[PATCH] Add clock driver implementation group
Mon Jan 23 14:27:16 UTC 2023
Use standard wording in Clock Driver related files.
 bsps/arm/raspberrypi/clock/clockdrv.c   |  7 +++----
 bsps/or1k/generic_or1k/clock/clockdrv.c |  7 +++----
 bsps/riscv/riscv/clock/clockdrv.c       |  5 +++--
 bsps/shared/dev/clock/clockimpl.h       | 23 +++++++++++++----------
 cpukit/include/rtems/clockdrv.h         |  6 ++----
 5 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/bsps/arm/raspberrypi/clock/clockdrv.c b/bsps/arm/raspberrypi/clock/clockdrv.c
index 9954d41741..8d220d51ba 100644
--- a/bsps/arm/raspberrypi/clock/clockdrv.c
+++ b/bsps/arm/raspberrypi/clock/clockdrv.c
@@ -1,14 +1,13 @@
  * @file
- * @ingroup bsp_clock
+ * @ingroup RTEMSDriverClockImpl
- * @brief Raspberry Pi clock support.
+ * @brief This source file contains the implementation of the BCM2835 Clock
+ *   Driver.
- * BCM2835 Clock driver
  * Copyright (c) 2013 Alan Cudmore
  * Copyright (c) 2016 Pavel Pisa
diff --git a/bsps/or1k/generic_or1k/clock/clockdrv.c b/bsps/or1k/generic_or1k/clock/clockdrv.c
index 7b8a07fd3d..44f220e057 100644
--- a/bsps/or1k/generic_or1k/clock/clockdrv.c
+++ b/bsps/or1k/generic_or1k/clock/clockdrv.c
@@ -1,14 +1,13 @@
  * @file
- * @brief or1k clock support.
+ * @brief This source file contains the implementation of the or1k Clock
+ *   Driver.
- * generic_or1k Clock driver
  * COPYRIGHT (c) 2014-2015 Hesham ALMatary <heshamelmatary at gmail.com>
  * The license and distribution terms for this file may be
diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
index d183e65b94..28222c69db 100644
--- a/bsps/riscv/riscv/clock/clockdrv.c
+++ b/bsps/riscv/riscv/clock/clockdrv.c
@@ -1,9 +1,10 @@
  * @file
- * @brief riscv clock support.
+ * @brief This source file contains the implementation of the riscv Clock
+ *   Driver.
diff --git a/bsps/shared/dev/clock/clockimpl.h b/bsps/shared/dev/clock/clockimpl.h
index ccf6d3ab60..e922c0b320 100644
--- a/bsps/shared/dev/clock/clockimpl.h
+++ b/bsps/shared/dev/clock/clockimpl.h
@@ -3,9 +3,12 @@
  * @file
- * @brief Clock Tick Device Driver Shell
+ * @brief This header file contains the shared Clock Driver implementation.
+ * This header file shall only be included by a particular Clock Driver
+ * implementation source file.
@@ -44,18 +47,18 @@
-#ifdef Clock_driver_nanoseconds_since_last_tick
-#error "Update driver to use the timecounter instead of nanoseconds extension"
-#endif
- * @defgroup bsp_clock Clock Support
- * @ingroup RTEMSBSPsShared
+ * @defgroup RTEMSDriverClockImpl Clock Driver Implementation
- * @brief Clock support
+ * @brief This group contains the Clock Driver implementation.
+#ifdef Clock_driver_nanoseconds_since_last_tick
+#error "Update driver to use the timecounter instead of nanoseconds extension"
+#endif
 #if CLOCK_DRIVER_USE_FAST_IDLE && CLOCK_DRIVER_ISRS_PER_TICK
 #error "Fast Idle PLUS n ISRs per tick is not supported"
 #endif
diff --git a/cpukit/include/rtems/clockdrv.h b/cpukit/include/rtems/clockdrv.h
index 3d3a62a63f..cd55e1bfe5 100644
--- a/cpukit/include/rtems/clockdrv.h
+++ b/cpukit/include/rtems/clockdrv.h
@@ -5,9 +5,7 @@
- * @brief Clock Driver API
- * This file defines the Clock Driver API.
+ * @brief This header file defines the Clock Driver API.
@@ -50,7 +48,7 @@ extern "C" {
  * @ingroup RTEMSDeviceDrivers
- * @brief The Clock Driver API.
+ * @brief This group contains the Clock Driver API.
2.35.3
