind-arm.h"
+#include <rtems/score/tls.h>
struct tls_data {
size_t td_tlsindex;
@@ -237,6 +238,7 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj* obj,
* A - the addend of the reolcation
* P - the address of the place being relocated (derived from r_offset)
* Page(expr) - the page address of the expression expr, defined as (expr & ~0xFFF).
+ * TPREL(expr) - the thread pointer offset of the expression expr
switch (ELF_R_TYPE(rela->r_info)) {
case R_TYPE(NONE):
@@ -286,6 +288,42 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj* obj,
printf("rtl: reloc COPY (please report)\n");
break;
+ case R_AARCH64_ADD_TPREL_HI12: /* TPREL(S + A) */
+ case R_AARCH64_ADD_TPREL_LO12:
+ case R_AARCH64_ADD_TPREL_LO12_NC:
+ uint32_t of_check = 0;
+ switch (ELF_R_TYPE(rela->r_info)) {
+ of_check = 212;
+ /* fallthrough */
+ shift = 0;
+ break;
+ of_check = 224;
+ shift = 12;
+ break;
+ default:
+ printf("illegal rtype: %ld\n", ELF_R_TYPE(rela->r_info));
+ break;
+ if (!parsing) {
+ target = (Elf_Addr)symvalue + rela->r_addend;
+ /* Calculate offset accounting for the DTV */
+ target -= (uintptr_t)_TLS_Data_begin;
+ target += sizeof(TLS_Dynamic_thread_vector);
+ target >>= shift;
+ target &= WIDTHMASK(12);
+ if (of_check && target >= of_check) {
+ return rtems_rtl_elf_rel_failure;
+ *insn = htole32(
+ (le32toh(*insn) & ~__BITS(21,10)) | (target << 10));
+ break;
case R_AARCH64_ADD_ABS_LO12_NC: /* S + A */
case R_AARCH64_LDST8_ABS_LO12_NC:
case R_AARCH_LDST16_ABS_LO12_NC:
2.30.2
