[PATCH rtems-source-builder v2] bare/config: add renode rsb installation config
Chris Johns
chrisj at rtems.org
Tue Jul 18 01:44:13 UTC 2023
On 12/7/2023 6:43 pm, Muhammad Sulthan Mazaya wrote:
> Use the design of how qemu handle config files + add version number to
> the config file name.
> bare/config/devel/renode-1.13.3-1.cfg | 11 ++++++
> bare/config/devel/renode.bset | 7 ++++
> source-builder/config/renode-1.13.3.cfg | 7 ++++
> source-builder/config/renode-common-1.cfg | 45 +++++++++++++++++++++++
> 4 files changed, 70 insertions(+)
> create mode 100644 bare/config/devel/renode-1.13.3-1.cfg
> create mode 100644 bare/config/devel/renode.bset
> create mode 100644 source-builder/config/renode-1.13.3.cfg
What happens if a new dot release comes out? Maybe this should be renode-1.cfg
and we only look at this file again if the major release changes?
> create mode 100644 source-builder/config/renode-common-1.cfg
> diff --git a/bare/config/devel/renode-1.13.3-1.cfg b/bare/config/devel/renode-1.13.3-1.cfg
> new file mode 100644
> index 0000000..ad9b0ad
> --- /dev/null
> +++ b/bare/config/devel/renode-1.13.3-1.cfg
> @@ -0,0 +1,11 @@
> +# Renode from git
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%define renode_version 1.13.3
> +%include %{_configdir}/renode-1.13.3.cfg
> diff --git a/bare/config/devel/renode.bset b/bare/config/devel/renode.bset
> index 0000000..f89168d
> --- /dev/null
> +++ b/bare/config/devel/renode.bset
> @@ -0,0 +1,7 @@
> +# Build set for Renode
> +%define release 1
> +devel/renode-1.13.3-1
> diff --git a/source-builder/config/renode-1.13.3.cfg b/source-builder/config/renode-1.13.3.cfg
> index 0000000..5aff341
> --- /dev/null
> +++ b/source-builder/config/renode-1.13.3.cfg
> @@ -0,0 +1,7 @@
> +# Renode 1.13.3 Version 1.
> +# This configuration file configure's, make's and install's Renode.
> +%include %{_configdir}/renode-common-1.cfg
> diff --git a/source-builder/config/renode-common-1.cfg b/source-builder/config/renode-common-1.cfg
> index 0000000..65be946
> --- /dev/null
> +++ b/source-builder/config/renode-common-1.cfg
> @@ -0,0 +1,45 @@
> +# Renode from git
> + %define release 1
> +%endif
> +Name: renode-%{renode_version}-%{_host}-%{release}
> +Summary: Renode v%{renode_version}
> +Version: %{renode_version}
> +Release: %{release}
> +URL: http://www.renode.io
> +# Renode source
> +%source set renode https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> +# Prepare the source code.
> +%prep
> + build_top=$(pwd)
> + source_dir_renode="renode_%{renode_version}_source"
> + %source setup renode -q -n renode_%{renode_version}_source
> + cd ${build_top}
> +%build
> + build_top=$(pwd)
> + cd ${source_dir_renode}
> + ./build.sh
> + cd ${build_top}
> +%install
> + build_top=$(pwd)
> + mkdir -p %{_bindir}
> + cp -r ./${source_dir_renode}/* %{_bindir}
> + cd ${build_top}
