[RSB 5] Remove aarch64 and microblaze from RSB on 5 branch
Mon Jan 30 20:13:57 UTC 2023
OK to push
Thanks
On 31/1/2023 1:44 am, Joel Sherrill wrote:
> Closes #4555.
>  rtems/config/5/rtems-aarch64.bset    | 4 ----
>  rtems/config/5/rtems-all.bset        | 2 --
>  rtems/config/5/rtems-microblaze.bset | 3 ---
>  rtems/config/5/rtems-tier-4.bset     | 1 -
>  4 files changed, 10 deletions(-)
>  delete mode 100644 rtems/config/5/rtems-aarch64.bset
>  delete mode 100644 rtems/config/5/rtems-microblaze.bset
> diff --git a/rtems/config/5/rtems-aarch64.bset b/rtems/config/5/rtems-aarch64.bset
> deleted file mode 100644
> index f38aff3..0000000
> --- a/rtems/config/5/rtems-aarch64.bset
> +++ /dev/null
> @@ -1,4 +0,0 @@
> -%define release 1
> -%define rtems_arch aarch64
> -%define with_libgomp
> -%include 5/rtems-default.bset
> diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
> index 00ccfae..81076e4 100644
> --- a/rtems/config/5/rtems-all.bset
> +++ b/rtems/config/5/rtems-all.bset
> @@ -1,11 +1,9 @@
> -5/rtems-aarch64
>  5/rtems-arm
>  5/rtems-bfin
>  5/rtems-epiphany
>  5/rtems-i386
>  5/rtems-lm32
>  5/rtems-m68k
> -5/rtems-microblaze
>  5/rtems-mips
>  5/rtems-moxie
>  5/rtems-nios2
> diff --git a/rtems/config/5/rtems-microblaze.bset b/rtems/config/5/rtems-microblaze.bset
> index e5c23af..0000000
> --- a/rtems/config/5/rtems-microblaze.bset
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -%define release 1
> -%define rtems_arch microblaze
> diff --git a/rtems/config/5/rtems-tier-4.bset b/rtems/config/5/rtems-tier-4.bset
> index 24d392d..042f2a0 100644
> --- a/rtems/config/5/rtems-tier-4.bset
> +++ b/rtems/config/5/rtems-tier-4.bset
> @@ -5,6 +5,5 @@
>  # anyone working on adding a BSP.
>  5/rtems-epiphany
> -5/rtems-microblaze
>  5/rtems-riscv
>  5/rtems-x86_64
