[PATCH v2 1/3] pci: Do not use BSP-specific interrupt API
Fri Jun 16 05:37:38 UTC 2023
Look good.
Thanks
On 16/6/2023 3:34 pm, Sebastian Huber wrote:
> Update #3269.
>  cpukit/include/pci/irq.h | 17 ++++-------------
>  1 file changed, 4 insertions(+), 13 deletions(-)
> diff --git a/cpukit/include/pci/irq.h b/cpukit/include/pci/irq.h
> index 4069f1ffa8..8617dd1680 100644
> --- a/cpukit/include/pci/irq.h
> +++ b/cpukit/include/pci/irq.h
> @@ -38,18 +38,9 @@
>  #ifndef __PCI_IRQ_H__
>  #define __PCI_IRQ_H__
> -#include <rtems/irq-extension.h>
> +#include <rtems/rtems/intr.h>
>  #include <rtems/score/basedefs.h>
> - * FIXME: This should be available via the IRQ extensions API.
> - * https://devel.rtems.org/ticket/3269
> -void BSP_shared_interrupt_clear(int irq);
> -void BSP_shared_interrupt_unmask(int irq);
> -void BSP_shared_interrupt_mask(int irq);
>  /* PCI Handler (ISR) called when IRQ is generated by any of the PCI devices
>   * connected to the same PCI IRQ Pin. This has been defined the same way as
>   * rtems_interrupt_handler in order for BSPs to "direct-map" the register
> @@ -106,7 +97,7 @@ static inline int pci_interrupt_unregister(int irq, pci_isr isr,
>  static inline void pci_interrupt_unmask(int irq)
> -	BSP_shared_interrupt_unmask(irq);
> +	(void)rtems_interrupt_vector_enable((rtems_vector_number)irq);
>  /* Disable shared PCI IRQ handler. This function will mask the interrupt
> @@ -122,7 +113,7 @@ static inline void pci_interrupt_unmask(int irq)
>  static inline void pci_interrupt_mask(int irq)
> -	BSP_shared_interrupt_mask(irq);
> +	(void)rtems_interrupt_vector_disable((rtems_vector_number)irq);
>  /* Acknowledge the interrupt controller by writing to the interrupt controller.
> @@ -136,7 +127,7 @@ static inline void pci_interrupt_mask(int irq)
>  static inline void pci_interrupt_clear(int irq)
> -	BSP_shared_interrupt_clear(irq);
> +	(void)rtems_interrupt_clear((rtems_vector_number)irq);
>  #endif /* !__PCI_IRQ_H__ */
