[PATCH 1/4] bsps/xqspipsu: Ensure NOR writes align
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jun 7 19:13:44 UTC 2023
This change causes NOR writes to be broken according to page boundaries.
Writes across page boundaries cause the writes beyond the boundary to
fail silently. This also introduces a new function that will explicitly
write pages.
bsps/include/dev/spi/xqspipsu-flash-helper.h | 25 ++++++++++-
bsps/shared/dev/spi/xqspipsu-flash-helper.c | 47 +++++++++++++++++++-
2 files changed, 70 insertions(+), 2 deletions(-)
diff --git a/bsps/include/dev/spi/xqspipsu-flash-helper.h b/bsps/include/dev/spi/xqspipsu-flash-helper.h
index 22f85f156c..1e16acaf06 100644
--- a/bsps/include/dev/spi/xqspipsu-flash-helper.h
+++ b/bsps/include/dev/spi/xqspipsu-flash-helper.h
@@ -49,11 +49,34 @@ int QspiPsu_NOR_Erase(
* @note None.
+int QspiPsu_NOR_Write_Page(
+ XQspiPsu *QspiPsuPtr,
+ u32 Address,
+ u32 ByteCount,
+ u8 *WriteBfrPtr
+ * This function writes to the serial Flash connected to the QSPIPSU interface.
+ * Writes will be broken into device page sized and aligned writes as necessary.
+ * @param QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
+ * @param Address contains the address to write data to in the Flash.
+ * @param ByteCount contains the number of bytes to write.
+ * @param WriteBfrPtr is pointer to the write buffer (which is to be transmitted)
+ * @return XST_SUCCESS if successful, else XST_FAILURE.
+ * @note None.
int QspiPsu_NOR_Write(
u32 Address,
u32 ByteCount,
- u8 *WriteBfrPtr
+ u8 *WriteBfrPtr
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index 43dc700507..0c1a9ffd2a 100644
--- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -333,7 +333,7 @@ static int FlashReadID(XQspiPsu *QspiPsuPtr)
return XST_SUCCESS;
-int QspiPsu_NOR_Write(
u32 Address,
u32 ByteCount,
@@ -475,6 +475,51 @@ int QspiPsu_NOR_Write(
return 0;
+int QspiPsu_NOR_Write(
+ u32 Address,
+ u32 ByteCount,
+ u8 *WriteBfrPtr
+ int Status;
+ size_t ByteCountRemaining = ByteCount;
+ unsigned char *WriteBfrPartial = WriteBfrPtr;
+ uint32_t AddressPartial = Address;
+ uint32_t PageSize = Flash_Config_Table[FCTIndex].PageSize;
+ if(QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_PARALLEL) {
+ PageSize *= 2;
+ while (ByteCountRemaining > 0) {
+ /* Get write boundary */
+ size_t WriteChunkLen = RTEMS_ALIGN_UP(AddressPartial + 1, PageSize);
+ /* Get offset to write boundary */
+ WriteChunkLen -= (size_t)AddressPartial;
+ /* Cap short writes */
+ if (WriteChunkLen > ByteCountRemaining) {
+ WriteChunkLen = ByteCountRemaining;
+ Status = QspiPsu_NOR_Write_Page(
+ QspiPsuPtr,
+ AddressPartial,
+ WriteChunkLen,
+ WriteBfrPartial
+ if ( Status != XST_SUCCESS ) {
+ return Status;
+ ByteCountRemaining -= WriteChunkLen;
+ AddressPartial += WriteChunkLen;
+ WriteBfrPartial += WriteChunkLen;
+ return Status;
u32 Address,
2.30.2
