[PATCH 1/3] build: Format build items
Fri Jan 20 06:30:59 UTC 2023
On 17.01.23 22:52, Chris Johns wrote:
> On 17/1/2023 6:39 pm, Sebastian Huber wrote:
>> On 17.01.23 03:48, Chris Johns wrote:
>>> On 16/1/2023 6:56 pm, Sebastian Huber wrote:
>>>> On 16.01.23 01:35, Chris Johns wrote:
>>>>> On 13/1/2023 1:54 am, Sebastian Huber wrote:
>>>>>> On 12.01.23 15:44, Kinsey Moore wrote:
>>>>>>> The other two patches look fine to me. The use of dump() that results in this
>>>>>>> patch does several things:
>>>>>>> * Removal of whitespace
>>>>>>> This is fine for whitespace at the base level of indentation. Whitespace
>>>>>>> within an indented block may be more important for readability.
>>>>>>> * Removal of comments
>>>>>>> This is not good as they are exclusively used to annotate manually ordered
>>>>>>> blocks of test result expectations
>>>>>>> * Rearrangement of items in alphabetical order
>>>>>>> In general, rearrangement of top-level sections is good. For indented
>>>>>>> sections
>>>>>>> specifically in tst*.yml, this is bad for the above reaso
>>>>>> One goal of the new build system was to be able to alter the data through
>>>>>> scripts. This requires that the build items are human and machine readable and
>>>>>> writable. The Python YAML import/export does not preserve white space and
>>>>>> comments.
>>>>> Can someone edit the file and add a hex number?
>>>> Yes, you can manually use whatever format is understood by the YAML loader. When
>>>> you write the file with the YAML dumper, then the standard representation is
>>>> used.
>>> Are there python modules in rtems.git someone could import that reads and writes
>>> the YAML spec files? If not should we provide a module to do this? It could be
>>> `spec` so a user can use `import spec` after setting the import path.
>>> That is, if external scripts (and I encourage this) all used a common read and
>>> write type functionality the format consistency is relative to specific version
>>> of rtems.git being used. Updates become read then write.
>> The Python modules to work with specification items are in rtems-central.git.
>> This repository contains also a format specification of the build items.
> And how does that help here with this repo? I suggest you reconsider the
> accessibility of those modules before pushing scripted generation changes like
> this into rtems.git.
It was not my idea to use multiple repositories. Do you prefer now to
move everything back into rtems.git (tools, documentation)?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
