[RSB PATCH] rtems/net: Add net services build support
Gedare Bloom
gedare at rtems.org
Mon Jun 5 23:01:27 UTC 2023
Great to see, go ahead.
On Sun, Jun 4, 2023 at 11:20 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> rtems/config/net/net-services-1.cfg | 23 ++++++
> rtems/config/net/net-services.bset | 15 ++++
> rtems/config/tools/rtems-net-services.cfg | 91 +++++++++++++++++++++++
> 3 files changed, 129 insertions(+)
> create mode 100644 rtems/config/net/net-services-1.cfg
> create mode 100644 rtems/config/net/net-services.bset
> create mode 100644 rtems/config/tools/rtems-net-services.cfg
> diff --git a/rtems/config/net/net-services-1.cfg b/rtems/config/net/net-services-1.cfg
> new file mode 100644
> index 0000000..c342547
> --- /dev/null
> +++ b/rtems/config/net/net-services-1.cfg
> @@ -0,0 +1,23 @@
> +# RTEMS Net Services
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +# Net Services Version
> +%define rtems_net_services_version e35f89b6bf8170b5556a90535ed2f1f6b7473d81
> +%hash sha512 rtems-net-services-%{rtems_net_services_version}.tar.bz2 \
> + CqubUTOMm3zohNpOYft5QPTqhl9qEuBo3wcQ5tOTZGRwOMzwQ+3tRyl8ZrcgdTtoV7fIZCoJt5Ty5zTeANdMCQ==
> +%define rtems_waf_version 68654b4f995382765605dc16917baad4bdbf7f7c
> +%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
> + NAuyFxjfSiQd6VfYZl4fJClywPrLF2fN+GjXHjq3ddceqaBrSeHZ+XpYpU3XTnk2qKICsUSTLV+CskDuWdwqvQ==
> +# Net Services Build configuration
> +%include %{_configdir}/tools/rtems-net-services.cfg
> diff --git a/rtems/config/net/net-services.bset b/rtems/config/net/net-services.bset
> index 0000000..7d90399
> --- /dev/null
> +++ b/rtems/config/net/net-services.bset
> @@ -0,0 +1,15 @@
> +# Build set for RTEMS Net Services
> +%define release 1
> +# The RTEMS Package defines
> +%include rtems-package.bset
> +# Build Net Services
> +net/net-services-1
> diff --git a/rtems/config/tools/rtems-net-services.cfg b/rtems/config/tools/rtems-net-services.cfg
> index 0000000..2acfbd8
> --- /dev/null
> +++ b/rtems/config/tools/rtems-net-services.cfg
> @@ -0,0 +1,91 @@
> +# This configuration file configure's, build's and install's
> +# networking services libraries
> +%define release 1
> +%endif
> +Name: rtems-net-services-%{rtems_net_services_version}-%{_host}-%{release}
> +Summary: RTEMS Net Services provides networking services for RTEMS networking
> + stacks.
> +Version: %{rtems_net_services_version}
> +Release: %{release}
> +URL: https://git.rtems.org/rtems-net-services.git/
> +# Net services is packaged as the release version when released.
> +%if %{rsb_released}
> + %define rtems_net_services_version %{rsb_version}
> + %define rtems_net_services_ext xz
> + %define rtems_waf_ext xz
> +%else
> + %define rtems_net_services_ext bz2
> + %define rtems_waf_ext bz2
> +%endif
> +# RTEMS BSP support.
> +%include rtems-bsp.cfg
> +# Net services Source.
> +# If not a release collect and install rtems_waf as cgit snapshots to not
> +# capture submodules.
> +# Releases package submodules in the top level tarfile.
> +%source set rtems_net_services --rsb-file=rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext} \
> + https://git.rtems.org/rtems-net-services/snapshot/rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}
> +%if !%{rsb_released}
> + %source set rtems_waf \
> + https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.%{rtems_waf_ext}
> +%endif
> +# Prepare the source code.
> +%prep
> + build_top=$(pwd)
> + source_dir_net_services="rtems-net-services-%{rtems_net_services_version}"
> + %source setup rtems_net_services -q -n rtems-net-services-%{rtems_net_services_version}
> + %if !%{rsb_released}
> + %source setup rtems_waf -q -s 1 -c -a -n rtems-net-services-%{rtems_net_services_version}/rtems_waf
> + %endif
> + cd ${build_top}
> +# Build the source code.
> +%build
> + build_top=$(pwd)
> + %{host_build_flags}
> + cd ${source_dir_net_services}
> + ./waf distclean configure \
> + --prefix=%{_prefix} \
> + %{rtems_waf_tools} \
> + %{rtems_waf_rtems} \
> + --rtems-bsp=%{rtems_bsp_arch_bsp}
> + ./waf build
> + cd ${build_top}
> +%install
> + build_top=$(pwd)
> + %{__rmdir} ${SB_BUILD_ROOT}
> + ./waf --destdir=$SB_BUILD_ROOT%{rtems_waf_build_root_suffix} install
> + cd ${build_top}
> 2.37.1
> devel mailing list
> devel at rtems.org
