xilinx_zynqmp_ultra96 build failures
Mon Jun 5 16:00:13 UTC 2023
Hi
The OAR build sweep turned this up from rtems-bsp-builder.
[1646/4698] Compiling testsuites/fstests/fsdosfssync01/init.c
/home/joel/rtems-work/tools/6/lib/gcc/arm-rtems6/12.2.1/../../../../arm-rtems6/bin/ld:
./librtemsbsp.a(console-config.c.36.o): in function `console_initialize':
/home/joel/rtems-work/rtems/b-xilinx_zynqmp_ultra96/arm/xilinx_zynqmp_ultra96/../../../bsps/arm/xilinx-zynqmp/console/console-config.c:62:
undefined reference to `rtems_termios_initialize'
It impacts multiple configurations of the BSP as seen here:
https://lists.rtems.org/pipermail/build/2023-June/046597.html
Hopefully someone recognizes what happened.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230605/dcf4eefd/attachment.htm>
