style question: breaking inline assembly lines
Gedare Bloom
gedare at rtems.org
Mon Jun 12 20:09:50 UTC 2023
We have a mix of ways to write inline assembly. It would be convenient
to choose one way. The prevailing options are based on breaking around
the colons (reg/field separators), either to break at colons if the
line length > 80, or to always break at colons.
I personally find it is easier to read inline assembly that has broken
at the colons. But we have these options:
1. Always break at the colon
2. Only break when the line length is exceeded
With #2, we also can break as usual, or we can force breaks at the
colons. I have seen examples of both in the source tree. Any strong
opinions one way or another?
here's a line broken because of line lengths, that has not split the
arguments at the colons:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/include/rtems/score/aarch32-system-registers.h#n69
Here's a line broken because of line lengths:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/include/rtems/score/cpu.h#n501
Here's a line broken always:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/aarch64/cpu.c#n153
And for good measure, here's an unbroken line that should be broken:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h#n206
With the newest version of clang-format we will be able to accommodate
always breaking the lines. It currently is inconsistent with whether
it puts the first argument on its own line, or keeps it with the
"__asm__ volatile (" that I could probably make consistent if we
decide we need it to be.
Gedare
