[PATCH 2/2] bsps: Remove uses of BSP-specific interrupt API
Fri Jun 16 05:36:28 UTC 2023
On 16.06.23 07:04, Chris Johns wrote:
> On 16/6/2023 2:51 pm, Sebastian Huber wrote:
>> On 16.06.23 03:49, Chris Johns wrote:
>>>> diff --git a/bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
>>>> b/bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
>>>> index 96b77907a6..bc211e37b6 100644
>>>> --- a/bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
>>>> +++ b/bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
>>>> @@ -41,7 +41,7 @@
>>>>    #include <grlib/genirq.h>
>>>>      #include <bsp.h>
>>>> -#include <bsp/irq.h>
>>>> +#include <bsp/irq-generic.h>
>>>>      #include <grlib/grlib_impl.h>
>>>>    @@ -227,7 +227,7 @@ static int ambapp_grlib_int_clear
>>>>        struct drvmgr_dev *dev,
>>>>        int irq)
>>>> -    BSP_shared_interrupt_clear(irq);
>>>> +    (void) rtems_interrupt_clear(irq);
>>>>        return DRVMGR_OK;
>>> Why ignore the return code of the clear and assume the result is OK?
>>> This pattern is repeated in other places.
>> This is how it is. I didn't want to introduce functional or API changes with
>> this patch set.
> I do not see the API change.
> If the code here is looking through the interface provided to the implementation
> so it knows no error will be returned then it is functionally equivalent to what
> exists if the error is checked. Nothing changes. The problem with the change is
> using the interface implies the error is being checked and a change in the
> implementation to return an error would not be handled here. Leaving a latent
> issue like that does not seem right?
The BSP_shared_interrupt*() functions have no return value and they
didn't check anything. The patch was supposed to be a simple change from
one API to another. I added some error checks to v2 of the patch set.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
