[PATCH rtems] grlib: Fix snprintf() overflow warnings from gcc 12
Mon Jan 30 15:03:02 UTC 2023
This is OK. Not ideal, but consistent with the current code at least.
The commit message is a bit wrong since it also fixes sprintf() messages.
We should probably replace the sprintf with snprintf especially where
there is a string being used (prefix). The prefix is usually (always?)
32 byte array, so it shouldn't ever be a problem (the compiler will
again complain).
On Fri, Jan 27, 2023 at 4:56 PM Joel Sherrill <joel at rtems.org> wrote:
> Updates #4662.
>  bsps/include/grlib/gpiolib.h           | 2 +-
>  bsps/shared/grlib/1553/b1553brm.c      | 2 +-
>  bsps/shared/grlib/1553/b1553rt.c       | 2 +-
>  bsps/shared/grlib/analog/gradcdac.c    | 2 +-
>  bsps/shared/grlib/can/grcan_internal.h | 2 +-
>  bsps/shared/grlib/can/occan.c          | 2 +-
>  bsps/shared/grlib/gpio/grgpio.c        | 4 ++--
>  bsps/shared/grlib/i2c/i2cmst.c         | 2 +-
>  bsps/shared/grlib/pwm/grpwm.c          | 2 +-
>  bsps/shared/grlib/spi/spictrl.c        | 2 +-
>  bsps/shared/grlib/spw/grspw.c          | 2 +-
>  bsps/shared/grlib/tmtc/grtc.c          | 2 +-
>  bsps/shared/grlib/tmtc/grtm.c          | 2 +-
>  bsps/shared/grlib/uart/apbuart_cons.c  | 2 +-
>  14 files changed, 15 insertions(+), 15 deletions(-)
> diff --git a/bsps/include/grlib/gpiolib.h b/bsps/include/grlib/gpiolib.h
> index 61f6fc9..c0f865f 100644
> --- a/bsps/include/grlib/gpiolib.h
> +++ b/bsps/include/grlib/gpiolib.h
> @@ -78,7 +78,7 @@ extern int gpiolib_irq_register(void *handle, void *func, void *arg);
>  /*** Driver Interface ***/
>  struct gpiolib_info {
> -       char            devName[64];
> +       char            devName[80];
>  struct gpiolib_drv_ops {
> diff --git a/bsps/shared/grlib/1553/b1553brm.c b/bsps/shared/grlib/1553/b1553brm.c
> index ee5f9fb..7e0b992 100644
> --- a/bsps/shared/grlib/1553/b1553brm.c
> +++ b/bsps/shared/grlib/1553/b1553brm.c
> @@ -119,7 +119,7 @@ struct irq_log_list {
>  typedef struct {
>         struct drvmgr_dev *dev; /* Driver manager device */
> -       char devName[32]; /* Device Name */
> +       char devName[52]; /* Device Name */
>         struct brm_reg *regs;
>         unsigned int memarea_base;
> diff --git a/bsps/shared/grlib/1553/b1553rt.c b/bsps/shared/grlib/1553/b1553rt.c
> index 43bbeaa..7a4e2535 100644
> --- a/bsps/shared/grlib/1553/b1553rt.c
> +++ b/bsps/shared/grlib/1553/b1553rt.c
> @@ -87,7 +87,7 @@ static rtems_driver_address_table b1553rt_driver = RT_DRIVER_TABLE_ENTRY;
>  typedef struct {
>      struct rt_reg *regs;
>      unsigned int ctrl_copy; /* Local copy of config register */
> diff --git a/bsps/shared/grlib/analog/gradcdac.c b/bsps/shared/grlib/analog/gradcdac.c
> index 3b1afa8..09f8760 100644
> --- a/bsps/shared/grlib/analog/gradcdac.c
> +++ b/bsps/shared/grlib/analog/gradcdac.c
> @@ -53,7 +53,7 @@
>  struct gradcdac_priv {
>         struct gradcdac_regs *regs;     /* Must be first */
> -       char devName[48];
> +       char devName[54];               /* Must be at least 48 per names */
>         unsigned int freq;
>         int irqno;
> diff --git a/bsps/shared/grlib/can/grcan_internal.h b/bsps/shared/grlib/can/grcan_internal.h
> index 16aabba..d27476a 100644
> --- a/bsps/shared/grlib/can/grcan_internal.h
> +++ b/bsps/shared/grlib/can/grcan_internal.h
> @@ -56,7 +56,7 @@ struct grcan_config {
>  struct grcan_priv {
>         unsigned int baseaddr, ram_base;
>         struct grcan_regs *regs;
>         int irq;
> diff --git a/bsps/shared/grlib/can/occan.c b/bsps/shared/grlib/can/occan.c
> index 51ffd07..a6b37ec 100644
> --- a/bsps/shared/grlib/can/occan.c
> +++ b/bsps/shared/grlib/can/occan.c
> @@ -226,7 +226,7 @@ typedef struct {
>  typedef struct {
> -       char devName[32];
> +       char devName[52];
>         SPIN_DECLARE(devlock);
>         /* hardware shortcuts */
> diff --git a/bsps/shared/grlib/gpio/grgpio.c b/bsps/shared/grlib/gpio/grgpio.c
> index d579432..711293d 100644
> --- a/bsps/shared/grlib/gpio/grgpio.c
> +++ b/bsps/shared/grlib/gpio/grgpio.c
> @@ -379,12 +379,12 @@ static int grgpio_gpiolib_get_info(void *handle, struct gpiolib_info *pinfo)
>                 /* Failed to get prefix, make sure of a unique FS name
>                  * by using the driver minor.
> -               snprintf(pinfo->devName, 64, "/dev/grgpio%d/%d", dev->minor_drv, portnr);
> +               snprintf(pinfo->devName, 80, "/dev/grgpio%d/%d", dev->minor_drv, portnr);
>         } else {
>                 /* Got special prefix, this means we have a bus prefix
>                  * And we should use our "bus minor"
> -               snprintf(pinfo->devName, 64, "/dev/%sgrgpio%d/%d", prefix, dev->minor_bus, portnr);
> +               snprintf(pinfo->devName, 80, "/dev/%sgrgpio%d/%d", prefix, dev->minor_bus, portnr);
>         return 0;
> diff --git a/bsps/shared/grlib/i2c/i2cmst.c b/bsps/shared/grlib/i2c/i2cmst.c
> index 68d4140..70c796b 100644
> --- a/bsps/shared/grlib/i2c/i2cmst.c
> +++ b/bsps/shared/grlib/i2c/i2cmst.c
> @@ -375,7 +375,7 @@ int i2cmst_init3(struct drvmgr_dev *dev)
>         gr_i2cmst_prv_t *priv;
>         char prefix[32];
> -       char devName[32];
> +       char devName[50];
>         int rc;
>         priv = (gr_i2cmst_prv_t *)dev->priv;
> diff --git a/bsps/shared/grlib/pwm/grpwm.c b/bsps/shared/grlib/pwm/grpwm.c
> index 22d0831..32d16a2 100644
> --- a/bsps/shared/grlib/pwm/grpwm.c
> +++ b/bsps/shared/grlib/pwm/grpwm.c
> @@ -169,7 +169,7 @@ struct grpwm_regs {
>  struct grpwm_priv {
>         struct grpwm_regs               *regs;
> -       char                            devName[32];
> +       char                            devName[52];
>         int                             irq;
>         int                             open;
> diff --git a/bsps/shared/grlib/spi/spictrl.c b/bsps/shared/grlib/spi/spictrl.c
> index d4b62a3..081d281 100644
> --- a/bsps/shared/grlib/spi/spictrl.c
> +++ b/bsps/shared/grlib/spi/spictrl.c
> @@ -251,7 +251,7 @@ int spictrl_init3(struct drvmgr_dev *dev)
>         struct spictrl_priv *priv;
>         char prefix[32];
> -       char devName[32];
> +       char devName[48];
>         int rc;
>         priv = (struct spictrl_priv *)dev->priv;
> diff --git a/bsps/shared/grlib/spw/grspw.c b/bsps/shared/grlib/spw/grspw.c
> index 15fc34f..80fb263 100644
> --- a/bsps/shared/grlib/spw/grspw.c
> +++ b/bsps/shared/grlib/spw/grspw.c
> @@ -108,7 +108,7 @@ typedef struct {
>  typedef struct {
>     /* configuration parameters */
> +   char devName[49]; /* Device Name */
>     LEON3_SPACEWIRE_Regs_Map *regs;
>     spw_config config;
> diff --git a/bsps/shared/grlib/tmtc/grtc.c b/bsps/shared/grlib/tmtc/grtc.c
> index f7c97c2..4cb9a06 100644
> --- a/bsps/shared/grlib/tmtc/grtc.c
> +++ b/bsps/shared/grlib/tmtc/grtc.c
> @@ -241,7 +241,7 @@ struct grtc_frame_pool {
>  struct grtc_priv {
>         struct grtc_regs        *regs;          /* TC Hardware Register MAP */
>         int                     irq;            /* IRQ number of TC core */
>         SPIN_DECLARE(devlock);                  /* spin-lock of registers */
> diff --git a/bsps/shared/grlib/tmtc/grtm.c b/bsps/shared/grlib/tmtc/grtm.c
> index f400696..a1b2a54 100644
> --- a/bsps/shared/grlib/tmtc/grtm.c
> +++ b/bsps/shared/grlib/tmtc/grtm.c
> @@ -367,7 +367,7 @@ struct grtm_ring {
>  struct grtm_priv {
>         struct grtm_regs        *regs;
>         int                     irq;
>         int                     minor;
> diff --git a/bsps/shared/grlib/uart/apbuart_cons.c b/bsps/shared/grlib/uart/apbuart_cons.c
> index e5f41f4..5d47b7f 100644
> --- a/bsps/shared/grlib/uart/apbuart_cons.c
> +++ b/bsps/shared/grlib/uart/apbuart_cons.c
> @@ -76,7 +76,7 @@ struct apbuart_priv {
>         struct apbuart_regs *regs;
>         struct rtems_termios_tty *tty;
> -       char devName[32];
> +       char devName[52];
>         volatile int sending;
>         int mode;
>         int cap;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
