[PATCH] intr: Add Interrupt Manager implementation group
Tue Jan 24 00:10:55 UTC 2023
Isn't there anything in the aarch64 or microblaze that should be in this
list?
Seems like there should be more files.
On Mon, Jan 23, 2023 at 9:13 AM Sebastian Huber <
> The shared BSP interrupt controller support code actually implements
> parts of the Interrupt Manager.
> Update #3706.
>  bsps/arm/altera-cyclone-v/include/bsp/irq.h |  2 +-
>  bsps/arm/beagle/irq/irq.c                   |  2 +-
>  bsps/arm/lpc176x/include/bsp/irq.h          |  4 +--
>  bsps/arm/lpc176x/irq/irq.c                  |  2 +-
>  bsps/arm/lpc24xx/include/bsp/irq.h          |  4 +--
>  bsps/arm/lpc24xx/irq/irq-dispatch.c         |  2 +-
>  bsps/arm/lpc24xx/irq/irq.c                  |  2 +-
>  bsps/arm/lpc32xx/include/bsp/irq.h          |  2 +-
>  bsps/include/bsp/irq-generic.h              | 32 ++++++++++-----------
>  bsps/include/bsp/irq-info.h                 |  2 +-
>  bsps/lm32/include/bsp/irq.h                 |  4 +--
>  bsps/mips/csb350/include/bsp/irq.h          |  4 +--
>  bsps/mips/hurricane/include/bsp/irq.h       |  4 +--
>  bsps/mips/jmr3904/include/bsp/irq.h         |  4 +--
>  bsps/mips/malta/include/bsp/irq.h           |  4 +--
>  bsps/mips/rbtx4925/include/bsp/irq.h        |  4 +--
>  bsps/mips/rbtx4938/include/bsp/irq.h        |  4 +--
>  bsps/mips/shared/irq/irq.c                  |  2 +-
>  bsps/powerpc/mpc55xxevb/include/bsp/irq.h   |  2 +-
>  bsps/shared/irq/irq-affinity.c              |  2 +-
>  bsps/shared/irq/irq-default-handler.c       |  2 +-
>  bsps/shared/irq/irq-default.c               |  2 +-
>  bsps/shared/irq/irq-enable-disable.c        |  2 +-
>  bsps/shared/irq/irq-entry-remove.c          |  2 +-
>  bsps/shared/irq/irq-generic.c               |  2 +-
>  bsps/shared/irq/irq-handler-install.c       |  2 +-
>  bsps/shared/irq/irq-handler-iterate.c       |  2 +-
>  bsps/shared/irq/irq-handler-remove.c        |  2 +-
>  bsps/shared/irq/irq-info.c                  |  2 +-
>  bsps/shared/irq/irq-legacy.c                |  2 +-
>  bsps/shared/irq/irq-lock.c                  |  2 +-
>  bsps/shared/irq/irq-raise-clear.c           |  2 +-
>  bsps/shared/irq/irq-record.c                |  2 +-
>  bsps/shared/irq/irq-server.c                |  2 +-
>  bsps/shared/irq/irq-shell.c                 |  2 +-
>  35 files changed, 59 insertions(+), 59 deletions(-)
> diff --git a/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> b/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> index 15d05ec632..d06bfa92f0 100644
> --- a/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> +++ b/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> @@ -52,7 +52,7 @@ extern "C" {
>   * @ingroup RTEMSBSPsARMCycV
> - * @ingroup bsp_interrupt
> + * @ingroup RTEMSImplClassicIntr
>   * @brief Intel Cyclone V Interrupt Support.
> diff --git a/bsps/arm/beagle/irq/irq.c b/bsps/arm/beagle/irq/irq.c
> index 29a4e391e8..0ae82aa95e 100644
> --- a/bsps/arm/beagle/irq/irq.c
> +++ b/bsps/arm/beagle/irq/irq.c
> @@ -1,7 +1,7 @@
>   * @file
>   * @ingroup arm_beagle
>   * @brief Interrupt support.
> diff --git a/bsps/arm/lpc176x/include/bsp/irq.h
> b/bsps/arm/lpc176x/include/bsp/irq.h
> index 19f8601771..8ec55e8b84 100644
> --- a/bsps/arm/lpc176x/include/bsp/irq.h
> +++ b/bsps/arm/lpc176x/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief LPC176X interrupt definitions.
> @@ -43,7 +43,7 @@
>  #endif
> - * @addtogroup bsp_interrupt
> + * @addtogroup RTEMSImplClassicIntr
> diff --git a/bsps/arm/lpc176x/irq/irq.c b/bsps/arm/lpc176x/irq/irq.c
> index 005002a647..dad212dfeb 100644
> --- a/bsps/arm/lpc176x/irq/irq.c
> +++ b/bsps/arm/lpc176x/irq/irq.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief LPC176X interrupt support.
> diff --git a/bsps/arm/lpc24xx/include/bsp/irq.h
> b/bsps/arm/lpc24xx/include/bsp/irq.h
> index 524a7f1f51..ff1135e48c 100644
> --- a/bsps/arm/lpc24xx/include/bsp/irq.h
> +++ b/bsps/arm/lpc24xx/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief LPC24XX interrupt definitions.
> @@ -43,7 +43,7 @@
>  #endif
> diff --git a/bsps/arm/lpc24xx/irq/irq-dispatch.c
> b/bsps/arm/lpc24xx/irq/irq-dispatch.c
> index b244b97b8a..3f12c88c5e 100644
> --- a/bsps/arm/lpc24xx/irq/irq-dispatch.c
> +++ b/bsps/arm/lpc24xx/irq/irq-dispatch.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief LPC24XX interrupt support.
> diff --git a/bsps/arm/lpc24xx/irq/irq.c b/bsps/arm/lpc24xx/irq/irq.c
> index a92763131a..025123addb 100644
> --- a/bsps/arm/lpc24xx/irq/irq.c
> +++ b/bsps/arm/lpc24xx/irq/irq.c
> @@ -3,7 +3,7 @@
>   * @file
> diff --git a/bsps/arm/lpc32xx/include/bsp/irq.h
> b/bsps/arm/lpc32xx/include/bsp/irq.h
> index ea3c116a58..582bcb9568 100644
> --- a/bsps/arm/lpc32xx/include/bsp/irq.h
> +++ b/bsps/arm/lpc32xx/include/bsp/irq.h
> @@ -51,7 +51,7 @@ extern "C" {
>   * @ingroup RTEMSBSPsARMLPC32XX
> diff --git a/bsps/include/bsp/irq-generic.h
> b/bsps/include/bsp/irq-generic.h
> index 1ff84ee7cd..bbfb1979f4 100644
> --- a/bsps/include/bsp/irq-generic.h
> +++ b/bsps/include/bsp/irq-generic.h
> @@ -3,10 +3,10 @@
>   * @file
> - * @brief This header file provides interfaces of the generic interrupt
> - *   controller support.
> + * @brief This header file provides interfaces of the Interrupt Manager
> + *   implementation.
> @@ -101,29 +101,29 @@ static inline rtems_vector_number
> bsp_interrupt_dispatch_index(
> - * @defgroup bsp_interrupt BSP Interrupt Support
> + * @defgroup RTEMSImplClassicIntr Interrupt Manager
> - * @ingroup RTEMSBSPsShared
> - * @brief Generic BSP Interrupt Support
> + * @brief This group contains the Interrupt Manager implementation.
> - * The BSP interrupt support manages a sequence of interrupt vector
> numbers
> - * greater than or equal to zero and less than @ref
> BSP_INTERRUPT_VECTOR_COUNT
> - * It provides methods to install, remove, and @ref
> - * bsp_interrupt_handler_dispatch() "dispatch" interrupt entries for each
> - * vector number.  It implements parts of the RTEMS interrupt manager.
> + * The Interrupt Manager implementation manages a sequence of interrupt
> vector
> + * numbers greater than or equal to zero and less than
> + * ``BSP_INTERRUPT_VECTOR_COUNT``.  It provides methods to install,
> remove, and
> + * dispatch interrupt entries for each vector number, see
> + * bsp_interrupt_dispatch_entries().
>   * The entry points to a list of interrupt entries are stored in a table
>   * (= dispatch table).
> - * You have to configure the BSP interrupt support in the <bsp/irq.h> file
> + * You have to configure the Interrupt Manager implementation in the
> <bsp/irq.h> file
>   * for each BSP.  For a minimum configuration you have to provide
> - * @ref BSP_INTERRUPT_VECTOR_COUNT.
>   * For boards with small memory requirements you can define
> - * @ref BSP_INTERRUPT_USE_INDEX_TABLE.  With an enabled index table the
> + * ``BSP_INTERRUPT_USE_INDEX_TABLE``.  With an enabled index table the
>   * dispatch table will be accessed via a small index table.  You can
> define the
> - * size of the dispatch table with @ref BSP_INTERRUPT_DISPATCH_TABLE_SIZE.
> + * size of the dispatch table with ``BSP_INTERRUPT_DISPATCH_TABLE_SIZE``.
>   * You have to provide some special routines in your BSP (follow the
> links for
>   * the details):
> @@ -175,7 +175,7 @@ static inline rtems_vector_number
>  void bsp_interrupt_handler_default(rtems_vector_number vector);
> - * @brief Initialize BSP interrupt support.
> + * @brief Initialize Interrupt Manager implementation.
>   * You must call this function before you can install, remove and dispatch
>   * interrupt entries.  There is no protection against concurrent
> diff --git a/bsps/include/bsp/irq-info.h b/bsps/include/bsp/irq-info.h
> index 25f05a9f69..c00f5c5daf 100644
> --- a/bsps/include/bsp/irq-info.h
> +++ b/bsps/include/bsp/irq-info.h
> @@ -3,7 +3,7 @@
>   * @file
>   *   controller support for the RTEMS Shell.
> diff --git a/bsps/lm32/include/bsp/irq.h b/bsps/lm32/include/bsp/irq.h
> index 709538d192..9b06fd5d7d 100644
> --- a/bsps/lm32/include/bsp/irq.h
> +++ b/bsps/lm32/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief BSP interrupt support for LM32.
> @@ -41,7 +41,7 @@
>  #include <stdint.h>
> diff --git a/bsps/mips/csb350/include/bsp/irq.h
> b/bsps/mips/csb350/include/bsp/irq.h
> index c98ad71803..c2f55c49e3 100644
> --- a/bsps/mips/csb350/include/bsp/irq.h
> +++ b/bsps/mips/csb350/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief interrupt definitions.
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/hurricane/include/bsp/irq.h
> b/bsps/mips/hurricane/include/bsp/irq.h
> index 83af94bc4a..af6a1aa1ee 100644
> --- a/bsps/mips/hurricane/include/bsp/irq.h
> +++ b/bsps/mips/hurricane/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/jmr3904/include/bsp/irq.h
> b/bsps/mips/jmr3904/include/bsp/irq.h
> index 6f0aa32618..1f80a1dc7a 100644
> --- a/bsps/mips/jmr3904/include/bsp/irq.h
> +++ b/bsps/mips/jmr3904/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief jmr3904 interrupt definitions.
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/malta/include/bsp/irq.h
> b/bsps/mips/malta/include/bsp/irq.h
> index f151ff2fe7..553fa523ee 100644
> --- a/bsps/mips/malta/include/bsp/irq.h
> +++ b/bsps/mips/malta/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief Malta Interrupt Definitions
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/rbtx4925/include/bsp/irq.h
> b/bsps/mips/rbtx4925/include/bsp/irq.h
> index 0fd181aef4..b255ddb464 100644
> --- a/bsps/mips/rbtx4925/include/bsp/irq.h
> +++ b/bsps/mips/rbtx4925/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/rbtx4938/include/bsp/irq.h
> b/bsps/mips/rbtx4938/include/bsp/irq.h
> index dfb488a0c3..5de3e20de8 100644
> --- a/bsps/mips/rbtx4938/include/bsp/irq.h
> +++ b/bsps/mips/rbtx4938/include/bsp/irq.h
> @@ -3,7 +3,7 @@
>   * @file
> @@ -45,7 +45,7 @@
>  #endif
> diff --git a/bsps/mips/shared/irq/irq.c b/bsps/mips/shared/irq/irq.c
> index 57816bd971..460da7a3f8 100644
> --- a/bsps/mips/shared/irq/irq.c
> +++ b/bsps/mips/shared/irq/irq.c
> @@ -1,7 +1,7 @@
>   * @file
> diff --git a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
> b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
> index 1bedd3a65a..84a2b12358 100644
> --- a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
> +++ b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
> @@ -485,7 +485,7 @@ rtems_status_code
> mpc55xx_intc_raise_software_irq(rtems_vector_number vector);
>  rtems_status_code mpc55xx_intc_clear_software_irq(rtems_vector_number
> vector);
> diff --git a/bsps/shared/irq/irq-affinity.c
> b/bsps/shared/irq/irq-affinity.c
> index c21468077b..dc105639c3 100644
> --- a/bsps/shared/irq/irq-affinity.c
> +++ b/bsps/shared/irq/irq-affinity.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the implementation of
>   *   rtems_interrupt_get_affinity() and rtems_interrupt_set_affinity().
> diff --git a/bsps/shared/irq/irq-default-handler.c
> b/bsps/shared/irq/irq-default-handler.c
> index 666d48aaa8..1458ceae40 100644
> --- a/bsps/shared/irq/irq-default-handler.c
> +++ b/bsps/shared/irq/irq-default-handler.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the default implementation of
>   *   bsp_interrupt_handler_default().
> diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
> index bd93bd72c6..39ee11118c 100644
> --- a/bsps/shared/irq/irq-default.c
> +++ b/bsps/shared/irq/irq-default.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   bsp_interrupt_vector_enable(), bsp_interrupt_vector_disable(), and
> diff --git a/bsps/shared/irq/irq-enable-disable.c
> b/bsps/shared/irq/irq-enable-disable.c
> index 75d3d5ec46..c9602de398 100644
> --- a/bsps/shared/irq/irq-enable-disable.c
> +++ b/bsps/shared/irq/irq-enable-disable.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   rtems_interrupt_get_attributes(),
> rtems_interrupt_vector_is_enabled(),
> diff --git a/bsps/shared/irq/irq-entry-remove.c
> b/bsps/shared/irq/irq-entry-remove.c
> index 6b43134a0c..6f603359fd 100644
> --- a/bsps/shared/irq/irq-entry-remove.c
> +++ b/bsps/shared/irq/irq-entry-remove.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   rtems_interrupt_entry_remove() and bsp_interrupt_entry_remove().
> diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
> index e899731a54..cf99b7207d 100644
> --- a/bsps/shared/irq/irq-generic.c
> +++ b/bsps/shared/irq/irq-generic.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the generic interrupt controller
> support
>   *   implementation.
> diff --git a/bsps/shared/irq/irq-handler-install.c
> b/bsps/shared/irq/irq-handler-install.c
> index 2474d792e6..75cd2c9822 100644
> --- a/bsps/shared/irq/irq-handler-install.c
> +++ b/bsps/shared/irq/irq-handler-install.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the rtems_interrupt_handler_install()
>   *   implementation.
> diff --git a/bsps/shared/irq/irq-handler-iterate.c
> b/bsps/shared/irq/irq-handler-iterate.c
> index 7437e8a43e..f7af6ee356 100644
> --- a/bsps/shared/irq/irq-handler-iterate.c
> +++ b/bsps/shared/irq/irq-handler-iterate.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   rtems_interrupt_handler_iterate().
> diff --git a/bsps/shared/irq/irq-handler-remove.c
> b/bsps/shared/irq/irq-handler-remove.c
> index cb32ba3b7c..ab46c67ab1 100644
> --- a/bsps/shared/irq/irq-handler-remove.c
> +++ b/bsps/shared/irq/irq-handler-remove.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   rtems_interrupt_handler_remove().
> diff --git a/bsps/shared/irq/irq-info.c b/bsps/shared/irq/irq-info.c
> index a52465ef09..8738771a43 100644
> --- a/bsps/shared/irq/irq-info.c
> +++ b/bsps/shared/irq/irq-info.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   bsp_interrupt_report() and bsp_interrupt_report_with_plugin().
> diff --git a/bsps/shared/irq/irq-legacy.c b/bsps/shared/irq/irq-legacy.c
> index 649b850095..6181b0c994 100644
> --- a/bsps/shared/irq/irq-legacy.c
> +++ b/bsps/shared/irq/irq-legacy.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the legacy interrupt controller
> support
>   *   implementation.
> diff --git a/bsps/shared/irq/irq-lock.c b/bsps/shared/irq/irq-lock.c
> index 58b7020a3b..568443718a 100644
> --- a/bsps/shared/irq/irq-lock.c
> +++ b/bsps/shared/irq/irq-lock.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   bsp_interrupt_lock() and bsp_interrupt_unlock().
> diff --git a/bsps/shared/irq/irq-raise-clear.c
> b/bsps/shared/irq/irq-raise-clear.c
> index 93e414b2d1..042c1a2b7a 100644
> --- a/bsps/shared/irq/irq-raise-clear.c
> +++ b/bsps/shared/irq/irq-raise-clear.c
> @@ -3,7 +3,7 @@
>   * @file
>   *   rtems_interrupt_clear().
> diff --git a/bsps/shared/irq/irq-record.c b/bsps/shared/irq/irq-record.c
> index 9f0a008d84..f48c0c732c 100644
> --- a/bsps/shared/irq/irq-record.c
> +++ b/bsps/shared/irq/irq-record.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the implementation of the interrupt
> event
>   *   recording support.
> diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
> index 8b9d82eb29..d099c6ff05 100644
> --- a/bsps/shared/irq/irq-server.c
> +++ b/bsps/shared/irq/irq-server.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the interrupt server implementation.
> diff --git a/bsps/shared/irq/irq-shell.c b/bsps/shared/irq/irq-shell.c
> index cf70f2ce1b..2667924076 100644
> --- a/bsps/shared/irq/irq-shell.c
> +++ b/bsps/shared/irq/irq-shell.c
> @@ -3,7 +3,7 @@
>   * @file
>   * @brief This source file contains the definition of
>   *   ::bsp_interrupt_shell_command.
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230123/375d777b/attachment-0001.htm>
