[PATCH] move isr_level of SMP_lock_Context into ISR_lock_Context
Zhu Zhongjie
zhongjiezhu1 at gmail.com
Sun Jan 15 10:00:27 UTC 2023
when Acquires an ISR lock in SMP system, it first call _ISR_Local_disable()
to disable ISR, this is the same with in UP system, so we could
use the same isr_level in ISR_lock_Context, this change will also save 4 Bytes
of SMP_lock_Context.
cpukit/include/rtems/score/isrlock.h | 39 ++++----------
cpukit/include/rtems/score/smpisrlock.h | 69 +++++++++++++++++++++++++
cpukit/include/rtems/score/smplock.h | 60 ---------------------
cpukit/score/src/profilingsmplock.c | 11 ++--
cpukit/score/src/smplock.c | 5 +-
testsuites/smptests/smpload01/init.c | 2 +-
testsuites/smptests/smpmrsp01/init.c | 6 +--
7 files changed, 93 insertions(+), 99 deletions(-)
create mode 100644 cpukit/include/rtems/score/smpisrlock.h
diff --git a/cpukit/include/rtems/score/isrlock.h b/cpukit/include/rtems/score/isrlock.h
index 72ac760196..fba10f1945 100644
--- a/cpukit/include/rtems/score/isrlock.h
+++ b/cpukit/include/rtems/score/isrlock.h
@@ -79,10 +79,9 @@ typedef struct {
* @brief Local ISR lock context for acquire and release pairs.
typedef struct {
+ ISR_Level isr_level;
#if defined( RTEMS_SMP )
SMP_lock_Context Lock_context;
-#else
- ISR_Level isr_level;
#endif
#if defined( RTEMS_PROFILING )
@@ -177,11 +176,7 @@ static inline void _ISR_lock_Context_set_level(
ISR_Level level
-#if defined( RTEMS_SMP )
- context->Lock_context.isr_level = level;
-#else
context->isr_level = level;
-#endif
@@ -230,6 +225,7 @@ static inline void _ISR_lock_Context_set_level(
#define _ISR_lock_Set_name( _lock, _name )
#endif
+#include <rtems/score/smpisrlock.h>
* @brief Acquires an ISR lock.
@@ -248,7 +244,7 @@ static inline void _ISR_lock_Context_set_level(
#define _ISR_lock_ISR_disable_and_acquire( _lock, _context ) \
_SMP_lock_ISR_disable_and_acquire( \
&( _lock )->Lock, \
- &( _context )->Lock_context \
+ _context \
#else
@@ -273,7 +269,7 @@ static inline void _ISR_lock_Context_set_level(
#define _ISR_lock_Release_and_ISR_enable( _lock, _context ) \
_SMP_lock_Release_and_ISR_enable( \
&( _lock )->Lock, \
+ _context \
#else
@@ -404,19 +400,11 @@ static inline void _ISR_lock_Context_set_level(
* @see _ISR_lock_ISR_enable().
- #define _ISR_lock_ISR_disable( _context ) \
- do { \
- _ISR_Local_disable( ( _context )->Lock_context.isr_level ); \
- _ISR_lock_ISR_disable_profile( _context ) \
- } while ( 0 )
-#else
- do { \
- _ISR_Local_disable( ( _context )->isr_level ); \
- } while ( 0 )
-#endif
+#define _ISR_lock_ISR_disable( _context ) \
+ do { \
+ _ISR_Local_disable( ( _context )->isr_level ); \
+ _ISR_lock_ISR_disable_profile( _context ) \
+ } while ( 0 )
* @brief Restores the saved interrupt state of the ISR lock context.
@@ -428,13 +416,8 @@ static inline void _ISR_lock_Context_set_level(
* @see _ISR_lock_ISR_disable().
- #define _ISR_lock_ISR_enable( _context ) \
- _ISR_Local_enable( ( _context )->Lock_context.isr_level )
-#else
- _ISR_Local_enable( ( _context )->isr_level )
-#endif
+#define _ISR_lock_ISR_enable( _context ) \
+ _ISR_Local_enable( ( _context )->isr_level )
diff --git a/cpukit/include/rtems/score/smpisrlock.h b/cpukit/include/rtems/score/smpisrlock.h
new file mode 100644
index 0000000000..984bbcf861
--- /dev/null
+++ b/cpukit/include/rtems/score/smpisrlock.h
@@ -0,0 +1,69 @@
+#ifndef _RTEMS_SCORE_SMP_ISR_LOCK_H
+#define _RTEMS_SCORE_SMP_ISR_LOCK_H
+#if defined(RTEMS_SMP)
+#include <rtems/score/smplock.h>
+#include <rtems/score/isrlock.h>
+ * @brief Disables interrupts and acquires the SMP lock
+ * @param[in, out] lock The lock to acquire.
+ * @param[in, out] context The lock context.
+static inline void _SMP_lock_ISR_disable_and_acquire_inline(
+ SMP_lock_Control *lock,
+ ISR_lock_Context *context
+ _ISR_Local_disable( context->isr_level );
+ _SMP_lock_Acquire_inline( lock, &context->Lock_context );
+ * @brief Disables interrupts and acquires the SMP lock.
+ * @param[in, out] lock The SMP lock control.
+ * @param[in, out] context The local SMP lock context for an acquire and release
+ * pair.
+void _SMP_lock_ISR_disable_and_acquire(
+ * @brief Releases the SMP lock and enables interrupts.
+ * @param[in, out] lock The SMP lock to release.
+static inline void _SMP_lock_Release_and_ISR_enable_inline(
+ _SMP_lock_Release_inline( lock, &context->Lock_context );
+ _ISR_Local_enable( context->isr_level );
+ * pair.
+#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
+void _SMP_lock_Release_and_ISR_enable(
+#else
+#define _SMP_lock_Release_and_ISR_enable( lock, context ) \
+ _SMP_lock_Release_and_ISR_enable_inline( lock, context )
+#endif
+#endif /* RTEMS_SMP */
+#endif
diff --git a/cpukit/include/rtems/score/smplock.h b/cpukit/include/rtems/score/smplock.h
index ca874fef08..84831499be 100644
--- a/cpukit/include/rtems/score/smplock.h
+++ b/cpukit/include/rtems/score/smplock.h
@@ -109,7 +109,6 @@ typedef struct {
* @brief Local SMP lock context for acquire and release pairs.
typedef struct {
#if defined(RTEMS_DEBUG)
SMP_lock_Control *lock_used_for_acquire;
#endif
@@ -327,65 +326,6 @@ void _SMP_lock_Release(
_SMP_lock_Release_inline( lock, context )
#endif
- * @brief Disables interrupts and acquires the SMP lock
- * @param[in, out] lock The lock to acquire.
- * @param[in, out] context The lock context.
-static inline void _SMP_lock_ISR_disable_and_acquire_inline(
- SMP_lock_Control *lock,
- SMP_lock_Context *context
- _ISR_Local_disable( context->isr_level );
- _SMP_lock_Acquire_inline( lock, context );
- * @brief Disables interrupts and acquires the SMP lock.
- * @param[in, out] lock The SMP lock control.
- * @param[in, out] context The local SMP lock context for an acquire and release
- * pair.
-void _SMP_lock_ISR_disable_and_acquire(
- * @brief Releases the SMP lock and enables interrupts.
- * @param[in, out] lock The SMP lock to release.
-static inline void _SMP_lock_Release_and_ISR_enable_inline(
- _SMP_lock_Release_inline( lock, context );
- _ISR_Local_enable( context->isr_level );
- * pair.
-#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
-void _SMP_lock_Release_and_ISR_enable(
-#else
-#define _SMP_lock_Release_and_ISR_enable( lock, context ) \
- _SMP_lock_Release_and_ISR_enable_inline( lock, context )
-#endif
* @brief Checks if the SMP lock is owned by the current processor.
diff --git a/cpukit/score/src/profilingsmplock.c b/cpukit/score/src/profilingsmplock.c
index 5c5b4d9196..41ebbcbed3 100644
--- a/cpukit/score/src/profilingsmplock.c
+++ b/cpukit/score/src/profilingsmplock.c
@@ -41,6 +41,7 @@
#endif
@@ -78,7 +79,7 @@ void _SMP_lock_Stats_destroy( SMP_lock_Stats *stats )
if ( !_Chain_Is_node_off_chain( &stats->Node ) ) {
SMP_lock_Stats_control *control = &_SMP_lock_Stats_control;
- SMP_lock_Context lock_context;
+ ISR_lock_Context lock_context;
SMP_lock_Stats_iteration_context *iteration_context;
SMP_lock_Stats_iteration_context *iteration_context_tail;
SMP_lock_Stats *next_stats;
@@ -115,7 +116,7 @@ void _SMP_lock_Stats_register_or_max_section_time(
if ( _Chain_Is_node_off_chain( &stats->Node ) ) {
SMP_lock_Stats_control *control;
_SMP_lock_ISR_disable_and_acquire( &control->Lock, &lock_context );
@@ -129,7 +130,7 @@ void _SMP_lock_Stats_iteration_start(
@@ -152,7 +153,7 @@ bool _SMP_lock_Stats_iteration_next(
SMP_lock_Stats *current;
bool valid;
@@ -190,7 +191,7 @@ void _SMP_lock_Stats_iteration_stop(
_Chain_Extract_unprotected( &iteration_context->Node );
diff --git a/cpukit/score/src/smplock.c b/cpukit/score/src/smplock.c
index c3a41300bb..a0ff2b3ab0 100644
--- a/cpukit/score/src/smplock.c
+++ b/cpukit/score/src/smplock.c
@@ -41,6 +41,7 @@
#endif
void _SMP_lock_Initialize(
@@ -77,7 +78,7 @@ void _SMP_lock_Release(
_SMP_lock_ISR_disable_and_acquire_inline( lock, context );
@@ -86,7 +87,7 @@ void _SMP_lock_ISR_disable_and_acquire(
_SMP_lock_Release_and_ISR_enable_inline( lock, context );
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index d28e728746..c72b5e1ef5 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -241,7 +241,7 @@ static void get_obtain_delay_estimate(test_context *ctx)
_ISR_Local_disable(level);
for (i = 0; i < n; ++i) {
rtems_counter_ticks a;
rtems_counter_ticks b;
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index e435f77b2a..2338b1e493 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -157,7 +157,7 @@ static void assert_executing_worker(test_context *ctx)
static void switch_extension(Thread_Control *executing, Thread_Control *heir)
test_context *ctx = &test_instance;
size_t i;
_SMP_lock_ISR_disable_and_acquire(&ctx->switch_lock, &lock_context);
@@ -181,7 +181,7 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
static void reset_switch_events(test_context *ctx)
ctx->switch_index = 0;
@@ -190,7 +190,7 @@ static void reset_switch_events(test_context *ctx)
static size_t get_switch_events(test_context *ctx)
size_t events;
2.34.1
