[PATCH] eng: Add guidelines for validation tests
Thu Jun 15 07:33:12 UTC 2023
Update #3717.
 eng/req/howto.rst | 59 +++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 59 insertions(+)
diff --git a/eng/req/howto.rst b/eng/req/howto.rst
index 0de3c01..688f693 100644
--- a/eng/req/howto.rst
+++ b/eng/req/howto.rst
@@ -1127,6 +1127,65 @@ the following post-condition states.
           parameter in past calls to ${../if/directive:/name} shall not be
           accessed by the ${../if/directive:/name} call.
+Validation Test Guidelines
+The validation test cases, test runners, and test suites are generated by the
+``./spec2modules.py`` script from specification items.  For the placement and
+naming of the generated sources use the following rules:
+* Place architecture-specific validation test sources and programs into the
+  ``testsuites/validation/cpu`` directory.
+* Place BSP-specific validation test sources and programs into the
+  ``testsuites/validation/bsps`` directory.
+* Place all other validation test sources and programs into the
+  ``testsuites/validation`` directory.
+* Place architecture-specific unit test sources and programs into the
+  ``testsuites/unit/cpu`` directory.
+* Place BSP-specific unit test sources and programs into the
+  ``testsuites/unit/bsps`` directory.
+* Place all other unit test sources and programs into the
+  ``testsuites/unit`` directory.
+* Use dashes (``-``) to separate parts of a file name.  Use only dashes, the
+  digits ``0`` to ``9``, and the lower case characters ``a`` to ``z`` for file
+  names.  In particular, do not use underscores (``_``).
+* Use the prefix ``tc-`` for test case files.
+* Use the prefix ``tr-`` for test runner files.
+* Use the prefix ``ts-`` for test suite files.
+* Use the prefix ``tx-`` for test extension files (test support code).
+* Use hierarchical parts to compose a file name.  The order of the parts from
+  general to specific shall be left to right, for example
+  ``tc-task-construct.c``.
+* Tests for fatal errors shall have ``fatal`` as the most general file part,
+  for example ``ts-fatal-too-large-tls-size.c``.
+* Validation test suites shall have ``validation`` as the most general file
+  part, for example ``ts-validation-no-clock-0.c``.
+* Unit test suites shall have ``unit`` as the most general file part, for
+  example ``ts-unit-no-clock-0.c``.
+* Architecture-specific files shall have the architecture name as a file part,
+  for example ``ts-fatal-sparc-leon3-clock-initialization.c``.
+* BSP-specific files shall have the BSP family or variant name as a file part,
+  for example ``tc-sparc-gr712rc.c``.
+* Architecture-specific or BSP-specific tests shall use the ``enabled-by``
+  attribute of the associated build item to make them conditional.
 Verify the Specification Items
2.35.3
