BSP-Specific Testing was: [PATCH 00/34] Integrate pre-qualified LEON3 BSP
Chris Johns
chrisj at rtems.org
Fri Jun 16 04:53:22 UTC 2023
On 16/6/2023 2:41 pm, Sebastian Huber wrote:
> On 16.06.23 00:07, Chris Johns wrote:
>> On 16/6/2023 12:54 am, Sebastian Huber wrote:
>>> The test framework prints out the location of events using the file name and the
>>> line number. So, it would be good if the file names are unique and descriptive.
>>> This is why I like Gedare's proposal to just use "bsps".
>> Is only the basename embedded in the file name, the full path or some form of a
>> relative path?
> Just the basename is printed
Should the fact the file name should be unique to avoid confusion as it is just
the basename be documented in the eng manual? I could not see it mentioned.
