[PATCH v2 1/1] RSB: Mitigate too short error reports
Fri Jan 20 21:53:10 UTC 2023
OK to push.
Thanks
On 21/1/2023 2:06 am, Frank Kuehndel wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> Close #4642
>  source-builder/sb/ereport.py | 4 +++-
>  1 file changed, 3 insertions(+), 1 deletion(-)
> diff --git a/source-builder/sb/ereport.py b/source-builder/sb/ereport.py
> index d8fb5f6..52ee2eb 100755
> --- a/source-builder/sb/ereport.py
> +++ b/source-builder/sb/ereport.py
> @@ -54,7 +54,9 @@ def generate(name, opts, header = None, footer = None):
>              name = name.replace('/', '-')
>              with open(name, 'w') as l:
>                  l.write(os.linesep.join(r))
> -            log.notice('  See error report: %s' % (name))
> +            log.notice(os.linesep.join(['  See error report: %s' % (name),
> +                '  Note: In some cases the error appears only in',
> +                '  the complete build log (see --log option)']))
>          except:
>              log.stderr('error: failure to create error report')
>              raise
