[PATCH] eng: Clarify use of extern "C"
Sebastian Huber
Mon Jan 23 09:57:43 UTC 2023
Close #4806.
eng/coding-file-hdr.rst | 3 +++
1 file changed, 3 insertions(+)
diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
index 3167670..e6f5b30 100644
--- a/eng/coding-file-hdr.rst
+++ b/eng/coding-file-hdr.rst
@@ -98,6 +98,9 @@ Use the following guidelines and template for C and C++ header files (here
* For C++ header files discard the ``extern "C"`` start and end sections.
+* The ``extern "C"`` is only required if the C header file contains function
+ declarations or inline function definitions.
.. code-block:: c
/* SPDX-License-Identifier: BSD-2-Clause */
2.35.3
