[PATCH 3/4] bsps/xqspipsu: Calculate erase sectors correctly
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jun 7 19:13:46 UTC 2023
When given the exact bounds of a sector, the current algorithm
calculates that 3 sectors need to be erased. This corrects the
calculation such that only 1 sector needs to be erased for erasures that
exactly match sector boundaries.
bsps/shared/dev/spi/xqspipsu-flash-helper.c | 19 +++----------------
1 file changed, 3 insertions(+), 16 deletions(-)
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index 0c1a9ffd2a..cb705ab505 100644
--- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -534,22 +534,18 @@ int QspiPsu_NOR_Erase(
u32 NumSect;
int Status;
u32 SectSize;
- u32 SectMask;
WriteEnableCmd = WRITE_ENABLE_CMD;
if(QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_PARALLEL) {
- SectMask = (Flash_Config_Table[FCTIndex]).SectMask - (Flash_Config_Table[FCTIndex]).SectSize;
SectSize = (Flash_Config_Table[FCTIndex]).SectSize * 2;
NumSect = (Flash_Config_Table[FCTIndex]).NumSect;
} else if (QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_STACKED) {
NumSect = (Flash_Config_Table[FCTIndex]).NumSect * 2;
- SectMask = (Flash_Config_Table[FCTIndex]).SectMask;
SectSize = (Flash_Config_Table[FCTIndex]).SectSize;
} else {
@@ -614,18 +610,9 @@ int QspiPsu_NOR_Erase(
* Calculate no. of sectors to erase based on byte count
- NumSect = (ByteCount / SectSize) + 1;
- * If ByteCount to k sectors,
- * but the address range spans from N to N+k+1 sectors, then
- * increment no. of sectors to be erased
- if (((Address + ByteCount) & SectMask) ==
- ((Address + (NumSect * SectSize)) & SectMask)) {
- NumSect++;
+ u32 SectorStartBase = RTEMS_ALIGN_DOWN(Address, SectSize);
+ u32 SectorEndTop = RTEMS_ALIGN_UP(Address + ByteCount, SectSize);
+ NumSect = (SectorEndTop - SectorStartBase)/SectSize;
for (Sector = 0; Sector < NumSect; Sector++) {
2.30.2
