[PATCH rtems-source-builder 1/2] github: Enable CI
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Jan 16 13:41:21 UTC 2023
Allow users to optionally use the GitHub CI.
.github/workflows/toolchain.yml | 196 ++++++++++++++++++++++++++++++++
1 file changed, 196 insertions(+)
create mode 100644 .github/workflows/toolchain.yml
diff --git a/.github/workflows/toolchain.yml b/.github/workflows/toolchain.yml
new file mode 100644
index 0000000..f9fec95
--- /dev/null
+++ b/.github/workflows/toolchain.yml
@@ -0,0 +1,196 @@
+name: Toolchain
+on:
+ # Triggers the workflow on push or pull request for the given branch
+ push:
+ branches: [ master ]
+ pull_request:
+ # Trigger manually from the Actions tab
+ workflow_dispatch:
+jobs:
+ devel:
+ strategy:
+ fail-fast: false
+ matrix:
+ tool:
+ - autotools-base
+ - autotools
+ - capstone
+ - dtc
+ - gnu-default-tools
+ - libtool
+ - libusb
+ - or1ksim
+ - qemu-couverture
+ - qemu-xilinx
+ - qemu
+ - sis
+ - spike
+ - swig
+ runs-on: ubuntu-latest
+ steps:
+ - uses: actions/checkout at v3
+ with:
+ path: rsb
+ - name: Install dependencies
+ run: |
+ sudo apt-get update
+ sudo apt-get install \
+ build-essential \
+ ninja-build \
+ libudev-dev
+ - name: Build ${{ matrix.tool }}
+ run: |
+ cd rsb/rtems
+ ../source-builder/sb-set-builder \
+ --log=l-${{ matrix.tool }} \
+ --prefix=/opt/rtems/6 \
+ --bset-tar-file \
+ devel/${{ matrix.tool }}
+ - name: Archive log on failure
+ if: ${{ failure() }}
+ uses: actions/upload-artifact at v3
+ with:
+ name: log-${{ matrix.tool }}
+ path: |
+ rsb/rtems/l-${{ matrix.tool }}
+ rsb/**/rsb-report-*.txt
+ - name: Archive artifacts
+ with:
+ name: devel-${{ matrix.tool }}
+ path: rsb/rtems/tar/*.tar*
+ build:
+ strategy:
+ fail-fast: false
+ matrix:
+ target:
+ - aarch64
+ - arm
+ - bfin
+ - i386
+ - lm32
+ - m68k
+ - microblaze
+ - mips
+ - moxie
+ - nios2
+ - or1k
+ - powerpc
+ - riscv
+ - sh
+ - sparc
+ - sparc64
+ - v850
+ - x86_64
+ steps:
+ with:
+ path: rsb
+ with:
+ path: rtems
+ ref: ci
+ repository: RTEMS/rtems
+ run: |
+ build-essential \
+ flex \
+ bison \
+ cmake \
+ texinfo \
+ device-tree-compiler \
+ u-boot-tools \
+ lzop \
+ libusb-1.0-0-dev \
+ python3 \
+ python-is-python3 \
+ libpython3-dev \
+ python3-dev
+ - name: Build toolchain
+ run: |
+ cd rsb/rtems
+ --log=l-${{ matrix.target }} \
+ --bset-tar-file \
+ 6/rtems-${{ matrix.target }}
+ with:
+ name: log-${{ matrix.target }}
+ path: rsb/rtems/l-${{ matrix.target }}
+ with:
+ name: tools-${{ matrix.target }}
+ #- name: Build BSPs
+ # uses: ./rtems/.github/actions/build-bsps
+ # with:
+ # target: ${{ matrix.target }}
+ # sources-rtems: "${GITHUB_WORKSPACE}/rtems"
+ # prefix: /opt/rtems/6
+ simulator:
+ # run even if not all of the earlier matrix builds worked
+ if: ${{ always() }}
+ needs:
+ - build
+ - devel
+ strategy:
+ fail-fast: false
+ matrix:
+ simulators:
+ - sparc/gr740
+ - riscv/griscv
+ - arm/xilinx_zynq_a9_qemu
+ steps:
+ - name: split arch and BSP
+ shell: bash
+ run: |
+ arch=`echo "${{ matrix.simulators }}" | sed -e "s|/.*||g"`
+ bsp=`echo "${{ matrix.simulators }}" | sed -e "s|.*/||g"`
+ echo "arch=${arch}" >> $GITHUB_ENV
+ echo "bsp=${bsp}" >> $GITHUB_ENV
+ with:
+ path: rtems
+ ref: ci
+ run: |
+ python3 \
+ jq
+ - name: Download toolchain artifact
+ uses: actions/download-artifact at v3
+ with:
+ name: tools-${{ env.arch }}
+ - name: Download qemu artifact
+ with:
+ name: devel-qemu
+ - name: Unpack toolchain
+ run: |
+ mkdir -p "$GITHUB_WORKSPACE/toolchain"
+ for t in *.tar.bz2; do tar xf $t -v -C "$GITHUB_WORKSPACE/toolchain"; done
+ ls -la "$GITHUB_WORKSPACE/toolchain"
+ - name: Start simulator run
+ id: simulator
+ uses: ./rtems/.github/actions/run-simulator
+ with:
+ target: ${{ matrix.simulators }}
+ sources-rtems: "$GITHUB_WORKSPACE/rtems"
+ prefix: "$GITHUB_WORKSPACE/toolchain/opt/rtems/6"
2.35.3
