[PATCH 0/5] bsps/microblaze: Add device tree support
Alex White
alex.white at oarcorp.com
Fri Jan 13 04:33:32 UTC 2023
This patch set adds device tree support to the following MicroBlaze BSP drivers:
- AXI Interrupt Controller
- JFFS2 QSPI
- AXI UART Lite
- AXI Timer clock
Previously, the only way to configure the above drivers was to use build
configuration options. Now when a device tree is present, the BSP will use the
device tree to configure the drivers.
Alex White (2):
bsps/microblaze: Add device tree getter
bsps/microblaze: Add device tree support to timer
Ryan Long (3):
bsps/microblaze: Add device tree support to AXI interrupt controller
bsps/microblaze: Add device tree support to JFFS2 QSPI
bsps/microblaze: Add device tree support to UART Lite
.../include/bsp/microblaze-fdt-support.h | 65 +++++++++++++++++
bsps/microblaze/microblaze_fpga/clock/clock.c | 50 ++++++++-----
.../microblaze_fpga/console/console-io.c | 19 ++++-
.../microblaze_fpga/console/debug-io.c | 29 ++++++--
bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 23 ------
.../microblaze_fpga/fs/jffs2_qspi.c | 17 ++++-
bsps/microblaze/microblaze_fpga/include/bsp.h | 3 +
.../microblaze_fpga/include/bsp/intc.h | 2 -
.../microblaze_fpga/include/bsp/timer.h | 2 -
bsps/microblaze/microblaze_fpga/irq/irq.c | 36 +++++-----
bsps/microblaze/shared/dev/serial/uartlite.c | 9 ++-
.../shared/fdt/microblaze-fdt-support.c | 72 +++++++++++++++++++
.../bsps/microblaze/microblaze_fpga/grp.yml | 2 +
.../bsps/microblaze/microblaze_fpga/obj.yml | 3 +-
.../microblaze/microblaze_fpga/optusefdt.yml | 15 ++++
15 files changed, 274 insertions(+), 73 deletions(-)
create mode 100644 bsps/microblaze/include/bsp/microblaze-fdt-support.h
delete mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
create mode 100644 bsps/microblaze/shared/fdt/microblaze-fdt-support.c
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optusefdt.yml
2.34.1
