BSP-Specific Testing was: [PATCH 00/34] Integrate pre-qualified LEON3 BSP
Wed Jun 14 19:39:51 UTC 2023
On Wed, Jun 14, 2023 at 11:59 AM Sebastian Huber
> On 14.06.23 18:13, Gedare Bloom wrote:
> >>> I think we should have some of the BSP-specific tests under some other
> >>> location in testsuites, while others would be under validation where
> >>> they are used for pre-qualification?
> >>> Maybe it is sensible to introduce testsuites/bsps/ also.
> >> For the unit tests I would use testsuites/unit/bsps and testsuites/unit/cpu.
> > I like this.
> Should the test programs be placed in a "bsps", "bsp", or "cpu"
> directory also:
'bsps' and 'cpu' are consistent with other parts of the tree. So that
would be my preference. It can be renamed if really needed later.
> [666/671] Linking
> build/sparc/gr740/testsuites/validation/ts-validation-timecounter-0.exe
> [667/671] Linking
> build/sparc/gr740/testsuites/validation/ts-validation-timecounter-smp-0.exe
> [668/671] Linking
> build/sparc/gr740/testsuites/validation/bsps/ts-fatal-sparc-leon3-cache-snooping-disabled-boot.exe
> [669/671] Linking
> build/sparc/gr740/testsuites/validation/bsps/ts-fatal-sparc-leon3-cache-snooping-disabled-secondary.exe
> [670/671] Linking
> build/sparc/gr740/testsuites/validation/bsps/ts-fatal-sparc-leon3-clock-initialization.exe
> [671/671] Linking
> build/sparc/gr740/testsuites/validation/bsps/ts-fatal-sparc-leon3-shutdown.exe
> vs.
> [666/671] Linking
> [667/671] Linking
> [668/671] Linking
> build/sparc/gr740/testsuites/validation/ts-fatal-sparc-leon3-cache-snooping-disabled-boot.exe
> [669/671] Linking
> build/sparc/gr740/testsuites/validation/ts-fatal-sparc-leon3-cache-snooping-disabled-secondary.exe
> [670/671] Linking
> build/sparc/gr740/testsuites/validation/ts-fatal-sparc-leon3-clock-initialization.exe
> [671/671] Linking
> build/sparc/gr740/testsuites/validation/ts-fatal-sparc-leon3-shutdown.exe
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
