[PATCH rtems 1/2] github: Enable CI
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Jan 16 13:41:19 UTC 2023
Allow users to optionally use the CI from github.
 .github/actions/build-bsps/action.yml    |  49 ++++++++
 .github/actions/run-simulator/action.yml | 144 +++++++++++++++++++++++
 .github/workflows/bsps.yml               |  63 ++++++++++
 .github/workflows/simulator.yml          |  72 ++++++++++++
 4 files changed, 328 insertions(+)
 create mode 100644 .github/actions/build-bsps/action.yml
 create mode 100644 .github/actions/run-simulator/action.yml
 create mode 100644 .github/workflows/bsps.yml
 create mode 100644 .github/workflows/simulator.yml
diff --git a/.github/actions/build-bsps/action.yml b/.github/actions/build-bsps/action.yml
new file mode 100644
index 0000000000..c06e560125
--- /dev/null
+++ b/.github/actions/build-bsps/action.yml
@@ -0,0 +1,49 @@
+name: "Build BSPs"
+description: "Build BSPs for the given target architecture."
+inputs:
+  bsp:
+    description: "The bsp to build 'sparc/erc32'"
+    type: string
+    required: true
+  sources-rtems:
+    description: "Where to find the RTEMS sources. Use absolute path!"
+    type: string
+    required: true
+  prefix:
+    description: "Prefix directory with the installed tools. Use absolute path!"
+    type: string
+    required: true
+runs:
+  using: "composite"
+  steps:
+    - name: create name for logs
+      shell: bash
+      run: |
+        shortname=`echo "${{ inputs.bsp }}" | sed -e "s|/|_|g"`
+        echo "shortname=${shortname}" >> $GITHUB_ENV
+    - name: create log dir
+      shell: bash
+      run: mkdir "${GITHUB_WORKSPACE}"/bsp-logs
+    - name: Run BSP builder
+      shell: bash
+      run: |
+        "${{ inputs.prefix }}"/bin/rtems-bsp-builder \
+                              --build-path "${GITHUB_WORKSPACE}"/rtems-build \
+                              --prefix "${{ inputs.prefix }}" \
+                              --rtems-tools "${{ inputs.prefix }}/bin" \
+                              --rtems "${{ inputs.sources-rtems }}" \
+                              --bsp ${{ inputs.bsp }} \
+                              --log "${GITHUB_WORKSPACE}"/bsp-logs/log-${{ env.shortname }}.txt \
+                              --warnings-report "${GITHUB_WORKSPACE}"/bsp-logs/warnings-${{ env.shortname }}.txt \
+                              --failures-report "${GITHUB_WORKSPACE}"/bsp-logs/failures-${{ env.shortname }}.txt
+    - name: Archive log
+      uses: actions/upload-artifact at v3
+      with:
+        name: log-${{ env.shortname }}
+        path: bsp-logs
+    - name: Check for errors
+      shell: bash
+      run: |
+        grep "Failures: 0" "$GITHUB_WORKSPACE"/bsp-logs/log-${{ env.shortname }}.txt
diff --git a/.github/actions/run-simulator/action.yml b/.github/actions/run-simulator/action.yml
index 0000000000..23aa70e8ea
--- /dev/null
+++ b/.github/actions/run-simulator/action.yml
@@ -0,0 +1,144 @@
+name: "Run Simulator"
+description: "Build BSPs for the given target/BSP and run tests on a simulator"
+inputs:
+  target:
+    description: "The Arch/BSP to run. For example 'sparc/erc32'"
+    type: string
+    required: true
+  sources-rtems:
+    type: string
+    required: true
+  prefix:
+    type: string
+    required: true
+runs:
+  steps:
+    - shell: bash
+      run: |
+        # Find correct parameters for this simulator
+        args=""
+        found=0
+        [ "${{ inputs.target }}" == "sparc/erc32" ] && \
+           args="--rtems-bsp=erc32-sis" && \
+           found=1
+        [ "${{ inputs.target }}" == "sparc/gr740" ] && \
+           args="--rtems-bsp=gr740-sis" && \
+           found=1
+        [ "${{ inputs.target }}" == "riscv/griscv" ] && \
+           args="--rtems-bsp=griscv-sis" && \
+           found=1
+        [ "${{ inputs.target }}" == "arm/xilinx_zynq_a9_qemu" ] && \
+           args="--rtems-bsp=xilinx_zynq_a9_qemu" && \
+           found=1
+        echo "rtems_test_args=${args}" >> $GITHUB_ENV
+        echo "simulator_supported=${found}" >> $GITHUB_ENV
+    - if: ${{ env.simulator_supported == 0 }}
+      shell: bash
+      run: |
+        # Check whether parameters for this simulator have been found
+        echo "${{ inputs.target }} is not supported for simulator runs"
+        false
+    - shell: bash
+      run: |
+        # create environment variables for paths and names
+        shortname=`echo "${{ inputs.target }}" | sed -e "s|/|_|g"`
+        echo "logdir=${GITHUB_WORKSPACE}/logs-${shortname}" >> $GITHUB_ENV
+        echo "builddir=${GITHUB_WORKSPACE}/build-${shortname}" >> $GITHUB_ENV
+    - shell: bash
+      run: |
+        # create directories
+        mkdir -p "${{ env.logdir }}"
+        mkdir -p "${{ env.builddir }}"
+    - shell: bash
+      run: |
+        # generate BSP config
+        echo -e "[${{ inputs.target }}]\nBUILD_TESTS = True" >> "${{ env.builddir }}/config.ini"
+        cat "${{ env.builddir }}/config.ini"
+    - shell: bash
+      run: |
+        # configure
+        cd ${{ env.builddir }} && ${{ inputs.sources-rtems }}/waf configure \
+          --out="${{ env.builddir }}" \
+          --rtems-config="${{ env.builddir }}/config.ini" \
+          --top="${{ inputs.sources-rtems }}" \
+          --prefix="${{ inputs.prefix }}"
+    - if: ${{ failure() }}
+      shell: bash
+      run: |
+        # print log
+        cat "${{ env.builddir }}/config.log"
+    - shell: bash
+      run: |
+        # compile
+        cd ${{ env.builddir }} && ${{ inputs.sources-rtems }}/waf \
+        find ${{ env.builddir }} -name "*.exe"
+    - shell: bash
+      run: |
+        # run tests
+        # Note: PATH needs to be adapted so that for example qemu is found
+        PATH="${{ inputs.prefix }}/bin":$PATH rtems-test \
+          --log="${{ env.logdir }}/test.log" \
+          --log-mode=all \
+          --report-path="${{ env.logdir }}/report" \
+          --report-format=json \
+          --warn-all \
+          --rtems-tools="${{ inputs.prefix }}" \
+          ${{ env.rtems_test_args }} \
+          ${{ env.builddir }}
+      if: success() || failure()
+      with:
+        name: test-logs-${{ env.shortname }}
+        path: logs-${{ env.shortname }}
+    - shell: bash
+      run: |
+        # Set default values
+        echo "results_total=-1" | tee -a $GITHUB_ENV
+        echo "tests_passed=0" | tee -a $GITHUB_ENV
+        echo "tests_user-input=0" | tee -a $GITHUB_ENV
+        echo "tests_expected-fail=0" | tee -a $GITHUB_ENV
+        echo "tests_benchmark=0" | tee -a $GITHUB_ENV
+    - shell: bash
+      run: |
+        # Count number of passed / failed / ... tests
+        jq -r '.reports | group_by(.result) | map({result: .[0].result, count: length})[] | ("tests_"+.result+"="+(.count|tostring))' ${{ env.logdir }}/report.json | tee -a $GITHUB_ENV
+        jq -r '.reports | ("results_total="+(length|tostring))' ${{ env.logdir }}/report.json | tee -a $GITHUB_ENV
+    - shell: bash
+      run: |
+        # Summarize tests
+        echo "results_ok=$(expr \
+            ${{ env.tests_passed }} + \
+            ${{ env.tests_user-input }} + \
+            ${{ env.tests_expected-fail }} + \
+            ${{ env.tests_benchmark }})" | tee -a $GITHUB_ENV
+    - shell: bash
+      run: |
+        # Generate ASCII-Table report
+        jq -r '.reports[] | ((.executable | split("testsuites/")[1] | split(".exe")[0])+";"+(if .result=="passed" or .result=="user-input" or .result=="benchmark" or .result=="expected-fail" then "\u001b[32m\u2714" else "\u001b[31m\u2716" end)+" "+.result+"\u001b[0m")' ${{ env.logdir }}/report.json | column -t -s\;
+    - shell: bash
+      run: |
+        # Summarize not passed tests on github step summary
+        echo "### Tests for ${{ inputs.target }}" >> $GITHUB_STEP_SUMMARY
+        jq -r '.reports | group_by(.result) | map({result: .[0].result, count: length})[] | ("- "+.result+": "+(.count|tostring))' ${{ env.logdir }}/report.json >> $GITHUB_STEP_SUMMARY
+        echo "" >> $GITHUB_STEP_SUMMARY
+        if [ ${{ env.results_ok }} -ne ${{ env.results_total }} ]; then
+          echo "The following tests did not pass:" >> $GITHUB_STEP_SUMMARY
+          echo "| name | result |" >> $GITHUB_STEP_SUMMARY
+          echo "| --- | --- |" >> $GITHUB_STEP_SUMMARY
+          jq -r '.reports[] | select(.result != "passed" and .result != "benchmark" and .result != "user-input" and .result != "expected-fail") | ("| "+(.executable | split("testsuites/")[1] | split(".exe")[0])+" | "+.result+" |")' ${{ env.logdir }}/report.json >> $GITHUB_STEP_SUMMARY
+        fi
+    - shell: bash
+      run: |
+        # check whether all tests worked as expected
+        echo "${{ env.results_ok }} of ${{ env.results_total }} worked as expected."
+        [ ${{ env.results_ok }} -eq ${{ env.results_total }} ]
diff --git a/.github/workflows/bsps.yml b/.github/workflows/bsps.yml
index 0000000000..c42e84cb5e
--- /dev/null
+++ b/.github/workflows/bsps.yml
@@ -0,0 +1,63 @@
+name: BSPs
+on:
+  # Trigger manually from the Actions tab
+  workflow_dispatch:
+jobs:
+  setup-bsp-matrix:
+    runs-on: ubuntu-latest
+    outputs:
+      matrix: ${{ steps.set-matrix.outputs.matrix }}
+    steps:
+      - uses: actions/checkout at v3
+        with:
+          path: rtems
+      - name: Build matrix
+        id: set-matrix
+        shell: bash
+        run: |
+          cd ${GITHUB_WORKSPACE}/rtems
+          out=$(./waf bsp_list | jq -R '.|split("/")|{ arch: .[0], bsp: .[1] }' | jq -sc '{include: .}')
+          echo "$out"
+          echo "::set-output name=matrix::$out"
+  build:
+    needs: setup-bsp-matrix
+    strategy:
+      fail-fast: false
+      matrix: ${{ fromJson(needs.setup-bsp-matrix.outputs.matrix) }}
+    steps:
+        with:
+          path: rtems
+        with:
+          path: rtems-actions
+          ref: ci
+      - name: Install dependencies
+        run: |
+          sudo apt-get update
+          sudo apt-get install \
+            python3 \
+            python-is-python3
+      - name: Download toolchain artifact
+        uses: dawidd6/action-download-artifact at v2
+        with:
+          repo: RTEMS/rtems-source-builder
+          branch: ci
+          workflow: toolchain.yml
+          workflow_conclusion: completed
+          name: tools-${{ matrix.arch }}
+      - name: Unpack toolchain
+        run: |
+          mkdir -p "$GITHUB_WORKSPACE/toolchain"
+          for t in *.tar.bz2; do tar xf $t -v -C "$GITHUB_WORKSPACE/toolchain"; done
+          ls -la "$GITHUB_WORKSPACE/toolchain"
+      - name: Build BSPs
+        uses: ./rtems-actions/.github/actions/build-bsps
+        with:
+          bsp: "${{ matrix.arch }}/${{ matrix.bsp }}"
+          sources-rtems: "$GITHUB_WORKSPACE/rtems"
+          prefix: "$GITHUB_WORKSPACE/toolchain/opt/rtems/6"
diff --git a/.github/workflows/simulator.yml b/.github/workflows/simulator.yml
index 0000000000..7360e76a5e
--- /dev/null
+++ b/.github/workflows/simulator.yml
@@ -0,0 +1,72 @@
+name: Simulator
+on:
+  # Triggers the workflow on push or pull request for the given branch
+  push:
+    branches: [ master ]
+  pull_request:
+jobs:
+  build:
+    strategy:
+      fail-fast: false
+      matrix:
+        simulators:
+          - riscv/griscv
+          - sparc/gr740
+          - arm/xilinx_zynq_a9_qemu
+    steps:
+      - name: split arch and BSP
+        shell: bash
+        run: |
+          arch=`echo "${{ matrix.simulators }}" | sed -e "s|/.*||g"`
+          bsp=`echo "${{ matrix.simulators }}" | sed -e "s|.*/||g"`
+          echo "arch=${arch}" >> $GITHUB_ENV
+          echo "bsp=${bsp}" >> $GITHUB_ENV
+        with:
+          path: rtems
+        with:
+          ref: ci
+        run: |
+            python3 \
+            python-is-python3 \
+            jq
+        with:
+          branch: ci
+          name: tools-${{ env.arch }}
+      - name: Download qemu artifact
+        with:
+          branch: ci
+          name: devel-qemu
+        run: |
+      - name: Start simulator run
+        id: simulator
+        uses: ./rtems-actions/.github/actions/run-simulator
+        with:
+          target: ${{ matrix.simulators }}
2.35.3
