libbsd updates
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Jan 20 07:32:56 UTC 2023
Hello,
recently an internal discussion about updates in the libbsd started. All
who participated in the discussion agreed that we should move the
discussion to a public one. Below you can find the mail thread. It's
oldest mail first. Mails are split with lines of = signs. I removed some
duplicated mail text in case there were no inline comments. The
date/time of the mails are in my current locale which is UTC+1.
Best regards
Christian
On 2023-01-03 16:52, Thomas DOERFLER wrote:
> Hello,
> first of all I wish you all a healthy, happy and successful new year.
> Unfortunately I already have to re-raise an issue: One of our customers
> has asked us about the RTEMS libbsd update policy. Since we still use a
> rather old libbsd version, it contains "OpenSSL 1.1.1d-freebsd  10 Sep
> 2019", there are many openSSL fixes missing when using RTEMS, and this
> most likely is true for other parts of libbsd.
> IMHO we should find a way to overcome the current libbsd update blocking
> points and try to stay close to the FreeBSD code (maybe in a 1-3 month
> interval).
> AFAIK the big blocking point are the different views around changes of
> the file descriptor handling between RTEMS and BSD (this may be a bit
> off the real topic, I am not yet into the details). In the next week I
> would like to get things rolling to see the pros and cons of both
> possible implementations and I would be happy if those closely involved
> would support this.
> Apart from the current blocking point, can we agree that staying close
> the the FreeBSD code (with a 1-3 month update/sync interval) would be
> desirable?
> Kind regards to you all,
> Thomas.
On 2023-01-12 01:24, Gedare Bloom wrote:
> Hi Thomas,
> I think the goal you have stated is laudable and fits with the initial
> design goals of libbsd. I will take a closer look at this topic and
> report back soon, I hope. I have remained (purposefully) ignorant
> about libbsd evolution over time, but I guess it is time for me to
> learn a bit more and catch up.
>  From what I have understood about the current blocking issue, it has
> to do with the changes that were made to use FreeBSD File Descriptors
> and the VFS. However, one of the main problems that was noted actually
> appears to be just related to the size increase caused by the syscall
> glue implemented in a single .c file. So, I will plan to start my
> libbsd learning adventure by trying to split that .c file apart into
> separate build components to see how/if that alleviates the linked
> image size. If successful, that should get us closer.
> I think we can then revisit whether or not the FreeBSD File
> Descriptors themselves are in fact problematic.
> It would also be helpful to decide if we want to clarify any
> requirements for libbsd maintenance. So, for example, the ability to
> keep it updated on a rolling basis would require good automation and
> validation that changes/updates remain usable. It would appear that
> there are some minimum resource requirements that some users of libbsd
> would like to remain under if possible. To ensure that would require
> establishing what platform(s) have resource requirements for using
> libbsd, and adding configurations/testing to check for when those
> resources are exceeded by an update. Because it is entirely plausible
> that an update pulls in changes from upstream that causes the
> resources to grow.
> Gedare
On 2023-01-12 08:46, Sebastian Huber wrote:
> Hello Gedare,
> On 12.01.23 01:24, Gedare Bloom wrote:
>> Hi Thomas,
> yes, one of the goals of libbsd was to follow the FreeBSD upstream,
> however, I was the only one doing this work in the past and I was busy
> with other things in the last three years (mainly the RTEMS
> pre-qualification). We need a more automated way to keep libbsd up to
> date. My proposal is to focus on the master branch since the FreeBSD EOL
> is 31. December 2023. We could use FreeBSD 14 for the next production
> branch. The current libbsd synchronization support was designed to do
> updates from Subversion. With Git we can do things more efficiently. I
> would replace the libbsd build system with the one from RTEMS (waf +
> spec items). With the spec items we can more easily read the data in
> other scripts. For continuous and automatic updates I would do the
> following:
> 1. Check out the FreeBSD X branch.
> 2. Move all FreeBSD top-level directories under the new "freebsd"
> directory and merge in all updates from FreeBSD.
> 3. Gather the set of files imported from FreeBSD. Name the set F.
> 4. Pick a start FreeBSD commit C.
> 5. Make a patch from C to C + 1 for the file set F.
> 6. Cherry pick the patch to the associated libbsd branch, if this fails,
> send a message and stop.
> 7. Build libbsd for the reference BSP, if this fails, send a message and
> stop.
> 8. Run the tests for the reference BSP, if this fails, send a message
> and stop.
> 9. Set C to C + 1, go to 5.
> Update problems can be more easily fixed if you just have a single
> commit. This approach makes it easier to fix things directly in FreeBSD
> and then get the fixes automatically into libbsd. Individual commits
> make it possible to use git bisect.
> I already started to work on this.
> https://github.com/sebhub/rtems-libbsd/tree/master-update
> I updated the FreeBSD baseline from 2019-09-24 to 2020-02-09 (again no
> issues with the system calls). The problem areas during updates are UMA,
> sleep queues, callouts, and the introduction of SMP optimizations
> through per-processor data structures. I added the ntpd support and
> started with the integration of the VFS/NFS support. This was not easy
> since FreeBSD was quite active in these five months and touch a lot of
> code in the VFS/NFS area.
> All the embedded brains contributions are in the 6-freebsd-12 and the
> master branch. This is not the case for other contributions. If I
> proceed with the update of the master branch moving this stuff from the
> 6-freebsd-12 branch to master will get more difficult.
> I have two issues:
> 1. The system calls in a single RTEMS-specific file.
> 2. The use of FreeBSD file descriptors.
> Both issues are fixed by the patch set. I don't see a benefit in
> splitting the RTEMS-specific file into one file per system call. The
> original approach is still the best approach. I don't know why it was
> changed without a discussion on the RTEMS mailing list. It worked for
> years, it allows compiler optimizations, it is easy to review, and there
> are no issues during updates.
> I updated the patch set so that it doesn't require changes in RTEMS:
> https://github.com/sebhub/rtems-libbsd/tree/filedesc
> File descriptors on top of file descriptors make little sense. Also
> FreeBSD has some implementation overheads which are unnecessary in the
> RTEMS context in which the maximum file descriptor count is fixed at
> link time.
>> resources to grow.
> Yes, it is possible that changes in FreeBSD lead to a higher resource
> usage and it would be good to have tests which catch this. However, the
> current problems were not caused by FreeBSD changes. The really big
> issue is that we didn't manage to integrate FreeBSD changes in the last
> three years.
On 2023-01-12 19:12, Gedare Bloom wrote:
> On Thu, Jan 12, 2023 at 12:46 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello Gedare,
>>> Hi Thomas,
>> following:
>> stop.
>> and stop.
> Thanks for that description. It makes sense, and I think this is a
> good direction for us to be heading. However, we do have to resolve
> the "fork" that currently exists between master and 6-freebsd-12.
> Yes, we need to resolve this issue. Thank you for having patience so
> far with it. I have not been able to put much thought or energy to it
> before now.
>> I have two issues:
> It looks to me like it is reverted rather than fixed. Since Chris
> apparently found it necessary to change, it is best if we can resolve
> the difference between what he needed and what you need. Simply
> returning back to the prior state is not respectful to him. Similarly,
> to be respectful to you, we should understand the pros/cons of each
> approach and try to resolve them. I am willing to do some of this work
> on a voluntary (unpaid) basis to help the community move forward, but
> I suspect it will eventually require compromise (and code) from both
> of you.
>  From what I have seen, the reason that the syscalls were consolidated
> was to make it easier to work across related syscalls. Maintainability
> is decided by the *next* person to work on the code. It looks to me
> like it is considerably easier to find the RTEMS syscall layer in the
> consolidated approach, and to work across layers.
> There is also a performance benefit to allow the compiler to optimize
> the syscall away, but that also impacts debuggability if our syscall
> layer disappears. The tradeoffs between maintainability and
> debuggability vs performance appear to be fairly complicated in this
> space. There's not a great description to me yet of what is required
> for performance, while the documentation of libbsd has mostly favored
> maintainability as a primary objective. So I think that any argument
> to do something for performance reasons has to be accompanied by clear
> evidence that the performance improvement matters.
> I think the change was announced:
> https://lists.rtems.org/pipermail/devel/2021-July/068573.html
> This is just another outcome of our current way of handling change
> management. Changes can easily be lost in the email exchange.
>> link time.
> Are there any performance analyses that quantify the impact of the
> implementation overhead of FreeBSD File Descriptors? Again, this is
> about the tradeoff between maintainability and performance. i can't
> make value judgments about performance without understanding the
> resource constraints of the target platforms, and the performance
> metrics (code size, heap size, throughput?) that are used to decide if
> an optimization is worth sacrificing maintainability. It has always
> been my understanding that the libbsd strives for maintainability
> first and foremost. So to unilaterally reject code changes that reduce
> the maintenance burden (by keeping us closer to the vanilla FreeBSD
> code base) in the name of performance requires two things:
> 1. Evidence that the performance improvement is substantial.
> 2. Argument that the implementation of the performance improvement is
> the most maintainable way to achieve it.
> So far, I haven't seen either of these with respect to the runtime
> overheads. And I haven't seen a good argument that injecting the
> syscall implementations into FreeBSD is better than having them live
> separately in the rtemsbsd layer.
On 2023-01-13 08:26, Sebastian Huber wrote:
> On 12.01.23 19:12, Gedare Bloom wrote:
>>> I have two issues:
>> of you.
> I would not have looked into that if I had not experienced two problems:
> 1. The ntpd crashed somewhere in the area of file descriptors. I tried
> to debug this, but the code is too complex compared to just using the
> RTEMS file descriptors. This is why I removed the FreeBSD file
descriptors.
> 2. I updated a project using the old network stack and libusb to just
> use libbsd. Here I have a RAM limitation of 16MiB. Wasting at least 4MiB
> for unused stuff is not that great. This lead to the system call
> aggregation issue.
> What do you mean with "work across related syscalls"? For example, the
> socket related system call implementations are in uipc_syscalls.c. Here
> we had:
> #ifdef __rtems__
> static
> #endif /* __rtems__ */
> int
> sys_sendto(struct thread *td, struct sendto_args *uap)
>      struct msghdr msg;
>      struct iovec aiov;
>      msg.msg_name = __DECONST(void *, uap->to);
>      msg.msg_namelen = uap->tolen;
>      msg.msg_iov = &aiov;
>      msg.msg_iovlen = 1;
>      msg.msg_control = 0;
> #ifdef COMPAT_OLDSOCK
>      if (SV_PROC_FLAG(td->td_proc, SV_AOUT))
>          msg.msg_flags = 0;
> #endif
>      aiov.iov_base = __DECONST(void *, uap->buf);
>      aiov.iov_len = uap->len;
>      return (sendit(td, uap->s, &msg, uap->flags));
> #ifdef __rtems__
> ssize_t
> sendto(int socket, const void *message, size_t length, int flags,
>      const struct sockaddr *dest_addr, socklen_t dest_len)
>      struct thread *td = rtems_bsd_get_curthread_or_null();
>      struct sendto_args ua = {
>          .s = socket,
>          .buf = (caddr_t) message,
>          .len = length,
>          .flags = flags,
>          .to = dest_addr,
>          .tolen = dest_len
>      int error;
>      if (td != NULL) {
>          error = sys_sendto(td, &ua);
>      } else {
>          error = ENOMEM;
>      if (error == 0) {
>          return td->td_retval[0];
>      } else {
>          rtems_set_errno_and_return_minus_one(error);
> The sys_sendto() is unmodified and the RTEMS adoption is below the
> implementation. This is easy to review and understand. Everything is in
> one place. There are no issues during updates and I know what I am
> talking about:
> git log ./freebsd/sys/kern/uipc_syscalls.c | grep 'Update to F'
>      Update to FreeBSD stable/12 2019-09-23
>      Update to FreeBSD stable/12 2019-02-11
>      Update to FreeBSD stable/12 2019-01-16
>      Update to FreeBSD head 2018-11-15
>      Update to FreeBSD head 2018-09-17
>      Update to FreeBSD head 2018-06-01
>      Update to FreeBSD head 2018-04-01
>      Update to FreeBSD head 2017-12-01
>      Update to FreeBSD head 2017-08-01
>      Update to FreeBSD head 2017-04-04
>      Update to FreeBSD head 2016-12-10
>      Update to FreeBSD head 2016-08-23
>      Update to FreeBSD 9.3
>      Update to FreeBSD 9.2
>      Update to FreeBSD 8.4
> In general, the system call related area is not an issue during updates
> since the system call interface is pretty stable. System call stability
> is a very important thing for FreeBSD/Linux/etc.
>> Maintainability
>> is decided by the*next*  person to work on the code.
> So far I am the only one who expressed plans to synchronize libbsd with
> the upstream FreeBSD development.
>> It looks to me
> Moving things to a separate file instead of having it directly under the
> implementation function is considerably easier to find?
>> layer disappears.
> If you want to debug you have to reduce the optimization level anyway.
> You can use for example -fno-inline.
> Talking about maintainability here sounds fairly abstract to me. This
> should be underlined with concrete examples. In the master branch there
> is no kern_descrip.c which is a 4k LOC source file. I don't know how
> adding this file improves maintainability. The VFS/NFS support works
> without the FreeBSD file descriptors.
there
> Sorry, I didn't notice this e-mail before. In this time frame I was
> quite busy with the RTEMS pre-qualification activity and holidays.
>>> link time.
> If you are interested I suggest to build libbsd for the
> arm/xilinx_zynq_a9_qemu BSP with optimization disabled. Then step
> through a socket send/receive system call on the master and 6-freebsd-12
> branch and in particular getsock_cap().
On 2023-01-16 14:30, Christian MAUDERER wrote:
> Hello,
> I think we have a bit of a new situation here: There are two approaches
> to a problem, and it seems that no consent can be found with the usual
> discussions. May I suggest that we try a more top-down approach: Let's
> agree what are the important points that we want to reach and then try
> to evaluate the problem based on these?
> What I have seen in the discussions, the following points should be
> evaluated:
> - Maintainability: Who does the main maintenance work and how easy is it
> for them to do that work?
> - Extensibility: Who works with the code and how easy is it for them to
> contribute?
> - Debuggability: How easy is it to debug / understand a problem and the
> related code?
> - Code and RAM sizes (or other hardware requirements): What are the
> minimum requirements and do we meet them?
> - Performance: Which are our use cases and does it perform well enough
> in these?
> - Real time capabilities: Does the subsystem have any real time
> requirements?
> These could be valid for basically any part of RTEMS (so that list could
> be useful for further similar problems). We should try to find out where
> our focus for libbsd is. For example, I think that real time capability
> was never important for libbsd.
> Where do you see the focus for libbsd? Please feel free to add further
> points and rate the ones above.
> Based on what we agree as most important points, we then should analyze
> the suggested solutions. From my point of view, we have at least three
> mostly independent parts in this discussion:
> - Updated NFS support. I think it's clear that the target for all of us
> is that it works.
> - Libbsd file descriptors: Chris imported them to the 6-freebsd-12
> branch when adding the NFS support. Sebastian wants to get rid of them
> again.
> - Collected system calls: Different opinions where the system calls
> should be located.
> Did I miss a fourth part of the problem?
> Please note: Of course I'm biased because I talk a lot more with
> Sebastian than with Chris. Despite that I'll try to be as objective as
> possible in this discussion.
> Best regards
> Christian
On 2023-01-16 17:33, Thomas DOERFLER wrote:
> Hello,
> just my two cents regarding real time capability:
> The point should not only consider, whether a certain subsystem has real
> time requirements, but also whether a certain patch/solution influences
> the real time capabilities of RTEMS as a whole.
> wkr,
> Thomas.
On 2023-01-16 17:55, Joel Sherrill wrote:
> On Mon, Jan 16, 2023 at 10:33 AM Thomas DOERFLER
> <Thomas.Doerfler at embedded-brains.de
> <mailto:Thomas.Doerfler at embedded-brains.de>> wrote:
>     Hello,
>     real
influences
> libbsd made us realize that source transparency and compatibility is
a big
> factor and must be considered any time we import/reuse third party code.
> libbsd is a huge amount of code and it is of paramount importance to
> minimize changes and RTEMS special code. Doing so increases the
> maintenance burden and adds risk of introducing incompatibility with
> FreeBSD.
> If something from FreeBSD cannot be supported on RTEMS or (in this
> case) is too large for some desired targets, then a way must be found to
> make the FreeBSD import leaner. Perhaps a configuration option to avoid
> some memory allocations. Or a configuration option to disable the part of
> the code in question that pulls in what is not needed for the specific
> application and target in question.
> The RTEMS way is to make features optional and drop out cleanly.
> We do not have a history of hacking up ported package.
> libbsd's first order goal is source transparency to ease updates,
> maintenance, and avoid introducing bugs/incompatibilities.
> I have trouble believing that this is about performance and we don't
> make real-time claims about libbsd because that would mean FreeBSD
> made those claims and they don't. It is about functionality and
> compatibility. I'm sure FreeBSD has made their implementation as
> performant as possible but without a worry about memory consumption.
> The unnecessary code for this specific application/target needs to be
> identified and simply configured out.
> Transparency and compatibility override any other considerations or
> options.
> --joel
On 2023-01-17 11:38, Christian MAUDERER wrote:
> Hello Joel,
> Am 16.01.23 um 17:55 schrieb Joel Sherrill:
>>     Hello,
>>     real
>> influences
>> libbsd made us realize that source transparency and compatibility is a
>> big
>> FreeBSD.
part of
>> options.
> Is the transparency and compatibility a new point? From how I read your
> text it is mostly part of maintainability and debugability as well as a
> bit extensibility that I mentioned in my list earlier.
> Beneath that you added a point to the list that is related but not the
> same as code and RAM size:
> - Modularity: How well and easy the system can be adapted to target
> applications. Additionally: What is the official way to enable / disable
> modules in the subsystem.
> Best regards
> Christian
After this mail it has been suggested to continue the discussion on
devel and all agreed that the mails can be re-posted.
