[PATCH 1/1] RSB: Mitigate too short error reports
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Jan 19 16:13:19 UTC 2023
Hi Joel,
On 1/19/23 15:08, Joel Sherrill wrote:
> Subject:
> Re: [PATCH 1/1] RSB: Mitigate too short error reports
> From:
> Joel Sherrill <joel at rtems.org>
> Date:
> 1/19/23, 15:08
> To:
> Frank Kühndel <frank.kuehndel at embedded-brains.de>
> CC:
> Chris Johns <chrisj at rtems.org>, devel at rtems.org
> On Thu, Jan 19, 2023 at 6:47 AM Frank Kühndel <
> frank.kuehndel at embedded-brains.de> wrote:
>> Hello Chris,
>> Hello Joel,
>> On 1/16/23 18:27, Joel Sherrill wrote:
>>> Subject:
>>> From:
>>> Joel Sherrill<joel at rtems.org>
>>> Date:
>>> 1/16/23, 18:27
>>> To:
>>> Frank Kühndel<frank.kuehndel at embedded-brains.de>
>>> CC:
>>> Chris Johns<chrisj at rtems.org>,devel at rtems.org
>>> On Mon, Jan 16, 2023 at 8:46 AM Frank Kühndel <
>>>> Hi Chris,
>>>> On 1/16/23 01:02, Chris Johns wrote:
>>>>> Subject:
>>>>> From:
>>>>> Date:
>>>>> 1/16/23, 01:02
>>>>> To:
>>>>> Frank Kühndel<frank.kuehndel at embedded-brains.de>,devel at rtems.org
>>>>> On 22/12/2022 9:09 pm, Frank Kühndel wrote:
>>>>>> On 12/21/22 00:06, Chris Johns wrote:
>>>>>>> On 21/12/2022 3:44 am, Frank Kuehndel wrote:
>>>>>>>> From: Frank Kühndel<frank.kuehndel at embedded-brains.de>
>>>>>>>> Close #4642
>>>>>>>>      source-builder/sb/ereport.py | 4 ++++
>>>>>>>>      1 file changed, 4 insertions(+)
>>>>>>>> diff --git a/source-builder/sb/ereport.py
>>>> b/source-builder/sb/ereport.py
>>>>>>>> index d8fb5f6..d391917 100755
>>>>>>>> --- a/source-builder/sb/ereport.py
>>>>>>>> +++ b/source-builder/sb/ereport.py
>>>>>>>> @@ -55,6 +55,10 @@ def generate(name, opts, header = None, footer =
>>>> None):
>>>>>>>>                  with open(name, 'w') as l:
>>>>>>>>                      l.write(os.linesep.join(r))
>>>>>>>>                  log.notice('  See error report: %s' % (name))
>>>>>>>> +            log.notice('  (Hint: The first error may be in front of
>>>> a '
>>>>>>>> +                'line containing\n'
>>>>>>>> +                '  "Error 1" [GNU make] and may be only in the
>> whole
>>>> log '
>>>>>>> Is this too specific to GNU make? What ifs a package uses cmake or
>>>> something
>>>>>>> else?
>>>>>> As the text indicates, this is specific to GNU make. For those using
>>>> something
>>>>>> else reading this text will still hint that the first error may not be
>>>> in the
>>>>>> end of the report "and may be only in the whole log".
>>>>>> Another weak point in this text is that by far not all errors
>>>> originating from
>>>>>> "make". Yet, the true trouble is the original "See error report: %s"
>>>> where it
>>>>>> can sometimes happen that the error is not in this "error report" at
>>>> all.
>>>>>> I found it difficult to find a wording which is short, clear and
>>>> helpful to the
>>>>>> reader and at the same time not confusing. I am not perfectly happy
>>>> with the
>>>>>> notice above. I just found it a reasonable compromise.
>>>>>> If you prefer more generic texts - such as the examples below - I will
>>>> send a
>>>>>> new patch with the suggested test.
>>>>>>        "Hint: The first error may be far way from the end of the
>>>>>>        report and in cases can only be found in the whole build log."
>>>>>>        "Hint: The error is most likely in the error report otherwise
>>>>>>        see the whole build log [--log option]."
>>>>>> If you find any such change might cause more confusion than it might
>> be
>>>> helpful,
>>>>>> I think it better to close this bug than to try to fix it.
>>>>> I think all you have written is valid and I have found the wording
>>>> difficult.
>>>>> There will never be a robust error message scanner or a simple full
>>>> proof way to
>>>>> find errors. The parallel builds makes tracking the errors difficult
>> and
>>>> the
>>>>> point of error and end of the build a long distance apart.
>>> I usually search the logs for "rror:" and that's the first time something
>>> is reported
>>> whether by make or gcc or whatever. It may not be the root cause but it
>> gets
>>> me to the first report.
>>> Cutting any of these long reports down is always going to be possible to
>>> cut out the real issue. It's ok because it it's more than just an odd
>> setup
>>> issue on the host, someone will have to build locally to reproduce the
>>> issue.
>>> And then they will get the full output.
>>>>> As a result I question the value of the report and wonder if it should
>> be
>>>>> removed. The report adds overhead to the build as the logging process
>>>> needs to
>>>>> maintain a buffer of lines that is always updating. Your attention and
>>>> interest
>>>>> around this feature highlights how problematic it is so maybe it is
>>>> simpler and
>>>>> better to remove it and we leave users to find the error in the log
>> file.
>>>>> I am happy to accept the report has not worked as a feature, remove it
>>>> and in
>>>>> the process we recover some overheads in the logging area of the RSB?
>>>> I am not against the error report and I do not say it is a useless
>>>> feature. It is just that I found the message '  See error report: %s'
>>>> confusing in those cases where the report does not contain the error
>>>> at all because it is too short (the error report consists simply of the
>>>> last 400 lines of the build log).
>>>> To answer your question, I believe there is always a build log - no
>>>> matter whether the `--log` option is used or not. In this case, removing
>>>> the error report and pointing to the build log in case of error (for
>>>> example like '  See build log: %s') would certainly solve all my
>> concerns.
>>> But on the build@ reports, it is nice to have something. Many times it
>>> is possible to diagnose the issue. Just in the past fifteen minutes,
>> there
>>> was one which having the log made it clear that CentOS 7 and other older
>>> distributions need to use a newer GCC. Having the info in the build@
>>> message was more than enough to diagnose that.
>>>> On the other hand, implementing the error report took time and was
>>>> certainly done with good reason. I do not feel like I should be the one
>>>> deciding to remove it. Changing the message or simply closing
>>>> https://devel.rtems.org/ticket/4642   would also be perfectly valid for
>> me.
>>> Changing the message to encourage --log or whatever guidance for
>>> debug. I don't even mind it pointing to a URL with guidance on debugging
>>> RSB build issues.
>> When I understand Joel right, he would keep the error report and prefers
>> to change the message.
> In a perfect world, there would also be improvements on what's reported
> but we know there is no perfect solution.
>> This brings the discussion back to decide on an
>> appropriate text. To make progress, I suggests
>>     '  See error report: %s\n'
>>     '  Note: In some cases the error appears only in\n'
>>     '  the complete build log (see --log option)'
>> If your are OK with this text, I am happy to prepare a patch. I also
>> welcome any other suggestion. If we cannot find any solution, I prefer
>> to close my ticket #4642 without any action taken.
> I'm happy with text like that. Is there a ticket to improve the message
> or should #4642 have a comment and the message improved?
I am aiming at closing my ticket. I can add a comment to #4642,
referring to this mailing list discussion and summarizing its result.
Then a will post a patch which should close that ticket, provided the
patch gets accepted.
Greetings
Frank
> --joel
>> Greetings
>> fk
>>> --joel
>>>> Greetings ... and a happy new year to you
>>>> Frank
>>>> embedded brains GmbH
>>>> Herr Frank KÜHNDEL
>>>> Dornierstr. 4
>>>> 82178 Puchheim
>>>> Germany
>>>> email:frank.kuehndel at embedded-brains.de
>>>> phone:  +49-89-18 94 741 - 23
>>>> mobile: +49-176-15 22 06 - 11
>>>> fax:    +49-89-18 94 741 - 08
>>>> Registergericht: Amtsgericht München
>>>> Registernummer: HRB 157899
>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
