[PATCH 00/18] Adds Formal Verification Material
Sebastian Huber
Wed Jan 18 12:04:25 UTC 2023
Hello,
I checked in an updated version of the patch set. You find the new files
here:
https://github.com/RTEMS/rtems-central/tree/master/formal
There is some work in progress to make the test code generation from the
model files a bit easier. Once this work is done we could try to add it
to the Github workflow.
The next step is to continue with the integration of the related
documentation into the RTEMS Software Engineering manual:
https://lists.rtems.org/pipermail/devel/2022-November/073765.html
Kind regards,
Sebastian
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
