[PATCH] score: Help static analysis
Joel Sherrill
joel at rtems.org
Sat Jan 28 15:57:50 UTC 2023
This only impacts one file and the change is precise so the short log
should be more specific.
Otherwise ok. I hope this makes it happy.
On Sat, Jan 28, 2023, 3:59 AM Sebastian Huber <
> Add an assert to _Thread_Initialize_scheduler_and_wait_nodes() which may
> help a static analyzer. Use a do/while loop since we have at least one
> scheduler.
> Update #4832.
> cpukit/score/src/threadinitialize.c | 7 +++++--
> 1 file changed, 5 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/src/threadinitialize.c
> b/cpukit/score/src/threadinitialize.c
> index 9b37206c6d..0d382853fd 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -139,7 +139,10 @@ static void
> * The application configuration ensures that we have at least one
> scheduler
> * configured.
> - while ( scheduler_index < _Scheduler_Count ) {
> + _Assert ( _Scheduler_Count >= 1 );
> + do {
> Priority_Control priority;
> if ( scheduler == config->scheduler ) {
> @@ -172,7 +175,7 @@ static void
> ( (uintptr_t) scheduler_node + _Scheduler_Node_size );
> ++scheduler;
> ++scheduler_index;
> + } while ( scheduler_index < _Scheduler_Count );
> * The thread is initialized to use exactly one scheduler node which is
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230128/642706af/attachment.htm>
