Question w.r.t. crash inside select call from libbsd.
Karel Gardas karel at functional.vision
Tue Jan 31 13:17:53 UTC 2023
On 1/31/23 07:30, Sebastian Huber wrote:
>> so with zone being NULL the crash is expected here. However I'm still
>> curious if this is libbsd issue or my issue with naive configuration?
> Did you use select() before libbsd is initialized? Do you have more than
> 64 file descriptors? In this case the fd set type is too small and you
> have a stack overflow.
And this is exactly what was happening and why I increase STACK size
insanely. Anyway, thanks to your help, this is no longer happening.
> Which branch of libbsd do you use? Maybe try out
> the other branch as well.
master. I've thought this is were development happens, isn't it?
Also noted interesting thing. If I modify buildset to remove all USB, I
still get linked error USB related (missing functions) due to functions
being used from device-nexus.h. Is this current behavior or have I did
anything wrong again?
E.g. stm32h7 USB setup in libbsd is wrong for my board (causes RTEMS
crash) so I've tried to disable that by build set modification (all
dev_usb* = off) and this does not helped hence I've modified
device-nexus.h also to not use dwg at all.
Hmm, looks like patch like attach may solve the issue? At least it did
for my case here. But I don't know if this is the right way to attack
this issue.
>  From the 16MiB you already waste 4MiB for unused features if you use
> the latest 6-freebsd-12 branch of libbsd.
No, master here. Also I've not attempted to optimize for size yet as the
project is currently still not done yet.
Thanks!
Karel
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230131/b2d8d9ce/attachment.bin>
