[PATCH v2] eng: Add guidelines for validation tests
Sebastian Huber
Fri Jun 16 05:09:45 UTC 2023
Update #3717.
v2:
* Mention that file name should be unique.
* Clarify file name parts.
* Add examples for enabled-by expressions.
eng/req/howto.rst | 80 +++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 80 insertions(+)
diff --git a/eng/req/howto.rst b/eng/req/howto.rst
index 0de3c01..125dac5 100644
--- a/eng/req/howto.rst
+++ b/eng/req/howto.rst
@@ -1127,6 +1127,86 @@ the following post-condition states.
parameter in past calls to ${../if/directive:/name} shall not be
accessed by the ${../if/directive:/name} call.
+Validation Test Guidelines
+The validation test cases, test runners, and test suites are generated by the
+``./spec2modules.py`` script from specification items. For the placement and
+naming of the generated sources use the following rules:
+* Place architecture-specific validation test sources and programs into the
+ ``testsuites/validation/cpu`` directory.
+* Place BSP-specific validation test sources and programs into the
+ ``testsuites/validation/bsps`` directory.
+* Place all other validation test sources and programs into the
+ ``testsuites/validation`` directory.
+* Place architecture-specific unit test sources and programs into the
+ ``testsuites/unit/cpu`` directory.
+* Place BSP-specific unit test sources and programs into the
+ ``testsuites/unit/bsps`` directory.
+* Place all other unit test sources and programs into the
+ ``testsuites/unit`` directory.
+* Use dashes (``-``) to separate parts of a file name. Use only dashes, the
+ digits ``0`` to ``9``, and the lower case characters ``a`` to ``z`` for file
+ names. In particular, do not use underscores (``_``).
+* The parts of a file name shall be separated by dashes and ordered from most
+ general (left) to more specific (right), for example ``tc-task-construct.c``.
+* The file names associated with tests shall be unique within the system since
+ the test framework prints out only the base file names.
+* Use the prefix ``tc-`` for test case files.
+* Use the prefix ``tr-`` for test runner files.
+* Use the prefix ``ts-`` for test suite files.
+* Use the prefix ``tx-`` for test extension files (test support code).
+* Tests for fatal errors shall have ``fatal`` as the most general file part,
+ for example ``ts-fatal-too-large-tls-size.c``.
+* Validation test suites shall have ``validation`` as the most general file
+ part, for example ``ts-validation-no-clock-0.c``.
+* Unit test suites shall have ``unit`` as the most general file part, for
+ example ``ts-unit-no-clock-0.c``.
+* Architecture-specific files shall have the architecture name as a file part,
+ for example ``ts-fatal-sparc-leon3-clock-initialization.c``.
+* BSP-specific files shall have the BSP family or variant name as a file part,
+ for example ``tc-sparc-gr712rc.c``.
+* Architecture-specific or BSP-specific tests shall use the ``enabled-by``
+ attribute of the associated specification item to make the build item
+ conditional, for example:
+ .. code-block:: yaml
+ build-type: objects
+ enabled-by: arm
+ type: build
+ build-type: test-program
+ enabled-by: bsps/sparc/leon3
+ type: build
Verify the Specification Items
2.35.3
