[PATCH 1/3] bsps/stm32h7: import MT25TL01G QSPI memory low-level driver
Mon Jan 30 15:13:17 UTC 2023
On Fri, Jan 27, 2023 at 11:41 AM Karel Gardas <karel at functional.vision> wrote:
> Sponsored-By:   Precidata
No issue with the patch, but I think it is awkward to have this
"Sponsored-By" in an import patch.
>  .../stm/Components/mt25tl01g/mt25tl01g.c      | 1046 +++++++++++++++++
>  .../stm/Components/mt25tl01g/mt25tl01g.h      |  362 ++++++
>  .../stm/Components/mt25tl01g/mt25tl01g_conf.h |   68 ++
>  3 files changed, 1476 insertions(+)
>  create mode 100644 bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.c
>  create mode 100644 bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.h
>  create mode 100644 bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g_conf.h
> diff --git a/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.c b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.c
> new file mode 100644
> index 0000000000..740cdbbd27
> --- /dev/null
> +++ b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.c
> @@ -0,0 +1,1046 @@
> +/* SPDX-License-Identifier: BSD-3-Clause */
> +  * @file    MT25TL01G.c
> +  * @author  MCD Application Team
> +  * @brief   This file provides the MT25TL01G QSPI driver.
> +  * @attention
> +  * <h2><center>© Copyright (c) 2016 STMicroelectronics.
> +  * All rights reserved.</center></h2>
> +  * This software component is licensed by ST under BSD 3-Clause license,
> +  * the "License"; You may not use this file except in compliance with the
> +  * License. You may obtain a copy of the License at:
> +  *                        opensource.org/licenses/BSD-3-Clause
> +/* Includes ------------------------------------------------------------------*/
> +#include "mt25tl01g.h"
> +/** @addtogroup BSP
> +/** @addtogroup Components
> +/** @addtogroup MT25TL01G
> +  * @brief     This file provides a set of functions needed to drive the
> +  *             MT25TL01G QSPI memory.
> +/** @defgroup MT25TL01G_Exported_Functions MT25TL01G Exported Functions
> +  * @brief  Return the configuration of the QSPI memory.
> +  * @param  pInfo pointer on the configuration structure
> +  * @retval QSPI memory status
> +int32_t MT25TL01G_GetFlashInfo(MT25TL01G_Info_t *pInfo)
> +  pInfo->FlashSize          = MT25TL01G_FLASH_SIZE;
> +  pInfo->EraseSectorSize    = (2 * MT25TL01G_SUBSECTOR_SIZE);
> +  pInfo->ProgPageSize       = MT25TL01G_PAGE_SIZE;
> +  pInfo->EraseSectorsNumber = (MT25TL01G_FLASH_SIZE/pInfo->EraseSectorSize);
> +  pInfo->ProgPagesNumber    = (MT25TL01G_FLASH_SIZE/pInfo->ProgPageSize);
> +  return MT25TL01G_OK;
> +  * @brief  This function set the QSPI memory in 4-byte address mode
> +  *          SPI/QPI; 1-0-1/4-0-4
> +  * @param  Ctx Component object pointer
> +  * @param  Mode Interface mode
> +int32_t MT25TL01G_Enter4BytesAddressMode(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  QSPI_CommandTypeDef s_command;
> +  /* Initialize the command */
> +  s_command.InstructionMode   = (Mode == MT25TL01G_QPI_MODE) ? QSPI_INSTRUCTION_4_LINES : QSPI_INSTRUCTION_1_LINE;
> +  s_command.Instruction       = MT25TL01G_ENTER_4_BYTE_ADDR_MODE_CMD;
> +  s_command.AddressMode       = QSPI_ADDRESS_NONE;
> +  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
> +  s_command.DataMode          = QSPI_DATA_NONE;
> +  s_command.DummyCycles       = 0;
> +  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
> +  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
> +  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
> +  /*write enable */
> +  if( MT25TL01G_WriteEnable(Ctx,Mode)!=MT25TL01G_OK)
> +    return MT25TL01G_ERROR_COMMAND;
> +  /* Send the command */
> +  if (HAL_QSPI_Command(Ctx, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +  /* Configure automatic polling mode to wait the memory is ready */
> +  else if(MT25TL01G_AutoPollingMemReady(Ctx,Mode)!=MT25TL01G_OK)
> +  * @brief  Flash exit 4 Byte address mode. Effect 3/4 address byte commands only.
> +  *         SPI/QPI; 1-0-0/4-0-0
> +int32_t MT25TL01G_Exit4BytesAddressMode(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_EXIT_4_BYTE_ADDR_MODE_CMD;
> +  * @brief  Polling WIP(Write In Progress) bit become to 0
> +  *         SPI/QPI;4-0-4
> +int32_t MT25TL01G_AutoPollingMemReady(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  QSPI_AutoPollingTypeDef s_config;
> +  /* Configure automatic polling mode to wait for memory ready */
> +  s_command.InstructionMode   = QSPI_INSTRUCTION_4_LINES;
> +  s_command.Instruction       = MT25TL01G_READ_STATUS_REG_CMD;
> +  s_command.DataMode          = QSPI_DATA_4_LINES;
> +  s_command.DummyCycles       = 2;
> +  s_config.Match           = 0;
> +  s_config.MatchMode       = QSPI_MATCH_MODE_AND;
> +  s_config.Interval        = 0x10;
> +  s_config.AutomaticStop   = QSPI_AUTOMATIC_STOP_ENABLE;
> +  s_config.Mask            = MT25TL01G_SR_WIP | (MT25TL01G_SR_WIP <<8);
> +  s_config.StatusBytesSize = 2;
> +  if (HAL_QSPI_AutoPolling(Ctx, &s_command, &s_config, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +    return MT25TL01G_ERROR_AUTOPOLLING;
> +  * @brief  This function send a Write Enable and wait it is effective.
> +int32_t MT25TL01G_WriteEnable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  /* Enable write operations */
> +  s_command.Instruction       = MT25TL01G_WRITE_ENABLE_CMD;
> +  /* Configure automatic polling mode to wait for write enabling */
> +  s_config.Match           = MT25TL01G_SR_WREN | (MT25TL01G_SR_WREN << 8);
> +  s_config.Mask            = MT25TL01G_SR_WREN | (MT25TL01G_SR_WREN << 8);
> +  s_command.DataMode       = (Mode == MT25TL01G_QPI_MODE) ? QSPI_DATA_4_LINES : QSPI_DATA_1_LINE;
> +  * @brief  This function reset the (WEL) Write Enable Latch bit.
> +int32_t MT25TL01G_WriteDisable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_WRITE_DISABLE_CMD;
> +  * @brief  Writes an amount of data to the QSPI memory.
> +  *         SPI/QPI; 1-1-1/1-2-2/1-4-4/4-4-4
> +  * @param  pData Pointer to data to be written
> +  * @param  WriteAddr Write start address
> +  * @param  Size Size of data to write. Range 1 ~ 256
> +int32_t MT25TL01G_PageProgram(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t WriteAddr, uint32_t Size)
> +  switch(Mode)
> +  case MT25TL01G_SPI_MODE :                   /* 1-1-1 commands, Power on H/W default setting */
> +    s_command.InstructionMode = QSPI_INSTRUCTION_1_LINE;
> +    s_command.Instruction     = MT25TL01G_PAGE_PROG_CMD;
> +    s_command.AddressMode     = QSPI_ADDRESS_1_LINE;
> +    s_command.DataMode        = QSPI_DATA_1_LINE;
> +    break;
> +  case MT25TL01G_SPI_2IO_MODE :               /*  1-2-2 commands */
> +    s_command.Instruction     = MT25TL01G_EXT_DUAL_IN_FAST_PROG_CMD;
> +    s_command.AddressMode     = QSPI_ADDRESS_2_LINES;
> +    s_command.DataMode        = QSPI_DATA_2_LINES;
> +    break;
> +  case MT25TL01G_SPI_4IO_MODE :               /* 1-4-4 program commands */
> +    s_command.Instruction     = MT25TL01G_EXT_QUAD_IN_FAST_PROG_CMD;
> +    s_command.AddressMode     = QSPI_ADDRESS_4_LINES;
> +    break;
> +  case MT25TL01G_QPI_MODE :                   /* 4-4-4 commands */
> +    s_command.Instruction     = MT25TL01G_QUAD_IN_FAST_PROG_4_BYTE_ADDR_CMD;
> +    break;
> +  s_command.AddressSize       = QSPI_ADDRESS_32_BITS;
> +  s_command.Address           = WriteAddr;
> +  s_command.NbData            = Size;
> +  if (HAL_QSPI_Transmit(Ctx, pData, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +    return MT25TL01G_ERROR_TRANSMIT;
> +  * @brief  Reads an amount of data from the QSPI memory on DTR mode.
> +  *         SPI/QPI; 1-1-1/1-1-2/1-4-4/4-4-4
> +  * @param  pData Pointer to data to be read
> +  * @param  ReadAddr Read start address
> +  * @param  Size Size of data to read
> +int32_t MT25TL01G_ReadDTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
> +  switch(Mode)
> +  case MT25TL01G_SPI_MODE:                /* 1-1-1 commands, Power on H/W default setting */
> +    s_command.Instruction       = MT25TL01G_FAST_READ_4_BYTE_DTR_CMD;
> +    break;
> +  case MT25TL01G_SPI_2IO_MODE:           /* 1-1-2 read commands */
> +    s_command.Instruction       = MT25TL01G_DUAL_OUT_FAST_READ_DTR_CMD;
> +    break;
> +  case MT25TL01G_SPI_4IO_MODE:             /* 1-4-4 read commands */
> +    s_command.Instruction       = MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_DTR_CMD;
> +    break;
> +  case MT25TL01G_QPI_MODE:                 /* 4-4-4 commands */
> +    s_command.Instruction       = MT25TL01G_QUAD_INOUT_FAST_READ_DTR_CMD;
> +    break;
> +  /* Initialize the read command */
> +  s_command.DummyCycles       = MT25TL01G_DUMMY_CYCLES_READ_QUAD_DTR;
> +  s_command.Address           = ReadAddr;
> +  s_command.DdrMode           = QSPI_DDR_MODE_ENABLE;
> +  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_HALF_CLK_DELAY;
> +  /* Configure the command */
> +  /* Reception of the data */
> +  if (HAL_QSPI_Receive(Ctx, pData, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +    return MT25TL01G_ERROR_RECEIVE;
> +  * @brief  Reads an amount of data from the QSPI memory on STR mode.
> +int32_t MT25TL01G_ReadSTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
> +  switch(Mode)
> +  case MT25TL01G_SPI_MODE:           /* 1-1-1 read commands */
> +    s_command.Instruction       = MT25TL01G_FAST_READ_4_BYTE_ADDR_CMD;
> +    break;
> +  case MT25TL01G_SPI_2IO_MODE:           /* 1-2-2 read commands */
> +    s_command.Instruction       = MT25TL01G_DUAL_INOUT_FAST_READ_4_BYTE_ADDR_CMD;
> +    break;
> +    s_command.Instruction       = MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_ADDR_CMD;
> +    break;
> +    s_command.Instruction       = MT25TL01G_QUAD_INOUT_FAST_READ_CMD;
> +    break;
> +  s_command.DummyCycles       = MT25TL01G_DUMMY_CYCLES_READ;
> +  * @brief  Erases the specified block of the QSPI memory.
> +  *         MT25TL01G support 4K, 32K, 64K size block erase commands.
> +  *         SPI/QPI; 1-1-0/4-4-0
> +  * @param  BlockAddress Block address to erase
> +int32_t MT25TL01G_BlockErase(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode ,uint32_t BlockAddress, MT25TL01G_Erase_t BlockSize)
> +  switch(BlockSize)
> +  default :
> +  case MT25TL01G_ERASE_4K :
> +    s_command.Instruction     = MT25TL01G_SUBSECTOR_ERASE_4_BYTE_ADDR_CMD_4K;
> +    break;
> +  case MT25TL01G_ERASE_32K :
> +    s_command.Instruction     = MT25TL01G_SUBSECTOR_ERASE_CMD_32K;
> +    break;
> +  case MT25TL01G_ERASE_64K :
> +    s_command.Instruction     = MT25TL01G_SECTOR_ERASE_4_BYTE_ADDR_CMD;
> +    break;
> +  case MT25TL01G_ERASE_CHIP :
> +    return MT25TL01G_ChipErase(Ctx, Mode);
> +  /* Initialize the erase command */
> +  s_command.Address           = BlockAddress;
> +  MT25TL01G_WriteEnable(Ctx,Mode);
> +  MT25TL01G_AutoPollingMemReady(Ctx,Mode);
> +  * @brief  Whole chip erase.
> +int32_t MT25TL01G_ChipErase(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_DIE_ERASE_CMD;
> +  * @brief  Read Flash Status register value
> +  * @param  Value pointer to status register value
> +int32_t MT25TL01G_ReadStatusRegister(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *Value)
> +  /* Initialize the read flag status register command */
> +  s_command.NbData            = 1;
> +  if (HAL_QSPI_Receive(Ctx,Value, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +  * @brief  This function put QSPI memory in QPI mode (Quad I/O) from SPI mode.
> +  *         SPI -> QPI; 1-x-x -> 4-4-4
> +  *         SPI; 1-0-0
> +int32_t MT25TL01G_EnterQPIMode(QSPI_HandleTypeDef *Ctx)
> +  s_command.Instruction       = MT25TL01G_ENTER_QUAD_CMD;
> +  * @brief  This function put QSPI memory in SPI mode (Single I/O) from QPI mode.
> +  *         QPI -> SPI; 4-4-4 -> 1-x-x
> +  *         QPI; 4-0-0
> +int32_t MT25TL01G_ExitQPIMode(QSPI_HandleTypeDef *Ctx)
> +  s_command.Instruction       = MT25TL01G_EXIT_QUAD_CMD;
> +int32_t MT25TL01G_EnableMemoryMappedModeDTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  QSPI_MemoryMappedTypeDef s_mem_mapped_cfg;
> +  switch(Mode)
> +    break;
> +    break;
> +    break;
> +    break;
> +  /* Configure the command for the read instruction */
> +  /* Configure the memory mapped mode */
> +  s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE;
> +  s_mem_mapped_cfg.TimeOutPeriod     = 0;
> +  if (HAL_QSPI_MemoryMapped(Ctx, &s_command, &s_mem_mapped_cfg) != HAL_OK)
> +    return MT25TL01G_ERROR_MEMORYMAPPED;
> +int32_t MT25TL01G_EnableMemoryMappedModeSTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  switch(Mode)
> +    break;
> +    break;
> +    break;
> +    break;
> +  * @brief  Flash reset enable command
> +  *         SPI/QPI; 1-0-0, 4-0-0
> +int32_t MT25TL01G_ResetEnable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  /* Initialize the reset enable command */
> +  s_command.Instruction       = MT25TL01G_RESET_ENABLE_CMD;
> +  * @brief  Flash reset memory command
> +int32_t MT25TL01G_ResetMemory(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_RESET_MEMORY_CMD ;
> +  * @brief  Read Flash 3 Byte IDs.
> +  *         Manufacturer ID, Memory type, Memory density
> +  * @param  ID pointer to flash id value
> +int32_t MT25TL01G_ReadID(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *ID)
> +  /* Initialize the read ID command */
> +  s_command.Instruction       = (Mode == MT25TL01G_QPI_MODE) ? MT25TL01G_MULTIPLE_IO_READ_ID_CMD  : MT25TL01G_READ_ID_CMD;
> +  s_command.NbData            = 3;
> +  if (HAL_QSPI_Receive(Ctx, ID, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> +  * @brief  Program/Erases suspend. Interruption Program/Erase operations.
> +  *         After the device has entered Erase-Suspended mode,
> +  *         system can read any address except the block/sector being Program/Erased.
> +int32_t MT25TL01G_ProgEraseSuspend(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_PROG_ERASE_SUSPEND_CMD ;
> +  * @brief  Program/Erases resume.
> +int32_t MT25TL01G_ProgEraseResume(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_PROG_ERASE_RESUME_CMD;
> +  * @brief  Deep power down.
> +  *         The device is not active and all Write/Program/Erase instruction are ignored.
> +int32_t MT25TL01G_EnterDeepPowerDown(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_ENTER_DEEP_POWER_DOWN;
> +  * @brief  Release from deep power down.
> +  *         After CS# go high, system need wait tRES1 time for device ready.
> +int32_t MT25TL01G_ReleaseFromDeepPowerDown(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
> +  s_command.Instruction       = MT25TL01G_RELEASE_FROM_DEEP_POWER_DOWN ;
> +  * @brief  Read SECTOR PROTECTION Block register value.
> +  *         SPI; 1-0-1
> +  * @param  SPBRegister pointer to SPBRegister value
> +int32_t MT25TL01G_ReadSPBLockRegister(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *SPBRegister)
> +  /* Initialize the reading of SPB lock register command */
> +  s_command.Instruction       = MT25TL01G_READ_SECTOR_PROTECTION_CMD;
> +  if (HAL_QSPI_Receive(Ctx, SPBRegister, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
> diff --git a/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.h b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.h
> index 0000000000..c2994d38af
> --- /dev/null
> +++ b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.h
> @@ -0,0 +1,362 @@
> +  * @file    MT25TL01G.h
> +  * @brief   This file contains all the description of the MT25TL01G QSPI memory.
> +  * @attention
> +/* Define to prevent recursive inclusion -------------------------------------*/
> +#ifndef MT25TL01G_H
> +#define MT25TL01G_H
> +#ifdef __cplusplus
> + extern "C" {
> +#endif
> +#include "mt25tl01g_conf.h"
> +/** @defgroup MT25TL01G_Exported_Types
> +   typedef struct {
> +  uint32_t FlashSize;          /*!< Size of the flash */
> +  uint32_t EraseSectorSize;    /*!< Size of sectors for the erase operation */
> +  uint32_t EraseSectorsNumber; /*!< Number of sectors for the erase operation */
> +  uint32_t ProgPageSize;       /*!< Size of pages for the program operation */
> +  uint32_t ProgPagesNumber;    /*!< Number of pages for the program operation */
> +} MT25TL01G_Info;
> +/* MT25TL01G Component Error codes *********************************************/
> +#define MT25TL01G_OK                           0
> +#define MT25TL01G_ERROR_INIT                  -1
> +#define MT25TL01G_ERROR_COMMAND               -2
> +#define MT25TL01G_ERROR_TRANSMIT              -3
> +#define MT25TL01G_ERROR_RECEIVE               -4
> +#define MT25TL01G_ERROR_AUTOPOLLING           -5
> +#define MT25TL01G_ERROR_MEMORYMAPPED          -6
> +/**exported type **/
> +/******************MT25TL01G_Info_t**********************/
> +typedef struct
> +} MT25TL01G_Info_t;
> +/******************MT25TL01G_Transfer_t**********************/
> +typedef enum
> +  MT25TL01G_SPI_MODE = 0,                 /*!< 1-1-1 commands, Power on H/W default setting */
> +  MT25TL01G_SPI_2IO_MODE,                 /*!< 1-1-2, 1-2-2 read commands                   */
> +  MT25TL01G_SPI_4IO_MODE,                 /*!< 1-1-4, 1-4-4 read commands                   */
> +  MT25TL01G_QPI_MODE                      /*!< 4-4-4 commands                               */
> +} MT25TL01G_Interface_t;
> +typedef enum
> +  MT25TL01G_STR_TRANSFER = 0,             /* Single Transfer Rate */
> +  MT25TL01G_DTR_TRANSFER                  /* Double Transfer Rate */
> +} MT25TL01G_Transfer_t;
> +/******************MT25TL01G_DualFlash_t**********************/
> +typedef enum
> +  MT25TL01G_DUALFLASH_DISABLE = QSPI_DUALFLASH_DISABLE, /*!<  Single flash mode              */
> +  MT25TL01G_DUALFLASH_ENABLE  =QSPI_DUALFLASH_ENABLE
> +} MT25TL01G_DualFlash_t;
> +/******************MT25TL01G_Erase_t**********************/
> +typedef enum
> +  MT25TL01G_ERASE_4K = 0,                 /*!< 4K size Sector erase */
> +  MT25TL01G_ERASE_32K,                    /*!< 32K size Block erase */
> +  MT25TL01G_ERASE_64K,                    /*!< 64K size Block erase */
> +  MT25TL01G_ERASE_CHIP                    /*!< Whole chip erase     */
> +} MT25TL01G_Erase_t;
> +/** @defgroup MT25TL01G_Exported_Constants
> +  * @brief  MT25TL01G Configuration
> +#define MT25TL01G_FLASH_SIZE                  0x8000000 /* 2 * 512 MBits => 2 * 64MBytes => 128MBytes*/
> +#define MT25TL01G_SECTOR_SIZE                 0x10000   /* 2 * 1024 sectors of 64KBytes */
> +#define MT25TL01G_SUBSECTOR_SIZE              0x1000    /* 2 * 16384 subsectors of 4kBytes */
> +#define MT25TL01G_PAGE_SIZE                   0x100     /* 2 * 262144 pages of 256 bytes */
> +#define MT25TL01G_DIE_ERASE_MAX_TIME          460000
> +#define MT25TL01G_SECTOR_ERASE_MAX_TIME       1000
> +#define MT25TL01G_SUBSECTOR_ERASE_MAX_TIME    400
> +  * @brief  MT25TL01G Commands
> +/* Reset Operations */
> +#define MT25TL01G_RESET_ENABLE_CMD                     0x66
> +#define MT25TL01G_RESET_MEMORY_CMD                     0x99
> +/* Identification Operations */
> +#define MT25TL01G_READ_ID_CMD                          0x9E
> +#define MT25TL01G_READ_ID_CMD2                         0x9F
> +#define MT25TL01G_MULTIPLE_IO_READ_ID_CMD              0xAF
> +#define MT25TL01G_READ_SERIAL_FLASH_DISCO_PARAM_CMD    0x5A
> +/* Read Operations */
> +#define MT25TL01G_READ_CMD                             0x03
> +#define MT25TL01G_READ_4_BYTE_ADDR_CMD                 0x13
> +#define MT25TL01G_FAST_READ_CMD                        0x0B
> +#define MT25TL01G_FAST_READ_DTR_CMD                    0x0D
> +#define MT25TL01G_FAST_READ_4_BYTE_ADDR_CMD            0x0C
> +#define MT25TL01G_FAST_READ_4_BYTE_DTR_CMD             0x0E
> +#define MT25TL01G_DUAL_OUT_FAST_READ_CMD               0x3B
> +#define MT25TL01G_DUAL_OUT_FAST_READ_DTR_CMD           0x3D
> +#define MT25TL01G_DUAL_OUT_FAST_READ_4_BYTE_ADDR_CMD   0x3C
> +#define MT25TL01G_DUAL_INOUT_FAST_READ_CMD             0xBB
> +#define MT25TL01G_DUAL_INOUT_FAST_READ_DTR_CMD         0xBD
> +#define MT25TL01G_DUAL_INOUT_FAST_READ_4_BYTE_ADDR_CMD 0xBC
> +#define MT25TL01G_QUAD_OUT_FAST_READ_CMD               0x6B
> +#define MT25TL01G_QUAD_OUT_FAST_READ_DTR_CMD           0x6D
> +#define MT25TL01G_QUAD_OUT_FAST_READ_4_BYTE_ADDR_CMD   0x6C
> +#define MT25TL01G_QUAD_INOUT_FAST_READ_CMD             0xEB
> +#define MT25TL01G_QUAD_INOUT_FAST_READ_DTR_CMD         0xED
> +#define MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_ADDR_CMD 0xEC
> +#define MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_DTR_CMD  0xEE
> +/* Write Operations */
> +#define MT25TL01G_WRITE_ENABLE_CMD                     0x06
> +#define MT25TL01G_WRITE_DISABLE_CMD                    0x04
> +/* Register Operations */
> +#define MT25TL01G_READ_STATUS_REG_CMD                  0x05
> +#define MT25TL01G_WRITE_STATUS_REG_CMD                 0x01
> +#define MT25TL01G_READ_LOCK_REG_CMD                    0xE8
> +#define MT25TL01G_WRITE_LOCK_REG_CMD                   0xE5
> +#define MT25TL01G_READ_FLAG_STATUS_REG_CMD             0x70
> +#define MT25TL01G_CLEAR_FLAG_STATUS_REG_CMD            0x50
> +#define MT25TL01G_READ_NONVOL_CFG_REG_CMD              0xB5
> +#define MT25TL01G_WRITE_NONVOL_CFG_REG_CMD             0xB1
> +#define MT25TL01G_READ_VOL_CFG_REG_CMD                 0x85
> +#define MT25TL01G_WRITE_VOL_CFG_REG_CMD                0x81
> +#define MT25TL01G_READ_ENHANCED_VOL_CFG_REG_CMD        0x65
> +#define MT25TL01G_WRITE_ENHANCED_VOL_CFG_REG_CMD       0x61
> +#define MT25TL01G_READ_EXT_ADDR_REG_CMD                0xC8
> +#define MT25TL01G_WRITE_EXT_ADDR_REG_CMD               0xC5
> +/* Program Operations */
> +#define MT25TL01G_PAGE_PROG_CMD                        0x02
> +#define MT25TL01G_PAGE_PROG_4_BYTE_ADDR_CMD            0x12
> +#define MT25TL01G_DUAL_IN_FAST_PROG_CMD                0xA2
> +#define MT25TL01G_EXT_DUAL_IN_FAST_PROG_CMD            0xD2
> +#define MT25TL01G_QUAD_IN_FAST_PROG_CMD                0x32
> +#define MT25TL01G_EXT_QUAD_IN_FAST_PROG_CMD            0x38
> +#define MT25TL01G_QUAD_IN_FAST_PROG_4_BYTE_ADDR_CMD    0x34
> +/* Erase Operations */
> +#define MT25TL01G_SUBSECTOR_ERASE_CMD_4K               0x20
> +#define MT25TL01G_SUBSECTOR_ERASE_4_BYTE_ADDR_CMD_4K   0x21
> +#define MT25TL01G_SUBSECTOR_ERASE_CMD_32K              0x52
> +#define MT25TL01G_SECTOR_ERASE_CMD                     0xD8
> +#define MT25TL01G_SECTOR_ERASE_4_BYTE_ADDR_CMD         0xDC
> +#define MT25TL01G_DIE_ERASE_CMD                        0xC7
> +#define MT25TL01G_PROG_ERASE_RESUME_CMD                0x7A
> +#define MT25TL01G_PROG_ERASE_SUSPEND_CMD               0x75
> +/* One-Time Programmable Operations */
> +#define MT25TL01G_READ_OTP_ARRAY_CMD                   0x4B
> +#define MT25TL01G_PROG_OTP_ARRAY_CMD                   0x42
> +/* 4-byte Address Mode Operations */
> +#define MT25TL01G_ENTER_4_BYTE_ADDR_MODE_CMD           0xB7
> +#define MT25TL01G_EXIT_4_BYTE_ADDR_MODE_CMD            0xE9
> +/* Quad Operations */
> +#define MT25TL01G_ENTER_QUAD_CMD                       0x35
> +#define MT25TL01G_EXIT_QUAD_CMD                        0xF5
> +#define MT25TL01G_ENTER_DEEP_POWER_DOWN                0xB9
> +#define MT25TL01G_RELEASE_FROM_DEEP_POWER_DOWN         0xAB
> +/*ADVANCED SECTOR PROTECTION Operations*/
> +#define MT25TL01G_READ_SECTOR_PROTECTION_CMD           0x2D
> +#define MT25TL01G_PROGRAM_SECTOR_PROTECTION            0x2C
> +#define MT25TL01G_READ_PASSWORD_CMD                    0x27
> +#define MT25TL01G_WRITE_PASSWORD_CMD                   0x28
> +#define MT25TL01G_UNLOCK_PASSWORD_CMD                  0x29
> +#define MT25TL01G_READ_GLOBAL_FREEZE_BIT               0xA7
> +#define MT25TL01G_READ_VOLATILE_LOCK_BITS              0xE8
> +#define MT25TL01G_WRITE_VOLATILE_LOCK_BITS             0xE5
> +    /*ADVANCED SECTOR PROTECTION Operations with 4-Byte Address*/
> +#define MT25TL01G_WRITE_4_BYTE_VOLATILE_LOCK_BITS      0xE1
> +#define MT25TL01G_READ_4_BYTE_VOLATILE_LOCK_BITS       0xE0
> +    /*One Time Programmable Operations */
> +#define MT25TL01G_READ_OTP_ARRAY                       0x4B
> +#define MT25TL01G_PROGRAM_OTP_ARRAY                    0x42
> +  * @brief  MT25TL01G Registers
> +/* Status Register */
> +#define MT25TL01G_SR_WIP                      ((uint8_t)0x01)    /*!< Write in progress */
> +#define MT25TL01G_SR_WREN                     ((uint8_t)0x02)    /*!< Write enable latch */
> +#define MT25TL01G_SR_BLOCKPR                  ((uint8_t)0x5C)    /*!< Block protected against program and erase operations */
> +#define MT25TL01G_SR_PRBOTTOM                 ((uint8_t)0x20)    /*!< Protected memory area defined by BLOCKPR starts from top or bottom */
> +#define MT25TL01G_SR_SRWREN                   ((uint8_t)0x80)    /*!< Status register write enable/disable */
> +/* Non volatile Configuration Register */
> +#define MT25TL01G_NVCR_NBADDR                 ((uint16_t)0x0001) /*!< 3-bytes or 4-bytes addressing */
> +#define MT25TL01G_NVCR_SEGMENT                ((uint16_t)0x0002) /*!< Upper or lower 128Mb segment selected by default */
> +#define MT25TL01G_NVCR_DUAL                   ((uint16_t)0x0004) /*!< Dual I/O protocol */
> +#define MT25TL01G_NVCR_QUAB                   ((uint16_t)0x0008) /*!< Quad I/O protocol */
> +#define MT25TL01G_NVCR_RH                     ((uint16_t)0x0010) /*!< Reset/hold */
> +#define MT25TL01G_NVCR_DTRP                   ((uint16_t)0x0020) /*!< Double transfer rate protocol */
> +#define MT25TL01G_NVCR_ODS                    ((uint16_t)0x01C0) /*!< Output driver strength */
> +#define MT25TL01G_NVCR_XIP                    ((uint16_t)0x0E00) /*!< XIP mode at power-on reset */
> +#define MT25TL01G_NVCR_NB_DUMMY               ((uint16_t)0xF000) /*!< Number of dummy clock cycles */
> +/* Volatile Configuration Register */
> +#define MT25TL01G_VCR_WRAP                    ((uint8_t)0x03)    /*!< Wrap */
> +#define MT25TL01G_VCR_XIP                     ((uint8_t)0x08)    /*!< XIP */
> +#define MT25TL01G_VCR_NB_DUMMY                ((uint8_t)0xF0)    /*!< Number of dummy clock cycles */
> +/* Extended Address Register */
> +#define MT25TL01G_EAR_HIGHEST_SE              ((uint8_t)0x03)    /*!< Select the Highest 128Mb segment */
> +#define MT25TL01G_EAR_THIRD_SEG               ((uint8_t)0x02)    /*!< Select the Third 128Mb segment */
> +#define MT25TL01G_EAR_SECOND_SEG              ((uint8_t)0x01)    /*!< Select the Second 128Mb segment */
> +#define MT25TL01G_EAR_LOWEST_SEG              ((uint8_t)0x00)    /*!< Select the Lowest 128Mb segment (default) */
> +/* Enhanced Volatile Configuration Register */
> +#define MT25TL01G_EVCR_ODS                    ((uint8_t)0x07)    /*!< Output driver strength */
> +#define MT25TL01G_EVCR_RH                     ((uint8_t)0x10)    /*!< Reset/hold */
> +#define MT25TL01G_EVCR_DTRP                   ((uint8_t)0x20)    /*!< Double transfer rate protocol */
> +#define MT25TL01G_EVCR_DUAL                   ((uint8_t)0x40)    /*!< Dual I/O protocol */
> +#define MT25TL01G_EVCR_QUAD                   ((uint8_t)0x80)    /*!< Quad I/O protocol */
> +/* Flag Status Register */
> +#define MT25TL01G_FSR_NBADDR                  ((uint8_t)0x01)    /*!< 3-bytes or 4-bytes addressing */
> +#define MT25TL01G_FSR_PRERR                   ((uint8_t)0x02)    /*!< Protection error */
> +#define MT25TL01G_FSR_PGSUS                   ((uint8_t)0x04)    /*!< Program operation suspended */
> +#define MT25TL01G_FSR_PGERR                   ((uint8_t)0x10)    /*!< Program error */
> +#define MT25TL01G_FSR_ERERR                   ((uint8_t)0x20)    /*!< Erase error */
> +#define MT25TL01G_FSR_ERSUS                   ((uint8_t)0x40)    /*!< Erase operation suspended */
> +#define MT25TL01G_FSR_READY                   ((uint8_t)0x80)    /*!< Ready or command in progress */
> +int32_t MT25TL01G_GetFlashInfo(MT25TL01G_Info_t *pInfo);
> +int32_t MT25TL01G_Enter4BytesAddressMode(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_Exit4BytesAddressMode(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_AutoPollingMemReady(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +/* Register/Setting Commands *************************************************/
> +int32_t MT25TL01G_WriteEnable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_BlockErase(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint32_t BlockAddress, MT25TL01G_Erase_t BlockSize);
> +int32_t MT25TL01G_ChipErase(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_PageProgram(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t WriteAddr, uint32_t Size);
> +int32_t MT25TL01G_ReadSTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size);
> +int32_t MT25TL01G_ReadDTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size);
> +int32_t MT25TL01G_ReadStatusRegister(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *Value);
> +int32_t MT25TL01G_EnterQPIMode(QSPI_HandleTypeDef *Ctx);
> +int32_t MT25TL01G_ExitQPIMode(QSPI_HandleTypeDef *Ctx);
> +int32_t MT25TL01G_EnableMemoryMappedModeSTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_EnableMemoryMappedModeDTR(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_WriteDisable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_ReadID(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *ID);
> +int32_t MT25TL01G_ResetMemory(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_ResetEnable(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_ReadSPBLockRegister(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *SPBRegister);
> +int32_t MT25TL01G_ReleaseFromDeepPowerDown(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_EnterDeepPowerDown(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_ProgEraseResume(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +int32_t MT25TL01G_ProgEraseSuspend(QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode);
> +#ifdef __cplusplus
> +#endif
> +#endif /* __MT25TL01G_H */
> +/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
> diff --git a/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g_conf.h b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g_conf.h
> index 0000000000..77479f8b12
> --- /dev/null
> +++ b/bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g_conf.h
> @@ -0,0 +1,68 @@
> +  * @file    mt25tl01g_conf_template.h
> +  * @attention
> +  * <h2><center>© Copyright (c) 2019 STMicroelectronics.
> +#ifndef MT25TL01G_CONF_H
> +#define MT25TL01G_CONF_H
> +#ifdef __cplusplus
> + extern "C" {
> +#endif
> +#include "stm32h7xx.h"
> +#include "stm32h7xx_hal.h"
> +#define CONF_MT25TL01G_READ_ENHANCE      0                       /* MMP performance enhance reade enable/disable */
> +#define CONF_QSPI_ODS                   MT25TL01G_CR_ODS_15
> +#define CONF_QSPI_DUMMY_CLOCK                 8U
> +/* Dummy cycles for STR read mode */
> +#define MT25TL01G_DUMMY_CYCLES_READ_QUAD      8U
> +#define MT25TL01G_DUMMY_CYCLES_READ           8U
> +/* Dummy cycles for DTR read mode */
> +#define MT25TL01G_DUMMY_CYCLES_READ_DTR       6U
> +#define MT25TL01G_DUMMY_CYCLES_READ_QUAD_DTR  8U
> +#ifdef __cplusplus
> +#endif
> +#endif /* MT25TL01G_CONF_H */
> 2.25.1
> devel mailing list
> devel at rtems.org
