style question: breaking inline assembly lines
Sebastian Huber
Tue Jun 13 14:51:12 UTC 2023
On 13.06.23 00:04, Gedare Bloom wrote:
> "b _ARM_Exception_default\n"
> - : [cpufsz] "i" (sizeof(CPU_Exception_frame)),
> - [cpuspoff] "i" (offsetof(CPU_Exception_frame, register_sp)),
> - [v7mlroff] "i" (offsetof(ARMV7M_Exception_frame, register_lr)),
> - [cpuvecoff] "J" (offsetof(CPU_Exception_frame, vector)),
> - [cpuvfpoff] "i" (ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET),
> - [cpacr] "i" (ARMV7M_CPACR),
> - [vfpsz] "i" (ARM_VFP_CONTEXT_SIZE)
> + : [cpufsz] "i"( sizeof( CPU_Exception_frame ) ),
If we place operators (e.g. &&, ||, ...) at the end of a broken line,
then we should do this for the : as well.
My current preference would be to format all non-third-party sources
with a standard clang-format selection. I guess in the long run, this
will be the easiest approach to maintain. If we use exotic options, then
we may up ending as clang-format maintainers.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
