[PATCH 2/2] bsps/nand: Update Xilinx NAND driver
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Jan 26 18:31:00 UTC 2023
This resovles gcc warnings by updating to the latest Xilinx NAND
controller driver.
bsps/include/dev/nand/xnandpsu.h | 4 +++-
bsps/include/dev/nand/xnandpsu_bbm.h | 2 +-
bsps/include/dev/nand/xnandpsu_hw.h | 2 +-
bsps/include/dev/nand/xnandpsu_onfi.h | 2 +-
bsps/shared/dev/nand/VERSION | 22 +++++++++++++---------
bsps/shared/dev/nand/xnandpsu.c | 14 ++++++++------
bsps/shared/dev/nand/xnandpsu_bbm.c | 2 +-
bsps/shared/dev/nand/xnandpsu_onfi.c | 2 +-
8 files changed, 29 insertions(+), 21 deletions(-)
diff --git a/bsps/include/dev/nand/xnandpsu.h b/bsps/include/dev/nand/xnandpsu.h
index 3625299fb2..a93a74eb85 100644
--- a/bsps/include/dev/nand/xnandpsu.h
+++ b/bsps/include/dev/nand/xnandpsu.h
@@ -7,7 +7,7 @@
* @file xnandpsu.h
-* @addtogroup nandpsu_v1_10
+* @addtogroup Overview
* @details
@@ -152,6 +152,8 @@
* 1.10 akm 10/20/21 Fix gcc warnings.
* 1.10 akm 12/21/21 Validate input parameters before use.
* 1.10 akm 01/05/22 Remove assert checks form static and internal APIs.
+* 1.11 akm 03/31/22 Fix unused parameter warning.
+* 1.11 akm 03/31/22 Fix misleading-indentation warning.
* </pre>
diff --git a/bsps/include/dev/nand/xnandpsu_bbm.h b/bsps/include/dev/nand/xnandpsu_bbm.h
index 4d4fafffa3..b6b39dc990 100644
--- a/bsps/include/dev/nand/xnandpsu_bbm.h
+++ b/bsps/include/dev/nand/xnandpsu_bbm.h
@@ -7,7 +7,7 @@
* @file xnandpsu_bbm.h
* This file implements the Bad Block Management(BBM) functionality. This is
diff --git a/bsps/include/dev/nand/xnandpsu_hw.h b/bsps/include/dev/nand/xnandpsu_hw.h
index 47e6c8fddc..e3a648b136 100644
--- a/bsps/include/dev/nand/xnandpsu_hw.h
+++ b/bsps/include/dev/nand/xnandpsu_hw.h
@@ -7,7 +7,7 @@
* @file xnandpsu_hw.h
* This file contains identifiers and low-level macros/functions for the Arasan
diff --git a/bsps/include/dev/nand/xnandpsu_onfi.h b/bsps/include/dev/nand/xnandpsu_onfi.h
index 7523ff48ea..97ea3c404e 100644
--- a/bsps/include/dev/nand/xnandpsu_onfi.h
+++ b/bsps/include/dev/nand/xnandpsu_onfi.h
@@ -7,7 +7,7 @@
* @file xnandpsu_onfi.h
* This file defines all the ONFI 3.1 specific commands and values.
diff --git a/bsps/shared/dev/nand/VERSION b/bsps/shared/dev/nand/VERSION
index c0afe6e031..5e4eb00fe9 100644
--- a/bsps/shared/dev/nand/VERSION
+++ b/bsps/shared/dev/nand/VERSION
@@ -5,16 +5,20 @@ Import from:
https://github.com/Xilinx/embeddedsw.git
-commit 8a89579489c88ea5acd23d7d439ac928659c26cf
-Author: msreeram <manikanta.sreeram at xilinx.com>
-AuthorDate: Wed Apr 6 23:24:38 2022 -0600
+commit 5330a64c8efd14f0eef09befdbb8d3d738c33ec2
+Refs: <xilinx_v2022.2>
+Author: Nicole Baze <nicole.baze at xilinx.com>
+AuthorDate: Mon Oct 3 13:27:19 2022 -0700
Commit: Siva Addepalli <sivaprasad.addepalli at xilinx.com>
-CommitDate: Fri Apr 8 16:47:15 2022 +0530
+CommitDate: Fri Oct 7 10:26:16 2022 +0530
- update license file for EmbeddedSW 2022.1 release
+ xilpm: versal: server: Fix bug in AIE2 zeroization
- Update license file for EmbeddedSW 2022.1 release
+ There is a bug in AIE2 zeriozation function when polling for memory
+ zeroization complete. Currently the entire memory register is being
+ checked against zero but instead we need to check the bits specific
+ to the memory tiles. This patch updates the zeroization check by
+ adding a mask so that only the desired bits are checked for zero.
- Signed-off-by: Manikanta Sreeram <msreeram at xilinx.com>
- Acked-by : Meena Paleti <meena.paleti at xilinx.com>
+ Signed-off-by: Nicole Baze <nicole.baze at xilinx.com>
+ Acked-by: Jesus De Haro <jesus.de-haro at xilinx.com>
diff --git a/bsps/shared/dev/nand/xnandpsu.c b/bsps/shared/dev/nand/xnandpsu.c
index a2e2235906..89451d19f8 100644
--- a/bsps/shared/dev/nand/xnandpsu.c
+++ b/bsps/shared/dev/nand/xnandpsu.c
@@ -7,7 +7,7 @@
* @file xnandpsu.c
* This file contains the implementation of the interface functions for
@@ -88,6 +88,8 @@
* </pre>
@@ -175,7 +177,7 @@ static s32 XNandPsu_ProgramPage(XNandPsu *InstancePtr, u32 Target, u32 Page,
static s32 XNandPsu_ReadPage(XNandPsu *InstancePtr, u32 Target, u32 Page,
u32 Col, u8 *Buf);
-static s32 XNandPsu_CheckOnDie(XNandPsu *InstancePtr, OnfiParamPage *Param);
+static s32 XNandPsu_CheckOnDie(XNandPsu *InstancePtr);
static void XNandPsu_SetEccAddrSize(XNandPsu *InstancePtr);
@@ -380,7 +382,7 @@ static s32 XNandPsu_FlashInit(XNandPsu *InstancePtr)
XNandPsu_InitTimingMode(InstancePtr, &Param[Index]);
XNandPsu_InitFeatures(InstancePtr, &Param[Index]);
if ((!InstancePtr->Features.EzNand) != 0U) {
- Status =XNandPsu_CheckOnDie(InstancePtr,&Param[Index]);
+ Status =XNandPsu_CheckOnDie(InstancePtr);
if (Status != XST_SUCCESS) {
InstancePtr->Features.OnDie = 0U;
@@ -642,7 +644,7 @@ static void XNandPsu_InitTimingMode(XNandPsu *InstancePtr, OnfiParamPage *Param)
* @note None
s32 Status = XST_FAILURE;
u8 JedecId[2] = {0U};
@@ -1976,8 +1978,8 @@ static s32 XNandPsu_ReadPage(XNandPsu *InstancePtr, u32 Target, u32 Page,
RegVal |= XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK |
XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK;
- XNandPsu_WriteReg((InstancePtr)->Config.BaseAddress,
- XNANDPSU_INTR_STS_EN_OFFSET, RegVal);
+ XNandPsu_WriteReg((InstancePtr)->Config.BaseAddress,
+ XNANDPSU_INTR_STS_EN_OFFSET, RegVal);
/* Program Page Size */
XNandPsu_SetPageSize(InstancePtr);
/* Program Column, Page, Block address */
diff --git a/bsps/shared/dev/nand/xnandpsu_bbm.c b/bsps/shared/dev/nand/xnandpsu_bbm.c
index c43a2ba62f..dd59148536 100644
--- a/bsps/shared/dev/nand/xnandpsu_bbm.c
+++ b/bsps/shared/dev/nand/xnandpsu_bbm.c
@@ -7,7 +7,7 @@
* @file xnandpsu_bbm.c
* This file implements the Bad Block Management (BBM) functionality.
diff --git a/bsps/shared/dev/nand/xnandpsu_onfi.c b/bsps/shared/dev/nand/xnandpsu_onfi.c
index cd230f247f..0009722bfe 100644
--- a/bsps/shared/dev/nand/xnandpsu_onfi.c
+++ b/bsps/shared/dev/nand/xnandpsu_onfi.c
@@ -7,7 +7,7 @@
* @file xnandpsu_onfi.c
* This file contains the implementation of ONFI specific functions.
2.30.2
