On 16.01.23 09:36, Zhu Zhongjie wrote:
> From: Zhongjie Zhu <zhongjiezhu1 at gmail.com>
> there are different cases for _ISR_lock_ISR_disable() and _ISR_lock_ISR_enable()
> in the case RTEMS_SMP is defined or RTEMS_PROFILING is defined, so remove the related code.
> ../../../cpukit/include/rtems/score/threaddispatch.h: In function '_Thread_Dispatch_disable':
> ../../../cpukit/include/rtems/score/threaddispatch.h:231:14: warning: 'lock_context' may be used uninitialized [-Wmaybe-uninitialized]
> 231 | cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
> ../../../cpukit/include/rtems/score/threaddispatch.h:210:32: note: by argument 1 of type 'const ISR_lock_Context *' to '_Thread_Dispatch_disable_critical' declared here
> 210 | static inline Per_CPU_Control *_Thread_Dispatch_disable_critical(
> ../../../cpukit/include/rtems/score/threaddispatch.h:225:21: note: 'lock_context' declared here
> 225 | ISR_lock_Context lock_context;
> cpukit/include/rtems/score/threaddispatch.h | 7 ++++---
> 1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/cpukit/include/rtems/score/threaddispatch.h b/cpukit/include/rtems/score/threaddispatch.h
> index 589935823f..b06ebe8fec 100644
> --- a/cpukit/include/rtems/score/threaddispatch.h
> +++ b/cpukit/include/rtems/score/threaddispatch.h
> @@ -222,16 +222,17 @@ static inline Per_CPU_Control *_Thread_Dispatch_disable_critical(
> static inline Per_CPU_Control *_Thread_Dispatch_disable( void )
> Per_CPU_Control *cpu_self;
> - ISR_lock_Context lock_context;
> #if defined( RTEMS_SMP ) || defined( RTEMS_PROFILING )
> + ISR_lock_Context lock_context;
> _ISR_lock_ISR_disable( &lock_context );
> -#endif
> -#if defined( RTEMS_SMP ) || defined( RTEMS_PROFILING )
> _ISR_lock_ISR_enable( &lock_context );
> +#else
> + cpu_self = _Thread_Dispatch_disable_critical( NULL );
> #endif
> return cpu_self;
I doubt that this patch compiles if RTEMS_SMP or RTEMS_PROFILING is not
defined.
The problem with the warning is that _Thread_Dispatch_disable_critical()
takes a const pointer to lock_context and nobody writes to this
structure before it is handed over.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
