[PATCH v2 0/1] RSB: Mitigate too short error reports
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Fri Jan 20 15:06:08 UTC 2023
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
Hello,
this is the promised patch to close my bug report #4642
https://devel.rtems.org/ticket/4642
"RSB: log.py tends to remove relevant error messages".
I tested it using Christian's Github CI - see his Email:
https://lists.rtems.org/pipermail/devel/2023-January/074099.html
You can see the automated build and test results of the "draft" pull
request for this patch here:
https://github.com/embedded-brains/rtems-source-builder/pull/4/checks
If you have a Github account (needed to see the details and artifacts),
you can see the new error report message at the end of the output of
failing builds, as for example here (click on the red-bubble at
"build toolchain" and scroll to the bottom):
https://github.com/embedded-brains/rtems-source-builder/actions/runs/3968465295/jobs/6801666558
Greetings
Frank
Frank Kühndel (1):
source-builder/sb/ereport.py | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
2.35.3
